Ethercat installation from repositories - how to step by step
2 years 2 months ago - 2 years 2 months ago #307916 by elovalvo
hi
here is the report with uname -v
no RT, yet it works, something went wrong
which kernel is working?
If you want instructions to create a PREEMPT_RT for Raspberry Pi 5 with native Raspberry OS you can see at this link
forum.linuxcnc.org/9-installing-linuxcnc...pi-5?start=40#303696
or use the ready-made image you find here
forum.linuxcnc.org/9-installing-linuxcnc...pi-5?start=40#303752
Then follow the procedures already described for Ethercat drivers
Last edit: 2 years 2 months ago by elovalvo.
The following user(s) said Thank You: jjdege
2 years 2 months ago #307934 by tommylight
Latency is OK, so the kernel should work just fine.
No idea if it works for EtherCAT though, although in general should work if the same headers are used.
2 years 2 months ago #307956 by jjdege
Thanks so much!
in the meantime
i tried to understand what went wrong and i found the reason,
i skipped a step in menuconfig
with that step the compilation of the RT kernel was successful
the latency is now very ok
unlike the installation of the EtherCAT packages that gives me an error
i don't know what it depends on, maybe we need to wait for Etherlab to update the repositories
2 years 2 months ago #307971 by tommylight
Try installing those one by one.
2 years 2 months ago - 2 years 2 months ago #307992 by elovalvo
Thanks so much!
forum.linuxcnc.org/9-installing-linuxcnc...i-5?start=220#306099
2 years 2 months ago #307998 by jjdege
hi
Thanks @tommylight and @elovalvo
these are two paths that I have already taken without success
the headers for the kernerl 6.6.45-rt39-v8-16k are not found.
Now I'm going away for a few days, when I come back we'll see
thanks a lot
Time to create page: 0.566 seconds
