Ethercat installation from repositories - how to step by step
2 years 2 months ago #307624 by rodw
Seems like the udev rules part of the instructions need redoing
2 years 2 months ago #307634 by mehdidadash
if you mean this, "sudo udevadm control --reload-rules" , i have done it
also this one
sudo geany /etc/udev/rules.d/99-ethercat.rules
KERNEL=="EtherCAT[0-9]", MODE="0777"
2 years 2 months ago #307790 by Ahmo
Are they making some updates on ethercat right now? Because when I try to install it it says that it cant fetch some files, I checked and the files that he is searching are version 1.5.2. but the files on repository are version 1.6.1. these files are changed 15 days ago so I was wondering do you now how long will it take for them to fix that?
2 years 2 months ago #307794 by rodw
1.6 is the current ethercat version.
2 years 2 months ago #307883 by Moutomation
Where am I making a mistake? The installation gives an error.
cnc@raspberrypi:~/Desktop$ ./ethinstall.sh
Install ethercat repository
dd: failed to open '/etc/apt/trusted.gpg.d/science_EtherLab.gpg': Permission denied
--2024-08-16 15:33:59-- build.opensuse.org/projects/science:Ethe...ys/download?kind=gpg
Resolving build.opensuse.org (build.opensuse.org)... 195.135.223.221, 2a07:de40:b250:131:10:151:131:20
Connecting to build.opensuse.org (build.opensuse.org)|195.135.223.221|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: unspecified [application/octet-stream]
Saving to: ‘STDOUT’
- [ <=> ] 1.08K --.-KB/s in 0s
2024-08-16 15:33:59 (11.7 MB/s) - written to stdout [1109]
gpg: [stdout]: write error: Broken pipe
gpg: filter_flush failed on close: Broken pipe
tee: /etc/apt/sources.list.d/ighvh.sources: Permission denied
2 years 2 months ago #307888 by rodw
looks like you need you use sudo sudo su before running the script
The following user(s) said Thank You: Moutomation
Time to create page: 0.807 seconds
