- Thank you received: 3
Ethercat installation from repositories - how to step by step
- marq_torque
3 years 1 month ago #281767
by marq_torque
Replied by marq_torque on topic Ethercat installation from repositories - how to step by step
Oh okay, I'll follow the instructions and share the progress.
Thanks Rodw
Thanks Rodw
- eduard
- Thank you received: 12
3 years 1 week ago #283261
by eduard
Replied by eduard on topic Ethercat installation from repositories - how to step by step
Hi Rod,
prevoiusly I istalled LCNC booted from USB stick, but with this file, not booting up? Did you have any suggestions? I write it with etcher, like previously.
Thanks.
Thanks.
- Thank you received: 4153
3 years 1 week ago #283270
Replied by rodw on topic Ethercat installation from repositories - how to step by step
have you set the boot order in the BIOS so that it tries the usb stick first.
You have not given us any useful information about what is happening.
Also what hardware?
Also what hardware?
- eduard
3 years 1 week ago #283284
by eduard
Yes, you are right. I thought the problem is mutch simpler.
So, I have a mintbox mini, linux pc which has UEFI bios and can boot in uefi, legacy and dual mode. I set dual, and foot from usb drive.
The regular LCNC image written by etcher booting fine from the same usb stick, and the ethercat version can not, with very same process and parameters.
- eduard
3 years 1 week ago #283289
by eduard
Success! I wrote again with etcher the same iso to the same stick and it is working now. How strange is that?
- eduard
3 years 1 week ago - 3 years 1 week ago #283318
by eduard
I have the system up and running, the ethercat slaves listed. Not tested with LCNC nor created the xml, but huge success for today. Thanks Rod!
After the reboot of the PC I have to issue these commands again.
sudo systemctl enable ethercat.service
sudo systemctl start ethercat.service
sudo systemctl status ethercat.service
sudo chmod 666 /dev/EtherCAT0
how can I set permanent the chmod and initialize the system to run after reboot the ethercat service?
Last edit: 3 years 1 week ago by eduard.
Time to create page: 0.487 seconds
