- Thank you received: 4153
Ethercat installation from repositories - how to step by step
3 years 1 week ago #283322
Replied by rodw on topic Ethercat installation from repositories - how to step by step
You missed the last step to create a udev rule
- eduard
- Thank you received: 12
3 years 1 week ago #283324
by eduard
Replied by eduard on topic Ethercat installation from repositories - how to step by step
Thanks!
And how can I automate the ethercat service?
3 years 1 week ago #283328
Ethercat should start automatically on reboot once you have the udev rule and all other steps complete.
- eduard
3 years 1 week ago #283381
by eduard
Everyting works now. Succes.
I began to blink some leds on digital outputs, but no success yet. I have EK1100, EL1008, EL2008 and have not yet found a description of its use that is easy to follow for me.
Now I have this exact output as you mention in first page:
Component Pins:
Owner Type Dir Value Name
4 u32 OUT 0x00000001 lcec.conf.master-count
4 u32 OUT 0x00000004 lcec.conf.slave-count
but no pins show up.
Component Pins:
3 years 1 week ago #283383
- Sockheaven
- Thank you received: 11
2 years 11 months ago - 2 years 11 months ago #285399
by Sockheaven
Replied by Sockheaven on topic Ethercat installation from repositories - how to step by step
I am upgrading from LinuxCNC 2.8.0 with EtherCAT using one of the previous ISOs and was directed to this guide. I successfully installed using the standard ISO and the guide at the beginning of this thread.
I copied the previous config files (.HAL/.INI/ethercat-conf.xml) but am finding that only 1 of my axes is initializing to behaving correctly based on the control word i issue from Linux CNC.
I took outputs from both the working old PC and the output of the new PC that can only enable one axis
I was hoping someone might help me decipher the differences. I have attached outputs of:
$ sudo dmesg -T | grep EtherCAT
$ sudo ethercat slaves
Devices/Axis order in config is: Y - X - Z
Note: Working: All 3 axes can be enabled/disabled
Failing: Y and Z are not responding over ethercat, but X enables/disables and is reading/sending position commands correctly
One thing that stands out about the new config is it appears to be trying to start EoE (EtherNet over EtherCAT), and I am just trying to use CoE (Can over EtherCAT)
I'm not sure that's root cause though, but thought it worth mentioning. Let me know if any additional info would help determining what is going on.
Last edit: 2 years 11 months ago by Sockheaven.
Time to create page: 0.725 seconds
