- Thank you received: 38
Ethercat installation from repositories - how to step by step
- jjdege
2 years 8 months ago - 2 years 8 months ago #292375
by jjdege
Replied by jjdege on topic Ethercat installation from repositories - how to step by step
Hi rodw
congratulations for the magnificent work!
I wanted to point out something strangeI installed the ISO [url] linuxcnc.org/downloads/ [/url]after the first upgrade, I get this error:
repeated the installation three times but nothing changes.
This does not affect the installation of the EtherCAT repositories
but it persists
I tried with a standard installation
with Iso Debian Bookworm and everything works fine
thank you so much
but it persists
thank you so much
Last edit: 2 years 8 months ago by jjdege.
- Thank you received: 7491
2 years 8 months ago #292382
Replied by tommylight on topic Ethercat installation from repositories - how to step by step
Can you please post the result of
lsb_release -a
Thank you.
To fix the update issue:
forum.linuxcnc.org/9-installing-linuxcnc...-update-error#289920
But do read also the post below as there is a typo on that post.
lsb_release -a
Thank you.
The following user(s) said Thank You: jjdege
- jjdege
2 years 8 months ago - 2 years 8 months ago #292406
by jjdege
wow!!! thanks I solved it
this is the result of
lsb_release -a
Thank you very much
lsb_release -a
Thank you very much
- bob8020
- Visitor
2 years 8 months ago - 2 years 8 months ago #292630
by bob8020
Replied by bob8020 on topic Ethercat installation from repositories - how to step by step
Deleted - wrong thread. Moved to new thread about wiring EtherCAT Delta servo absolute encoder.
Last edit: 2 years 8 months ago by bob8020. Reason: should have made new thread
- Thank you received: 4153
2 years 8 months ago #292640
Replied by rodw on topic Ethercat installation from repositories - how to step by step
@jjdege
This does not appear to be anything to worry about. The RT kernel errors on an update to the net version but all other packages seem to get installed.
I replicated this yesterday as it was reported by another user.
@everybody, please don't raise issues on this thread that are not related to ethercat installation. Add another thread in the appropriate forum section.
- jjdege
2 years 8 months ago #293481
by jjdege
Time to create page: 0.157 seconds
