Problems with Lichuan Ethercat servo drive
1 year 3 months ago #331806 by MaxEkb77
I use abs position, when set to zero i reset encoder multiturn position.
If you need a ini setup for abs, late copy this side a config.
1 year 3 months ago #331828 by stirra
I was hoping @tar_san could post his files, as he indicates he got homing with external limit and origin switches working. I had thought I had homing figured out back in January, but discovered it was only working for Z index pulse homing, not external switch homing. I then had to set the project aside for six months due to a high priority consulting project, and am back on my LCNC ethercat quest again.
-- Ralph
1 year 3 months ago #331841 by stirra
Actually, now that I have done more testing and fixed on issue in my ini file (had HOME_SEQUENCE=1 for all joints instead of 0), my original instructions at forum.linuxcnc.org/ethercat/54908-missin...-homing-lc10e#318671 appear to work correctly for homing LC10E drive with an external home switch on DI2.
-- Ralph
1 year 3 months ago #331848 by MaxEkb77
You can make "no encoder reset" & use standart linuxcnc homing procedure
1 year 3 months ago #331871 by tar_san
Hello.
I had to recreate LC10 homing code from zero reading manual designated for a driver with a motor with incremental encoder . ( I thought original code was difficult to fix )
If you still have some problems, I consider to open my codes...( I have something to do for some improvement )
1 year 3 months ago #331895 by mra7768
Hi, I’d like to ask — which version of LinuxCNC and kernel are you currently running?
Time to create page: 0.189 seconds
