Beckhoff ethercat 64 with bit linuxcnc, How to install.
7 years 3 months ago #138653 by JimPanski
Hi Grotius!
this was quick ;) yes, i hope this will be nice :D
GOOD NEWS! I managed to find the problem. At the installation of the preemt kernel i got the wrong header files choosen. Now with the correct headers and deinstalled unused kernel+header files this works so far! awsome...
Thank you for your quick response and generally for your nice feedback with those components. only because of that i am now switched to beckhoff for this upcoming project ;)
Best regards
Conny
7 years 3 months ago #138709 by JimPanski
Hi Grotius,
my inputs on the EL1004 modules are working fine now :) At least on the second try. Now i know that you cant load the lcec component in the already existing postgui_call_list.hal! its a bit tricky because of postgui.hal in the description.
But one thing i have to ask:
Grotius wrote: I now use a EL2124 to guide 4 stepgen signals ( 4 motor pulse train's )
Does it mean you are using one EL2124 for 4 independent stepper drivers? if so, please tell me how can this be done if you need a 5v STP DIR and ENA signal for one driver.
Thank you!
7 years 3 months ago #138898 by Grotius
@Nico,
Thank you very much for your tutorial. Sorry i was a bit late to thank you.
Respect for you B)
The following user(s) said Thank You: Nico2017
7 years 3 months ago - 7 years 3 months ago #138919 by Grotius
@Jim,
2 pieces of this high speed (<1ms) output stuff is enough.
Switching times typ. TON: < 1 µs, typ. TOFF: < 1 µs
If a McLaren has this valve time, they will go faster....
Is this for the Nico tutorial? Please provide more information about your item... This for other user's.
Last edit: 7 years 3 months ago by Grotius.
7 years 3 months ago #138967 by JimPanski
Hello Grotius!
so this means you dont use the ena signal on the drivers and ony stp+dir for one axis?
Yes, in both tutorials you have to create the halfile called postgui.hal. thats a bit confusing because when you use the (already) existig postgui_call_list.hal to shorten things up (i thaught in that moment), you wont succeed ;)
What item do you mean?
Cheers,
Conny
7 years 3 months ago #139018 by Grotius
@Conny,
That is correct. I don't use enable signals, do you know why?
You need the postgui.hal file. It's a very good program flow for the linuxcnc software. Some developper's had to think about
this file at that time.
In my tutorial there is no file like :
Time to create page: 0.152 seconds
