- Thank you received: 3
Beckhoff ethercat 64 with bit linuxcnc, How to install.
- JimPanski
7 years 3 months ago #139029
by JimPanski
Replied by JimPanski on topic Beckhoff ethercat 64 with bit linuxcnc, How to install.
No, I really don't know why. Please tell me the reason why.
- Grotius
- Thank you received: 2349
7 years 3 months ago - 7 years 3 months ago #139036
by Grotius
Replied by Grotius on topic Beckhoff ethercat 64 with bit linuxcnc, How to install.
@Jim,
I will tell you why..
Once i was expert programmer related to Kuka robotic's.
Safety is number one in automotive industry. So enable the robot servo drives is not a option if a person is trapped by a robot.
It will only cause more (hours) of delay to free the person. To free the person first the drives have to be enabled. For lineair machines main power shut down is the best option.
Last edit: 7 years 3 months ago by Grotius.
- JimPanski
7 years 3 months ago #139121
by JimPanski
Hi Grotius,
thanks, that makes sense.
There is one other thing:
Please tell me, that i have a chance to use Beckhoff KL modules with linuxcnc. (if not - i may have a problem..)
- JimPanski
7 years 3 months ago - 7 years 3 months ago #140567
by JimPanski
Hello Grotius,
I didnt get this. So please can you say what in your example was really needed to change?
Conny
Grotius wrote: 3. Modify the EL3255.c and EL3255.h to your EL3062.c and EL3062.h needs.
It's almost as simple as the find and replace function for whole document with text editor geany.
Conny
Last edit: 7 years 3 months ago by JimPanski.
- Grotius
7 years 3 months ago #140568
by Grotius
Hi Conny,
What i mentioned, if a driver not exist's it is possible to copy and edit a existing driver.
- JimPanski
7 years 3 months ago #140570
by JimPanski
What i meant was what exactly is needed to change in this files.
In the .h file i have seen its the PID VID and PDOS lines but what do i need to change in the .c file?
I am asking because today i get my K-Bus modules wich now i need to adopt drivers for
Thank you!
Conny
Thank you!
Conny
Time to create page: 0.563 seconds
