- Thank you received: 38
Ethercat installation from repositories - how to step by step
- jjdege
2 years 3 months ago - 2 years 3 months ago #306487
by jjdege
Replied by jjdege on topic Ethercat installation from repositories - how to step by step
Hi
waiting for a more suitable solution
I solved it almost like zylos146.
I searched and deleted all the ethercat-dkms folders, including the .deb
then I downloaded ethercat-stable-1.6 from
[url] gitlab.com/etherlab.org/ethercat [/url]
followed the installation from install.md everything went well.
then I performed the standard installation here
it no longer returns errors
Hi
Hi
Last edit: 2 years 3 months ago by jjdege.
The following user(s) said Thank You: AndriySM
- AndriySM
2 years 3 months ago #306492
by AndriySM
Replied by AndriySM on topic Ethercat installation from repositories - how to step by step
jjdege .Thank you, I'll try to do that this evening, I hope to succeed
- Thank you received: 4153
2 years 3 months ago #306498
I built a new image. The keys have been fixed but I am getting a dkms erorr so no joy.
I've updated the issue upstream, gitlab.com/etherlab.org/ethercat/-/issues/131
so hopefully they will fix it soon. They have always beeen very good to me
Replied by rodw on topic Ethercat installation from repositories - how to step by step
Not quite out of the woods. the changes were pushed to the LInuxcnc code on github.Hi
Hi
The following user(s) said Thank You: tommylight, jjdege, AndriySM
- Moutomation
- Thank you received: 11
2 years 3 months ago #306610
by Moutomation
Replied by Moutomation on topic Ethercat installation from repositories - how to step by step
Err:1
download.opensuse.org/repositories/science:/EtherLab/Debian_12
./ ethercat-dkms 1.5.2.429.g3079ece-1+392.1
404 Not Found [IP: 195.135.223.226 80]
Err:2 download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ ethercat-master 1.5.2.429.g3079ece-1+392.1
Err:3 download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ libethercat 1.5.2.429.g3079ece-1+392.1
Err:4 download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ linuxcnc-ethercat 1.25.1.g180ad89-0
E: Failed to fetch download.opensuse.org/repositories/scien...ce-1%2b392.1_all.deb 404 Not Found [IP: 195.135.223.226 80]
E: Failed to fetch download.opensuse.org/repositories/scien...-1%2b392.1_amd64.deb 404 Not Found [IP: 195.135.223.226 80]
E: Failed to fetch download.opensuse.org/repositories/scien...g180ad89-0_amd64.deb 404 Not Found [IP: 195.135.223.226 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Err:1 download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ ethercat-dkms 1.5.2.429.g3079ece-1+392.1
Err:4 download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ libethercat-dev 1.5.2.429.g3079ece-1+392.1
Err:5 download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ linuxcnc-ethercat 1.25.1.g180ad89-0
I've done this before on another computer and there was no problem. Is there a problem with the computer?
- jjdege
2 years 2 months ago - 2 years 2 months ago #306667
by jjdege
thanks!
everything is working again, even on Raspy Pi5
thanks to everyone
thanks to everyone
Last edit: 2 years 2 months ago by jjdege.
- jjdege
2 years 2 months ago - 2 years 2 months ago #306669
by jjdege
sorry double
Time to create page: 0.150 seconds
