- Thank you received: 4153
Ethercat installation from repositories - how to step by step
- Shemmers
- Visitor
2 years 2 months ago - 2 years 2 months ago #307410
by Shemmers
Replied by Shemmers on topic Ethercat installation from repositories - how to step by step
Hi Rodw, Thanks for all the incredible work so far on EtherCAT. I'm diving into both LinuxCNC and EtherCAT right now and excited by the possibilities.
I ran into the same issues as discussed. I tried your script on the Rpi 5 and it seemed to connect to their servers but it only seems to have grabbed 733 bytes. I may try some of the other methods mentioned previously.
___
System: Raspberry pi 5 + Leadshine EL8 EtherCAT drives
LinuxCNC level: first timer
Linux level: noob noob
___
Last edit: 2 years 2 months ago by Shemmers.
2 years 2 months ago #307434
Replied by rodw on topic Ethercat installation from repositories - how to step by step
The script just adds the Ethercat repositories/
Just folllw the steps in post 1 to install Ethercat.
- abdulasis12
- Thank you received: 8
2 years 2 months ago #307482
by abdulasis12
No. 59 right ?
link sent back your first post
Replied by abdulasis12 on topic Ethercat installation from repositories - how to step by step
Refer here. Please restrict this thread to Ethercat installation only
docs.google.com/document/d/1jeV_4VKzVmOI...diY/edit?usp=sharing
No. 59 right ?
- AndyDM01
2 years 2 months ago #307496
by AndyDM01
Replied by AndyDM01 on topic Ethercat installation from repositories - how to step by step
so far so good, got the first signs that the software is working ok on the first machine I have to retrofit, thank you to everyone for contributing... I think i really used something from everyone and I will ofcourse due time post my own track to the walhala of linuxcnc when i get to the point of managable cnc machine under total control (for all 3 machines !) ... if i don't die from carpal-syndrome , haven't typed this much since i left the plc/automation world
- AndyDM01
2 years 2 months ago - 2 years 2 months ago #307497
by AndyDM01
Last edit: 2 years 2 months ago by AndyDM01.
- mehdidadash
2 years 2 months ago #307618
by mehdidadash
Replied by mehdidadash on topic Ethercat installation from repositories - how to step by step
hi
i have upgrdded my kernel to 6.1.0-23-rt-amd64 from 6.1.0-13-rt-amd64
since then, i have to remove ethercat-dkms libethercat libethercat-dev ethercat-master and reinstall them and linuxcnc-ethercat on every boot
i have followed post 1 of this thread completely .
this is error code when i want to start linuxcnc
"Failed to open /dev/EtherCAT0: No such file or directory"
Time to create page: 0.427 seconds
