- Thank you received: 114
Beckhoff ethercat 64 with bit linuxcnc, How to install.
- bkt
6 years 3 months ago #176014
by bkt
Replied by bkt on topic Beckhoff ethercat 64 with bit linuxcnc, How to install.
Ok thanks ... today i try to install the iso you have posted on first page of these thread .... in these way I hope I can start .... after these we can verify, with some your help, the differences between installation on debian 9 and ubuntu18.04/mint19 (that is the same SO with different WM and less bloatware on mint side, more or less .... but normally I start from minimal installation on ubuntu .... ).
Thanks for your help test ..... to date I have not seen what happened .... but I think it's just a problem of folder paths or rt-preemt patch version. If I knew the way linuxcnc-ethercat builds the paths and what it expects to find in the various folders, I probably would have already solved ... but this takes time which I don't know where to go.
bkt
bkt
- Tady
6 years 3 months ago #176025
by Tady
Replied by Tady on topic Beckhoff ethercat 64 with bit linuxcnc, How to install.
Hey guys.
Can anyone tell me if someone installed this on a PI?
I am trying to build this package but after running
i get ....
Any ideas? probably the kernel is not supported?
sudo dpkg -i etherlabmaster_1.5.2+20190904hg33b922p8ea394-1_armhf.deb
i get ....
DKMS: install completed.
Building initial module for 4.19.118-v7l+
Error! Bad return status for module build on kernel: 4.19.118-v7l+ (armv7l)
Consult /var/lib/dkms/etherlabmaster/1.5.2+20190904hg33b922p8ea394/build/make.log for more information.
dpkg: error processing package etherlabmaster (--install):
installed etherlabmaster package post-installation script subprocess returned error exit status 10
Processing triggers for libc-bin (2.28-10+rpi1) ...
Errors were encountered while processing:
etherlabmaster
Linux raspberrypi 4.19.127-rt55-v7l+ #1 SMP PREEMPT RT Mon Jul 13 09:30:06 CEST 2020 armv7l GNU/Linux
- Tady
6 years 3 months ago #176037
by Tady
Huh i just noticed that kernel versions do not match
- bkt
6 years 3 months ago #176039
by bkt
and where did you find the news? I'm using the 4.18 kernel on mint .... and I'm having problems ...
bkt
bkt
- Tady
6 years 3 months ago #176046
by Tady
Sorry the news?
- bkt
6 years 3 months ago #176071
by bkt
where you find these notice ... on reading terminal output or in other land (like other forum)?
bkt
bkt
Time to create page: 0.172 seconds
