- Thank you received: 4153
Ethercat installation from repositories - how to step by step
3 years 1 month ago #281279
Replied by rodw on topic Ethercat installation from repositories - how to step by step
I think lib-ethercat is a dkms module. dkms must be enrolled in uefi or nothing will install. Please read the first post about this.Hello everyone, Hi Rodw
Many thanks for this thread, however i'm noob in C and all programming language. Can someone help me fixing Panasonic A6B Absolute servo with ethercat?
Here i tried to install Debian 12.1 and tried following instructions on this thread. Pl Pardon my stupidity. I'm getting below error when i try to install ethercat
sudo apt-get install linuxcnc-ethercat
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
linuxcnc-ethercat : Depends: libethercat (>= 1.5.2.309.gc8a512a) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
- marq_torque
- Thank you received: 3
3 years 1 month ago #281412
by marq_torque
Replied by marq_torque on topic Ethercat installation from repositories - how to step by step
Previous installation was on Lenovo Thinkpad Laptop it looks whimsical in bios, so now installing on Gigabyte H61, I'm installing from scratch on intel i3 now stuck at
The repository 'cdrom://[Official Debian GNU/Linux Live 12.1.0 xfce 2023-07-22T09:48:34Z] bookworm Release' does not have a Release file.,
3 years 1 month ago #281428
One post per problem. I have already replied elsewhere.Previous installation was on Lenovo Thinkpad Laptop it looks whimsical in bios, so now installing on Gigabyte H61, I'm installing from scratch on intel i3 now stuck at
- soungoulian
3 years 1 month ago #281431
by soungoulian
Replied by soungoulian on topic Ethercat installation from repositories - how to step by step
Hi Rod, Thank you so much for all of your effort putting together and updating tutorials... For the google drive link to your Linuxcnc live installer (with required third party repositories pre installed) in the "Ethercat installation from repositories - how to step by step" thread, the link appears to be down (says that the iso is in your trash). Is this the same iso in the index (
linuxcnc.org/iso/
)? Thanks again, - Sevan
- marq_torque
3 years 1 month ago - 3 years 1 month ago #281438
by marq_torque
Hello Rodw,
Pardon my multiple posts... I started fresh install on i3 H61 UEFI Motherboard, Debian 12, 6.3 Kernel
This first step "sudo apt install ethercat-master libethercat-dev linuxcnc-ethercat" is throwing below errors
[sudo] password for vcam:
E: Unable to locate package ethercat-master
E: Unable to locate package libethercat-dev
E: Unable to locate package linuxcnc-ethercat
Last edit: 3 years 1 month ago by marq_torque.
3 years 1 month ago #281465
did you do
sudo apt update
sudo apt upgrade?
Did you install with my ISO in the first post? If not you will need to set up the repos manually per the spoiler
sudo apt update
sudo apt upgrade?
Time to create page: 3.003 seconds
