- Thank you received: 92
Ethercat installation from repositories - how to step by step
- Henk
2 years 1 month ago #310149
by Henk
Replied by Henk on topic Ethercat installation from repositories - how to step by step
HI
A couple of weeks ago i installed a the iso from rodw's google drive, worked fine, no problems.
This time, i tried the one from the downloads page, and also again the google drive one, but i get these errors. I have seen similar errors in this thread, but the sollutions are either not clear or doesnt work for me.
i ran apt update, and also apt upgrade as per the sticky, but these errors appear when i try installing linuxcnc-ethercat. I ran the script from [url] forum.linuxcnc.org/ethercat/53785-instal...-repositories#309963 [/url]
but still get errors as seen below
Any idea how to fix this?
Henk
linuxcnc@linuxcnc:~$ sudo apt install linuxcnc-ethercat
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
The following packages were automatically installed and are no longer required:
linux-headers-6.1.0-23-amd64 linux-headers-6.1.0-23-common
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
autoconf autoconf-archive automake autotools-dev ethercat-dkms ethercat-master libethercat libltdl-dev libtool m4
Suggested packages:
gnu-standards autoconf-doc libtool-doc gfortran | fortran95-compiler gcj-jdk m4-doc
The following NEW packages will be installed:
autoconf autoconf-archive automake autotools-dev ethercat-dkms ethercat-master libethercat libltdl-dev libtool linuxcnc-ethercat m4
0 upgraded, 11 newly installed, 0 to remove and 0 not upgraded.
Need to get 2,415 kB/5,387 kB of archives.
After this operation, 86.6 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Ign:1 http://download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ ethercat-dkms 1.6.1.g419f621-1+8.3
Ign:2 http://download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ ethercat-master 1.6.1.g419f621-1+8.3
Ign:3 http://opensuse.mirror.liquidtelecom.com/repositories/science%3A/EtherLab/Debian_12 ./ linuxcnc-ethercat 1.40.0.g8a607c0-0
Err:1 http://download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ ethercat-dkms 1.6.1.g419f621-1+8.3
Could not connect to opensuse.mirror.liquidtelecom.com:80 (2c0f:fe40:8001:10::1). - connect (101: Network is unreachable) Could not connect to opensuse.mirror.liquidtelecom.com:80 (197.155.77.1), connection timed out
Err:2 http://download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ ethercat-master 1.6.1.g419f621-1+8.3
Unable to connect to opensuse.mirror.liquidtelecom.com:http:
Err:3 http://opensuse.mirror.liquidtelecom.com/repositories/science%3A/EtherLab/Debian_12 ./ linuxcnc-ethercat 1.40.0.g8a607c0-0
E: Failed to fetch http://opensuse.mirror.liquidtelecom.com/repositories/science%3A/EtherLab/Debian_12/all/ethercat-dkms_1.6.1.g419f621-1%2B8.3_all.deb Could not connect to opensuse.mirror.liquidtelecom.com:80 (2c0f:fe40:8001:10::1). - connect (101: Network is unreachable) Could not connect to opensuse.mirror.liquidtelecom.com:80 (197.155.77.1), connection timed out
E: Failed to fetch http://opensuse.mirror.liquidtelecom.com/repositories/science%3A/EtherLab/Debian_12/amd64/ethercat-master_1.6.1.g419f621-1%2B8.3_amd64.deb Unable to connect to opensuse.mirror.liquidtelecom.com:http:
E: Failed to fetch http://opensuse.mirror.liquidtelecom.com/repositories/science%3A/EtherLab/Debian_12/amd64/linuxcnc-ethercat_1.40.0.g8a607c0-0_amd64.deb Unable to connect to opensuse.mirror.liquidtelecom.com:http:
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
E: Conflicting values set for option Signed-By regarding source http://download.opensuse.org/repositories/science:/EtherLab/Debian_12/ ./: /etc/apt/trusted.gpg.d/science_EtherLab.gpg != /etc/apt/trusted.gpg.d/science_EtherLab.gpg.key.binary.gpg
E: The list of sources could not be read.
Henk
- bertoldo
2 years 1 month ago #310249
by bertoldo
Replied by bertoldo on topic Ethercat installation from repositories - how to step by step
hello dear.
try it.
'unistall chave gpg
sudo rm /etc/apt/trusted.gpg.d/science_EtherLab.gpg
sudo rm /etc/apt/trusted.gpg.d/science_EtherLab.gpg.key.binary.gpg
'reinstall it
wget -O - download.opensuse.org/repositories/scien...ebian_12/Release.key | sudo apt-key add -
'update
sudo apt update
'install again
try it.
'unistall chave gpg
'reinstall it
'update
sudo apt update
'install again
- AndyDM01
2 years 1 month ago #310277
by AndyDM01
Replied by AndyDM01 on topic Ethercat installation from repositories - how to step by step
so I got stuck, still can't get any movement , and yes i tried everything , someone please explain what are the basics to get an operational system...
from absolute zero ... in what order to do stuff ... i am sure i did something wrong and just got stuck so i will restart from zero but ... please please please someone can tell me the order to do stuff ... i just erased everything from the harddisk and have option to start from zero ...
- bertoldo
2 years 1 month ago #310281
by bertoldo
hello!
I went through this too! I'm finishing a document with files... very neatly so there are no doubts... when I finish I'll post it here
- Henk
2 years 1 month ago #310325
by Henk
HI bertoldo
It doesnt work.
also when i try to update i get the following
It doesnt work.
linuxcnc@linuxcnc:~$ wget -O - download.opensuse.org/repositories/scien...ebian_12/Release.key | sudo apt-key add -
--2024-09-17 19:36:19-- http://download.opensuse.org/repositories/scien...ebian_12/Release.key
Resolving download.opensuse.org (download.opensuse.org)... 195.135.223.226, 2a07:de40:b250:131:10:151:131:30
Connecting to download.opensuse.org (download.opensuse.org)|195.135.223.226|:80... Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
connected.
HTTP request sent, awaiting response... 404 Not Found
2024-09-17 19:36:20 ERROR 404: Not Found.
gpg: no valid OpenPGP data found.
linuxcnc@linuxcnc:~$ sudo apt update
- AndyDM01
2 years 1 month ago #310339
by AndyDM01
just some basic guidelines to get into the ethercat side off linuxcnc would mean a lot to the noobs
Time to create page: 0.216 seconds
