Ethercat installation from repositories - how to step by step
- Mehta_123
2 years 6 months ago - 2 years 6 months ago #298341
by Mehta_123
Replied by Mehta_123 on topic Ethercat installation from repositories - how to step by step
Hello !!Thanks for the detailed steps, I have installed ethercat and able to detect slaves. As I am totally new to this I am not able to start LCNC.I have followed steps of xml and hal file from youtube (attaching hal file and error for your reference)
I am aware that its the issue of xml file as I am using different driver (panasonic MBDLN25BE)
Can you please guide me what type of changes I need to do in xml file ?
Thanks and Regards,
Mehta
Thanks and Regards,
Mehta
Last edit: 2 years 6 months ago by Mehta_123.
- sevketsakinc
2 years 5 months ago #300972
by sevketsakinc
Replied by sevketsakinc on topic Ethercat installation from repositories - how to step by step
Hello, first of all, thank you for your descriptive shares.
I used a servo with ethercat using "Debian 9" 4 years ago and it has been working since then.
PC: INTEL 9TH GENERATION I3
Ethercat version is 1.5.2.
Servo: Panasonic A6
Now I wanted to use Debian 12, Ethercat version 1.6.0 and LinuxCNC 2.9.2, which has been updated according to your shares.
PC: INTEL 12th GENERATION i3
When I close the Linuxcnc interface, the servos get a synchronization error. This did not happen in the old version.
The servo is still the same servo (PANASONIC A6) but I was getting 80.4 synchronization error.
This error ( <dcConf assignActivate="300" sync0Cycle="*1" sync0Shift="0"/>
<watchdog divider="2498" intervals="5000"/>
I solved it by doing .
But now, when I restart it, some of the servos do not switch to OP mode on the first try.
Can you help me ?
I am grateful.
Servo: Panasonic A6
Can you help me ?
I am grateful.
- sevketsakinc
2 years 5 months ago #301107
by sevketsakinc
After installing Debian 12, this time I installed ethercat 1.5.2 version.
The problem is still the same.
I suspect it's from Debian 12 or Linuxcnc 2.9.2.
Ethercat protocol does not work properly on servos.
- Cristian_g
2 years 4 months ago #302470
by Cristian_g
Replied by Cristian_g on topic Ethercat installation from repositories - how to step by step
Hi, I have installed bookworm kernel version 6.1.54-rt15 on a Raspberry Pi 4B. After restart, I have tried to install the cia 402 drivers, but the git command gives me an permission denied error. In the first attempt I used the sudo to install the drivers, however the hallcmd command to load the configuration file gave me an error. Should I used the sudo to install the drivers? Thank You for your help!
- Thank you received: 4153
2 years 4 months ago #302525
Replied by rodw on topic Ethercat installation from repositories - how to step by step
Git does not require root permissions (sudo)
Using halcompile does.
Installing software from repositories with apt install needs sudo apt install
- Cristian_g
2 years 4 months ago #302537
by Cristian_g
Thank You! I was able to install everithing according to your instructions. I did not know that git has now a credential manager.
Time to create page: 0.185 seconds
