EtherCAT driver for a 6 axis robot
20 Jul 2022 11:05 - 20 Jul 2022 11:14 #247830 by ftree
Replied by ftree on topic EtherCAT driver for a 6 axis robot
I believe I may need to look at "immediate homing" for the Meca500 if the robot provides its own homing mechanisms.  Thoughts?
SEARCH_VEL = 0
LATCH_VEL = 0
USE_INDEX = NO
HOME_SEQUENCE = 0
#homing
net a1-home-index <= joint.0.index-enable => lcec.0.Meca500.status.homed
net a2-home-index <= joint.1.index-enable => lcec.0.Meca500.status.homed
net a3-home-index <= joint.2.index-enable => lcec.0.Meca500.status.homed
net a4-home-index <= joint.3.index-enable => lcec.0.Meca500.status.homed
net a5-home-index <= joint.4.index-enable => lcec.0.Meca500.status.homed
net a6-home-index <= joint.5.index-enable => lcec.0.Meca500.status.homed
Last edit: 20 Jul 2022 11:14 by ftree.
20 Jul 2022 12:06 #247837 by ftree
db1981 Are you suggesting a comp "glue" layer similar to
github.com/dbraun1981/hal-cia402/blob/main/cia402.comp
20 Jul 2022 14:16 #247849 by ftree
20 Jul 2022 18:11 #247867 by db1981
Replied by db1981 on topic EtherCAT driver for a 6 axis robot
yes, similar to this but only for the robots complete control pins and the axis enables...
21 Jul 2022 09:14 #247922 by db1981
oh, i have not noticed a few of the last posts.
-initial values would be set with the inital data at variable initialization in c.
I don't know if this is practicable in the whole system but my way of implementation would be:
safty chain (estop btn, power_on btn implemented in Hardware)
estop case : ctrl.deactivate = 1; motion.set-point 0
safty chain on (estop disabled) :
-ctrl.deactivate = 0;ctrl.activate = 1
-wait for status.activated -> set ctrl.home
-wait for status.homed -> reset ctrl.home, at this moment in time first set emc-enable-in true (the power on btn in gui will gets accesable)
-now set this
setp lcec.0.Meca500.vel-command 21
setp lcec.0.Meca500.motion.set-point 1
setp lcec.0.Meca500.motion.move-id 0
for lcnc homing use absolute encoders...
21 Jul 2022 10:55 #247928 by ftree
21 Jul 2022 11:06 #247929 by ftree
This is where my experience and knowlege of the workings of lcnc falls off a cliff.  If you're available for contract work let me know.  The resulting work would be open source.
21 Jul 2022 11:26 - 21 Jul 2022 11:26 #247931 by ftree
Would you also check for the robot existence on the EtherCAT bus as part of the safety chain?
lcec.0.Meca500.slave-online
lcec.0.Meca500.slave-oper
lcec.0.Meca500.slave-state-op
lcec.0.Meca500.slave-state-preop
lcec.0.Meca500.slave-state-safeop
Last edit: 21 Jul 2022 11:26 by ftree.
21 Jul 2022 13:30 - 21 Jul 2022 13:35 #247938 by db1981
yes, checking the whole ec-bus is an good thing.
this is a part from out standart safty/error handling comp, this comp works together with the safty-plc in the cabinet.
ec_slaves_responding_ok = (ec_slaves_responding == ec_slaves);
if (!ec_slaves_responding_ok) {
  emc_enable_out = 0;
  if (data.last_ec_slaves_responding_ok) {
    rtapi_print_msg(RTAPI_MSG_ERR, "EtherCAT: Not all %d slaves responding!\n",    ec_slaves);
data.last_ec_slaves_responding_ok = ec_slaves_responding_ok;
if (!ec_link_up) {
  emc_enable_out = 0;
  if (data.last_ec_link_up) {
    rtapi_print_msg(RTAPI_MSG_ERR, "EtherCAT: Link down!\n");
data.last_ec_link_up = ec_link_up;
if (!ec_all_op) {
  emc_enable_out = 0;
  if (data.last_ec_all_op)
  {rtapi_print_msg(RTAPI_MSG_ERR, "EtherCAT: Not all slaves in OP mode!\n");
data.last_ec_all_op = ec_all_op;
Last edit: 21 Jul 2022 13:35 by db1981. Reason: hating windows formatting
21 Jul 2022 13:40 #247940 by db1981
[quote]I don't know if this is practicable in the whole system but my way of implementation would be:[/quote]
with whole system, i am thinking about the safty regulations, hardware design of the complete machine.
this is my daily business, which country you are living?
Time to create page: 0.222 seconds
