Ethercat installation from repositories - how to step by step
- Rkatts
1 year 11 months ago #314167
by Rkatts
Replied by Rkatts on topic Ethercat installation from repositories - how to step by step
This seems to have fixed the permissions.
Then ran:
Tried again from the start.
Any ideas?
nc:~/Downloads$ chmod +x ecat.sh
Then ran:
nc:~/Downloads$ sudo ./ecat.sh
[sudo] password for aa:
requires sudo to run eg: sudo ./ecat.sh
Install ethercat repository
--2024-11-09 19:52:41-- https://build.opensuse.org/projects/science:EtherLab/signing_keys/download?kind=gpg
Resolving build.opensuse.org (build.opensuse.org)... 195.135.223.221, 2a07:de40:b250:131:10:151:131:20
Connecting to build.opensuse.org (build.opensuse.org)|195.135.223.221|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: unspecified [application/octet-stream]
Saving to: ‘STDOUT’
- [ <=> ] 1.08K --.-KB/s in 0s
2024-11-09 19:52:42 (28.1 MB/s) - written to stdout [1109]
1+1 records in
1+1 records out
733 bytes copied, 0.608919 s, 1.2 kB/s
nc:~$ sudo apt update
E: Conflicting values set for option Signed-By regarding source http://download.opensuse.org/repositories/science:/EtherLab/Debian_12/ ./: /etc/apt/trusted.gpg.d/science_EtherLab.gpg != /etc/apt/trusted.gpg.d/science_EtherLab.gpg.key.binary.gpg
E: The list of sources could not be read.
Any ideas?
- Rkatts
1 year 11 months ago #314214
by Rkatts
This worked:
Installing ethercat repositories - Page 2 - LinuxCNC
- Rkatts
1 year 11 months ago - 1 year 11 months ago #314446
by Rkatts
After installing LinuxCNC 2.9.3 (Debian 12) and EtherCAT module (Master driver 1.6.2), I am unable to get EtherCAT communication working. LinuxCNC will run, but there is no active status or feedback positions. DS402 statuswords are zero, indicating there is no communication.
I have a LinuxCNC system running with an older version (2.8.0). I copied the linuxcnc_axis folder from the working system and put it into this one and made adjustments for the new system.
In ecat_gantry.ini, the hal file is listed correctly.
In ecat_gantry.hal, I updated the loadusr command. (removed the path that was incorrect)
The ethercat-conf.xml file is configured correctly for the three servo drives. This same configuration works on an almost identical system. The only difference in hardware is the AKD2G in this system is FS3 (functional safety) whereas the working system is FS1 (STO only). I made the appropriate change in the ethercat pid code.
(That is only the first part of the ethercat-conf.xml file.)
It recognizes the 3 servo drives, but they are all errored.
Can anyone help me determine what is wrong?
[HAL]
TWOPASS=ON
HALFILE = ecat_gantry.hal
loadusr -W lcec_conf ethercat-conf.xml
loadrt lcec
<!--cnc-bg Config -->
<masters>
<master idx="0" appTimePeriod="1000000" refClockSyncCycles="1">
<!-- AKD X Axis (beam) -->
<slave idx="0" type="generic" vid="0000006A" pid="00414b44" configPdos="true">
<!-- Clear SM PDOs -->
<sdoConfig idx="1C12" subIdx="00">
<sdoDataRaw data="00"/>
</sdoConfig>
<sdoConfig idx="1C13" subIdx="00">
</sdoConfig>
<!-- Clear RX PDO1 -->
<sdoConfig idx="1A00" subIdx="00">
</sdoConfig>
<!-- Map status word to RX-PDO1 -->
<!-- 0x6041 0010 -->
<sdoConfig idx="1A00" subIdx="01">
<sdoDataRaw data="10 00 41 60"/>
</sdoConfig>
<!-- Map position feedback to RX-PDO1 -->
<!-- 0x6064 0020 -->
<sdoConfig idx="1A00" subIdx="02">
<sdoDataRaw data="20 00 64 60"/>
</sdoConfig>
<!-- Set RX-PDO1 count to 2 -->
<sdoDataRaw data="02"/>
</sdoConfig>
jim@cnc:~$ ethercat slaves
0 6:0 PREOP E AKD EtherCAT Drive (CoE)
1 6:1 SAFEOP E AKD2G Dual Axis FS3 EtherCAT Drive (CoE)
2 1:0 PREOP E AKD EtherCAT Drive (CoE)
jim@cnc:~$ sudo dmesg | grep EtherCAT
[sudo] password for jim:
[ 4.545203] EtherCAT: Master driver 1.6.2 1.6.2.g285cdf0-1+12.2
[ 4.545268] EtherCAT: 1 master waiting for devices.
[ 4.572786] ec_generic: EtherCAT master generic Ethernet device module 1.6.2 1.6.2.g285cdf0-1+12.2
[ 4.572795] EtherCAT: Accepting 00:1B:21:5A:44:37 as main device for master 0.
[ 4.588476] EtherCAT 0: Starting EtherCAT-IDLE thread.
[ 4.588497] EtherCAT 0: Link state of ecm0 changed to UP.
[ 5.192449] EtherCAT 0: Link state of ecm0 changed to DOWN.
[ 5.240474] EtherCAT 0: Link state of ecm0 changed to UP.
[ 5.264455] EtherCAT 0: 3 slave(s) responding on main device.
[ 5.264458] EtherCAT 0: Slave states on main device: PREOP, SAFEOP + ERROR.
[ 5.265859] EtherCAT 0: Scanning bus.
[ 5.878393] EtherCAT WARNING 0-1: Slave has state error bit set (SAFEOP + ERROR)!
[ 7.657131] EtherCAT ERROR 0-1: Timeout after 1000 ms while waiting for SDO 0x1c12:0 upload response.
[ 7.657134] EtherCAT ERROR 0-1: Failed to read number of assigned PDOs for SM2.
[ 8.657645] EtherCAT ERROR 0-1: Timeout after 1000 ms while waiting for SDO 0x1c13:0 upload response.
[ 8.657647] EtherCAT ERROR 0-1: Failed to read number of assigned PDOs for SM3.
[ 9.267846] EtherCAT 0: Bus scanning completed in 4000 ms.
[ 9.267848] EtherCAT 0: Using slave 0 as DC reference clock.
[ 9.267851] EtherCAT 0: Starting EoE thread.
[ 9.307336] EtherCAT ERROR 0-0: Failed to set SAFEOP state, slave refused state change (PREOP + ERROR).
[ 9.308655] EtherCAT ERROR 0-0: AL status message 0x001D: "Invalid output configuration".
[ 9.310093] EtherCAT 0-0: Acknowledged state PREOP.
[ 9.316500] EtherCAT ERROR 0-1: AL status message 0x001B: "Sync manager watchdog".
[ 9.320634] EtherCAT 0-1: Acknowledged state SAFEOP.
[ 9.372708] EtherCAT ERROR 0-2: Failed to set SAFEOP state, slave refused state change (PREOP + ERROR).
[ 9.374026] EtherCAT ERROR 0-2: AL status message 0x001D: "Invalid output configuration".
[ 9.375463] EtherCAT 0-2: Acknowledged state PREOP.
[ 9.397756] EtherCAT ERROR 0-1: AL status message 0x001B: "Sync manager watchdog".
[ 9.403141] EtherCAT 0-1: Acknowledged state SAFEOP.
[ 9.469755] EtherCAT ERROR 0-1: AL status message 0x001B: "Sync manager watchdog".
[ 9.473818] EtherCAT 0-1: Acknowledged state SAFEOP.
[55800.087042] EtherCAT WARNING 0-1: SDO information error response while fetching SDO entry 0x1C32:0E!
[55800.087045] EtherCAT ERROR 0-1: SDO abort message 0x06090011: "Subindex does not exist".
[55800.089891] EtherCAT WARNING 0-1: SDO information error response while fetching SDO entry 0x1C32:0F!
[55800.089893] EtherCAT ERROR 0-1: SDO abort message 0x06090011: "Subindex does not exist".
[55800.092737] EtherCAT WARNING 0-1: SDO information error response while fetching SDO entry 0x1C32:10!
[55800.092738] EtherCAT ERROR 0-1: SDO abort message 0x06090011: "Subindex does not exist".
[55800.096957] EtherCAT WARNING 0-1: SDO information error response while fetching SDO entry 0x1C32:11!
[55800.096958] EtherCAT ERROR 0-1: SDO abort message 0x06090011: "Subindex does not exist".
[55800.101182] EtherCAT WARNING 0-1: SDO information error response while fetching SDO entry 0x1C32:12!
[55800.101183] EtherCAT ERROR 0-1: SDO abort message 0x06090011: "Subindex does not exist".
Last edit: 1 year 11 months ago by Rkatts.
- endian
- Thank you received: 134
1 year 11 months ago #315415
by endian
Replied by endian on topic Ethercat installation from repositories - how to step by step
Hello,
is the any way to change the network card driver from default generic to my hardware native e1000e when I install ethercat stuff from responsitories please?
thanks regards
thanks regards
- Thank you received: 4153
1 year 11 months ago #315526
etherlab.org/en_GB/ethercat
Replied by rodw on topic Ethercat installation from repositories - how to step by step
I think only the generic driver is supported in the deb install. If you build Ethercat master from sources I think you can build the Intel driver which will give better performance. Check the docs which outlines the build process. Its pretty easy.Hello,
thanks regards
- endian
1 year 11 months ago #315582
by endian
I have built them form the source with
but it has behaviour same same... after
but when I change to
and did
it immediately works
it looks like it does not have disabled generic driver and still using it
./configure --sysconfdir=/etc/ --disable-8139too --enable-userlib --disable-generic --disable-eoe --enable-e1000e
ethercat master
Master0
Phase: Waiting for device(s)...
Active: no
Slaves: 0
Ethernet devices:
Main: 00:01:05:xx:93:xx (waiting...)
Link: DOWN
Tx frames: 0
Tx bytes: 0
Rx frames: 0
Rx bytes: 0
Tx errors: 0
Tx frame rate [1/s]: 0 0 0
Tx rate [KByte/s]: 0.0 0.0 0.0
Rx frame rate [1/s]: 0 0 0
Rx rate [KByte/s]: 0.0 0.0 0.0
DEVICE_MODULES="generic"
sudo systemctl restart ethercat.service
Time to create page: 3.257 seconds
