Ethercat installation from repositories - how to step by step
- Macwolf
2 years 2 weeks ago #311846
by Macwolf
Replied by Macwolf on topic Ethercat installation from repositories - how to step by step
it works fine on my Raspberry 5 after a clean install
Master0
Phase: Idle
Active: no
Slaves: 0
Ethernet devices:
Main: 2c:cf:67:15:58:57 (attached)
Link: UP
Tx frames: 22305
Tx bytes: 1338300
Rx frames: 0
Rx bytes: 0
Tx errors: 0
Tx frame rate [1/s]: 125 125 118
Tx rate [KByte/s]: 7.3 7.3 6.9
Rx frame rate [1/s]: 0 0 0
Rx rate [KByte/s]: 0.0 0.0 0.0
Common:
Tx frames: 22305
Tx bytes: 1338300
Rx frames: 0
Rx bytes: 0
Lost frames: 22305
Loss rate [1/s]: 125 125 118
Frame loss [%]: 100.0 100.0 100.0
Distributed clocks:
Reference clock: None
DC reference time: 0
Application time: 0
2000-01-01 00:00:00.000000000
Master0
Phase: Idle
Active: no
Slaves: 0
Ethernet devices:
Link: UP
Tx frames: 22305
Tx bytes: 1338300
Rx frames: 0
Rx bytes: 0
Tx errors: 0
Common:
Tx frames: 22305
Tx bytes: 1338300
Rx frames: 0
Rx bytes: 0
Lost frames: 22305
Distributed clocks:
Application time: 0
- Thank you received: 4153
2 years 2 weeks ago #311856
Replied by rodw on topic Ethercat installation from repositories - how to step by step
There is another sticky to fix the expired security key
forum.linuxcnc.org/ethercat/53785-instal...repositories?start=0
- Macwolf
2 years 2 weeks ago - 2 years 2 weeks ago #312345
by Macwolf
Since I am new to the topic of Ethercat, here is another question. I have now installed a servo( As715N) in my test series, but what is it written as in the ethercat-conf.xml
<master idx="0" appTimePeriod="1000000" refClockSyncCycles="-1">
<slave idx="1" type="EK1100"/>
<slave idx="2" type="EL1008"/>
<slave idx="3" type="EL2008"/>
<slave idx="4" type="AS715N"/>
is that right?
is that right?
Last edit: 2 years 2 weeks ago by Macwolf.
- AndyDM01
1 year 11 months ago - 1 year 11 months ago #313758
by AndyDM01
Replied by AndyDM01 on topic Ethercat installation from repositories - how to step by step
I would like to know what steps to take to have qtplasmac gui to work with ethercat
not trying to be lazy, just trying to avoid another 3 months delay because I could not get my ECR86 drivers to work.
rtelligent service actually helped me out and I finally had the axis moving...
I took notes of everything and I will post my findings here ...
Last edit: 1 year 11 months ago by AndyDM01.
1 year 11 months ago #313787
I would probably get a working xyz Ethercat config with axis.
Then I would use pncconf to build a qtplasmac config then merge them together by hand
You will need to work out how to sense torch voltage. I would look for an Ethercat module that sensed analog voltage.
This has been done in the past but it was before QTplasmac.
The following user(s) said Thank You: AndyDM01
- furkanuzal
1 year 11 months ago #313960
by furkanuzal
Replied by furkanuzal on topic Ethercat installation from repositories - how to step by step
Hello. I installed ethercat following all the instructions. I can see my servo motors. But I can't do anything else. I cannot create the lcec.conf file. Please can you help? (I can't find a clear source because I use Google translate)
Time to create page: 0.206 seconds
