Ethercat installation from repositories - how to step by step
- RiJa
2 years 3 months ago - 2 years 3 months ago #304209
by RiJa
Replied by RiJa on topic Ethercat installation from repositories - how to step by step
Last edit: 2 years 3 months ago by RiJa.
- Thank you received: 4153
2 years 3 months ago #304215
Replied by rodw on topic Ethercat installation from repositories - how to step by step
I think there is a path issue in line 14 looking for lcec_conf
The following user(s) said Thank You: RiJa
- RiJa
2 years 3 months ago - 2 years 3 months ago #304239
by RiJa
2 years 3 months ago #304243
Yes, I know. I looked at my git repo before replying. But the difference is it worked for me and is reporting a file not found error for you. Read the error message you posted. I have also experienced similar errors in the past. You can either continue to complain or undertake some troubleshooting at your end to resolve the error like I did. I can't help further.I'm using the same file as you posted earlier, the path on line 14 is:
loadusr -W ./lcec_conf ethercat-conf.xml
- zjjxxsh
2 years 3 months ago #304329
by zjjxxsh
Replied by zjjxxsh on topic Ethercat installation from repositories - how to step by step
Err:1
download.opensuse.org/repositories/science:/EtherLab/Debian_12
./ ethercat-master 1.6.0.gcafd367-1+1.2
404 Not Found [IP: 95.216.238.135 80]
Err:2 mirror.aardsoft.fi/opensuse/repositories...A/EtherLab/Debian_12 ./ linuxcnc-ethercat 1.39.0.g4299f7a-0
E: Failed to fetch mirror.aardsoft.fi/opensuse/repositories...67-1%2B1.2_arm64.deb 404 Not Found [IP: 95.216.238.135 80]
E: Failed to fetch mirror.aardsoft.fi/opensuse/repositories...g4299f7a-0_arm64.deb 404 Not Found [IP: 95.216.238.135 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
This is what I got, by enter "sudo apt install linuxcnc-ethercat"
- NickH
2 years 3 months ago #305000
by NickH
Replied by NickH on topic Ethercat installation from repositories - how to step by step
Hello Rodw, I think this is what I am coming-up against. When running 'sudo halcmd loadusr -W Icec_conf ethercat-conf.xml ' I get 'commandlin>:0: execv(Icec_conf): no such file or directory' then 'waitpid failed Icec_conf', and then 'Icec_conf exited'..
I'm on the last parts of setting up Ethercat and get stumped by this.
Also, thank you for pointing me in the right direction on the RTAI thread wrt ethercat.
Time to create page: 1.508 seconds
