Ethercat installation from repositories - how to step by step
2 years 2 months ago #308511 by rodw
yes should have ethercat repos set up so follow the sticky
2 years 2 months ago - 2 years 2 months ago #308537 by Sandro
Hello everyone
I am getting the same error with a new install of LCNC 2.9.3 on amd64. (Also affects my 2.9.2 install)
sudo apt update
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ InRelease: The following signatures were invalid: EXPKEYSIG A94819A7CB97A204 science:EtherLab OBS Project
W: Failed to fetch download.opensuse.org/repositories/scien...ebian_12/./InRelease   The following signatures were invalid: EXPKEYSIG A94819A7CB97A204 science:EtherLab OBS Project
W: Some index files failed to download. They have been ignored, or old ones used instead.
sudo apt install  linuxcnc-ethercat
[code]E: Failed to fetch download.opensuse.org/repositories/scien...0bca-1%2b3.1_all.deb   404  Not Found [IP: 195.135.223.226 80]
E: Failed to fetch download.opensuse.org/repositories/scien...ca-1%2b3.1_amd64.deb   404  Not Found [IP: 195.135.223.226 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Etherlab repository not valid anymore? Any ideas?
Edit: I have found rods image here which works:
drive.google.com/file/d/1gEQzgHsj_LjHiGB...k1Z/view?usp=sharing[/url
Last edit: 2 years 2 months ago by Sandro.
2 years 2 months ago #308552 by zmrdko
Hi Rod,
I followed these instructions several times  and, everything worked perfectly. Tried to install today and I get an error saying that no public key is available. Any idea if something has something changed? This is a fresh install of the Debian buster Linuxcnc iso.
Kind regards,
Dan
run this:
sudo mkdir -p /usr/local/share/keyrings/ wget -O- https://build.opensuse.org/projects/science:EtherLab/signing_keys/download?kind=gpg | gpg --dearmor | sudo dd of=/etc/apt/trusted.gpg.d/science_EtherLab.gpg sudo tee -a /etc/apt/sources.list.d/ighvh.sources > /dev/null <<EOT Types: deb Signed-By: /etc/apt/trusted.gpg.d/science_EtherLab.gpg Suites: ./ URIs: http://download.opensuse.org/repositories/science:/EtherLab/Debian_12/ EOT sudo apt update sudo apt install -y linux-headers-$(uname -r) ethercat-master linuxcnc-ethercat
2 years 2 months ago #308661 by seyad
 I am using your recent image only but i con't able to intall ethercat -master following this
2 years 2 months ago #308666 by rodw
The following user(s) said Thank You: seyad
2 years 2 months ago - 2 years 2 months ago #308684 by seyad
how can i resolve it..?when i  try to download manualy but it is shows 404 page not found
Last edit: 2 years 2 months ago by seyad.
Time to create page: 0.848 seconds
