Ethercat installation from repositories - how to step by step
2 years 8 months ago - 2 years 8 months ago #293660 by igh-vh
Have you tried
sudo dpkg-reconfigure ethercat-dkms
to rebuild the ethercat modules after upgrading the kernel? And are the corresponding headers also installed (linux-headers-6.1.0-18-rt-amd64)?
Last edit: 2 years 8 months ago by igh-vh.
The following user(s) said Thank You: rodw, jjdege, zmrdko
2 years 8 months ago #294411 by Rojs0nik
Hello everyone,
Can anybody help me because when I type
cd ~/dev
it says that there is no such file or directory
2 years 8 months ago #294432 by rodw
Sorry, I missed a command
mkdir ~/dev
I amnot sure where scott is with his cia402 support as this may become redundant.
2 years 8 months ago #294435 by Rojs0nik
Thank you,
everything worked, now i can move on
2 years 7 months ago - 2 years 6 months ago #296108 by PeakWang
thank you, I do step by step according your guidance, It seems everything is ok, i also got the same result.
can you advice me or give me an link on how to set up an system with Ethercat servo after that, it seems only Stepconf.Wizard and Pncconf.Wizard. thank you
Update 2024.4.7
I managed to get the three motors moving through LinuxCNC via Ethercat last week, Now I still have some issues on how to adjust on ballscrew pitch, encoder bit(I have 2^17 encoder).......
Last edit: 2 years 6 months ago by PeakWang.
2 years 6 months ago - 2 years 6 months ago #297448 by meister
strange,
following the steps from the first post on Raspberry PI 400 and getting...
Debian GNU/Linux 12 (bookworm) 6.1.54-rt15 #1_RT Sat Oct 21 18:12:02 AEST 2023
aarch64
Raspberry Pi 400 Rev 1.1
== DISK
Filesystem Size Used Avail Use% Mounted on
/dev/mmcblk0p2 29G 4.5G 23G 17% /
/dev/mmcblk0p1 508M 55M 454M 11% /boot/broadcom
== NETWORK
Hostname: raspberrypi
Wireless: wlan0 UP 192.168.10.248
== SYSTEM
Processor: Cortex-A72 @ 1800MHz 35.5°C
Online: 0-3
Governor: performance
Memory: 3.3G 264M
Entropy: 256
Uptime: 03:01:30 up 0 min, 1 user, load average: 3.41, 0.82, 0.27
Last login: Wed Apr 3 02:58:07 2024 from 192.168.10.23
root@raspberrypi:~#
root@raspberrypi:~# ethercat master
Failed to obtain number of masters: Failed to open master device /dev/EtherCAT0: No such file or directory
root@raspberrypi:~#
(reverse-i-search)`': ^C
root@raspberrypi:~# systemctl status ethercat
● ethercat.service - EtherCAT Master Kernel Modules
Loaded: loaded (/lib/systemd/system/ethercat.service; enabled; preset: enabled)
Active: active (exited) since Wed 2024-04-03 03:01:15 AEST; 1min 36s ago
Process: 447 ExecStart=/usr/sbin/ethercatctl start (code=exited, status=0/SUCCESS)
Main PID: 447 (code=exited, status=0/SUCCESS)
CPU: 130ms
Apr 03 03:01:15 raspberrypi systemd[1]: Starting ethercat.service - EtherCAT Master Kernel Modules...
Apr 03 03:01:15 raspberrypi systemd[1]: Finished ethercat.service - EtherCAT Master Kernel Modules.
root@raspberrypi:~#
root@raspberrypi:~# /usr/sbin/ethercatctl status
Checking for EtherCAT master 1.5.2
Master0 dead
root@raspberrypi:~#
root@raspberrypi:~# /usr/sbin/ethercatctl stop
rmmod: ERROR: Module ec_master is in use by: ec_genet
root@raspberrypi:~# rmmod ec_genet
root@raspberrypi:~# /usr/sbin/ethercatctl start
Master0
Phase: Idle
Active: no
Slaves: 0
Ethernet devices:
Main: e4:5f:01:49:6a:7f (attached)
Link: DOWN
Tx frames: 0
Tx bytes: 0
Rx frames: 0
Rx bytes: 0
Tx errors: 0
Tx frame rate [1/s]: 0 0 0
Tx rate [KByte/s]: 0.0 0.0 0.0
Rx frame rate [1/s]: 0 0 0
Rx rate [KByte/s]: 0.0 0.0 0.0
Common:
Tx frames: 0
Tx bytes: 0
Rx frames: 0
Rx bytes: 0
Lost frames: 0
Loss rate [1/s]: 0 0 0
Frame loss [%]: 0.0 0.0 0.0
Distributed clocks:
Reference clock: None
DC reference time: 0
Application time: 0
2000-01-01 00:00:00.000000000
root@raspberrypi:~#
root@raspberrypi:~# uname -a
Linux raspberrypi 6.1.54-rt15 #1 SMP PREEMPT_RT Sat Oct 21 18:12:02 AEST 2023 aarch64 GNU/Linux
root@raspberrypi:~# lsb_release -a
No LSB modules are available.
Distributor ID: Debian
Description: Debian GNU/Linux 12 (bookworm)
Release: 12
Codename: bookworm
now with an slave, it looks ok:
root@raspberrypi:~# ethercat slaves
0  0:0  INIT  E  SAME54 EtherCAT Slave
Last edit: 2 years 6 months ago by meister.
Time to create page: 0.330 seconds
