Ethercat installation from repositories - how to step by step
2 years 1 month ago - 2 years 1 month ago #309936 by bertoldo
"Ethercat should be running. If the above command is not found, you have a problem
You can list the slaves if you type
ethercat slaves"
So far I found the servo everything fine... but then it didn't go, from my understanding there is no lcec_conf file...
raspberrypi4b 8 giga, servo ethercat I will add a xml of the drive too
File Name: LC10EV1.041.xml
File Size:735 KB
Last edit: 2 years 1 month ago by bertoldo.
2 years 1 month ago #309962 by rodw
Sometimes the path needs modifying in the hal file where you load the ethercat driver. You need to share the errors printed in the console when you start linuxcnc from the command line for anybody to help
2 years 1 month ago #309997 by bertoldo
Mine doesn't give any errors. It's just that I don't know how to configure it in Linux CNC.
After my run I'll make a video from start to finish and a manual to post here for those who have never opened Linux CNC.
I open Linux CNC and press to move the axes and the software acts as if everything is fine, but it's not. In fact, I've started the trial and error phase... I'm disoriented :)
2 years 1 month ago #310011 by jjdege
I'm disoriented :)
look here it might give you a starting point
The following user(s) said Thank You: bertoldo
2 years 1 month ago #310018 by bertoldo
seems to be exactly where I am at the moment...
2 years 1 month ago #310032 by jjdege
sorry,
here they say that the drivers are OP and the engines move,
you're on the right track then
Time to create page: 0.479 seconds
