- Thank you received: 4153
Ethercat installation from repositories - how to step by step
2 years 2 months ago #307276
Replied by rodw on topic Ethercat installation from repositories - how to step by step
The Raspberry pi images do not include the Ethercat repositories but enabling some commented out code should enable it according to feedback from etherlabmaster
Try running a script something like this
#!/bin/bash
# Install companion repositories. NOTE: QTPYVCP does not support the raspberry pi.
echo "Install ethercat repository"
mkdir -p /usr/local/share/keyrings/
wget -O- https://build.opensuse.org/projects/science:EtherLab/signing_keys/download?kind=gpg | gpg --dearmor | dd of=/etc/apt/trusted.gpg.d/science_EtherLab.gpg
tee -a /etc/apt/sources.list.d/ighvh.sources > /dev/null <<EOT
Types: deb
Signed-By: /etc/apt/trusted.gpg.d/science_EtherLab.gpg
Suites: ./
URIs: http://download.opensuse.org/repositories/science:/EtherLab/Debian_12/
EOT
The following user(s) said Thank You: Moutomation, Macwolf
2 years 2 months ago #307277
yes tested it works on my chromebook so it should work on any device Ethercat supports. Shame it does not have an Ethernet port
copy text to a file. call it ethinstall.sh and make it executable:
chmod +x ethinstall.sh
./ethinstall.sh
- Henk
- Thank you received: 92
2 years 2 months ago #307362
by Henk
Replied by Henk on topic Ethercat installation from repositories - how to step by step
HI
Firstly, thank you very much for this outstanding work. I have installed from the ISO provided, no errors, works as intended.
I was not planning to use Ethercat, but when i bought new drives for one of my machines, i forgot to specify that i want an analog interface, so they supplied Ethercat drives...so i figured i would give it a go, and i am pleased with the result
I have a PC with 2 network adaptors, and i managed to set up a Mesa 7i92 on the other port, which works, but im having "error finishing read" issues. Im told that this is a known issue with Debian 12 and Realtec NIC's. Will search on the forum for a sollution, though i am pleased with the result so fat.
Thanks again for the effort
Henk
Henk
- abdulasis12
- Thank you received: 8
2 years 2 months ago #307370
by abdulasis12
I have question
Because my PC a lot setup for 7i73 mattrixkey sendkey for setup in debian (permission) ,If I go to D/L .ISO and reinstall , I must go to setup all again, and not sure I can do it working again or not.
Can you share any solution for fix this error about DKMS and don't need to reinstall with .ISO ?
Replied by abdulasis12 on topic Ethercat installation from repositories - how to step by step
Hi MR.RODWNow fixed. They had a bug in the DKMS deb files. Grab this Linuxcnc ISO which has the new keys in it.
ISO: drive.google.com/file/d/1gEQzgHsj_LjHiGB...k1Z/view?usp=sharing
Folder with all generated files: drive.google.com/drive/folders/1pwDh_jn8...QcQwcLv7?usp=sharing
This ISO also corrects installing a pre-release version of Linuxcnc and no installs 2.93 as intended.
I have asked the devs to copy this ISO to the downloads page.
I have question
- Moutomation
- Thank you received: 11
2 years 2 months ago #307378
by Moutomation
Replied by Moutomation on topic Ethercat installation from repositories - how to step by step
Make a new and clean installation on another computer, do not touch the existing computer. If you can run it on a new computer, reinstall it on your existing computer.
2 years 2 months ago #307388
docs.google.com/document/d/1jeV_4VKzVmOI...diY/edit?usp=sharing
Refer here. Please restrict this thread to Ethercat installation onlyCan you share any solution for fix this error about DKMS and don't need to reinstall with .ISO ?
The following user(s) said Thank You: abdulasis12
Time to create page: 0.461 seconds
