- Thank you received: 4153
Ethercat installation from repositories - how to step by step
2 years 2 months ago #308063
Replied by rodw on topic Ethercat installation from repositories - how to step by step
If you compile a custom kernel or build an ISO or image, the headers are not going to be in the repositories.
They are built with the kernel. If you don't save or install them, you will need to build them again.
The 2.9.3 isos and images do all of this for you.
Your posts have nothing to do with installing ethercat from repositories, so please ask further questions on another thread.
The following user(s) said Thank You: jjdege
- AndyDM01
2 years 2 months ago - 2 years 2 months ago #308229
by AndyDM01
Replied by AndyDM01 on topic Ethercat installation from repositories - how to step by step
so, the moment of victory was very short. i followed the instructions to the letter, did some corrections when needed and had the first signs of a lcnc-ethercat system coming alive (that was last week) yesterday i wanted to continue but i only got the error screen from linuxcnc telling me that it closed down because some pin doesn't exist ... cia402 pin... wanted to share xml and hal and ini and screenshot but after writing the reply at work with all attachments ... it refused to submit... waited half hour to submit... nothing happened.
so, here's what i have for hardware :
1 rtec IO 1616
1 rtec ECR86 for X
1rtec ECR86 for Y
2 wantai nema 34 steppers (60V-3.5Amp) {these steppers eat almost 6 amps in real-life}
had every sign that the install was complete last week ... saw a lot of lcec pins in the halmeter. actually was able to turn on an output on the IO card. yesterday nothing . no lcec pins, only error screen about this cia402 pin does not exist...
of course i already tried to do everything possible ... reload this, reconfig that, recompile this... for some reason i can't the lcec pins back like i had last week...
1 rtec IO 1616
1 rtec ECR86 for X
1rtec ECR86 for Y
Last edit: 2 years 2 months ago by AndyDM01.
2 years 2 months ago #308354
Start linuxcnc from the command line, read the error about the missing pin. It probably tells you the line number. Comment it out until Linuxcnc starts and review halshow to get the right spelling/pin name. This is just basic trouble shooting, not ethercat related.
linuxcnc -l
is a very handy command (Lower case -L)
linuxcnc -l
- seyad
2 years 2 months ago #308379
by seyad
Replied by seyad on topic Ethercat installation from repositories - how to step by step
2 years 2 months ago - 2 years 2 months ago #308381
Can you try this image?
drive.google.com/file/d/1HBXliMQE-OvU0PQ...O5K/view?usp=sharing
Its the one I sent to Linuxcnc but maybe they have not updated. This shoulld work
Last edit: 2 years 2 months ago by rodw.
- seyad
2 years 2 months ago #308440
by seyad
Thank you. yeah its working now . But it doesn't contain ethercat in it, is it..?
Time to create page: 0.205 seconds
