Problems with Lichuan Ethercat servo drive
- Sandro
- Thank you received: 38
04 May 2024 08:33 - 04 May 2024 15:08 #299692
by Sandro
Replied by Sandro on topic Problems with Lichuan Ethercat servo drive
Thank you for helping us out scott!
This is what ethercat pdos looks like after power-cycling (ethercat_pdos.txt) and ethercat pdos after LCNC start and subsequent shutdown (ethercat_pdos_after_startup.txt). I have also attached the XML file I am currently using.
Last edit: 04 May 2024 15:08 by Sandro.
- scottlaird
- Thank you received: 161
04 May 2024 17:12 #299741
by scottlaird
Replied by scottlaird on topic Problems with Lichuan Ethercat servo drive
Thanks. Nothing leaps out at me here, although I'm not sure that the DC config is right. To verify that, I need the ESI file for the LC10E. Failing that, the information *might* be in the LC10E manual.
This is surprisingly difficult to find. servo.xlichuan.com shows up on Google but doesn't list the LC10E or anything similar. Aliexpress has a broken link to www.lichuanservomotor.com/; cutting and pasting that shows "Ethercat AC Serco Motor kit" listings that show the LC10E (and have images labeled "LC10E") but don't actually use the term "LC10E" in text anywhere.
Searching Google a bit more turns up aqtronic.com/wp-content/uploads/2023/10/...manual-A5-driver.pdf, which says that it's the LC10 (non-E) manual, but has "A5" in the description. Looking at the Lichuan A5 on their website shows that it's *also* called the LC10, and that it comes in two flavors, the LC10P and LC10E. But that's in an image, so you can't search for it. Of course. The A5 manual is more or less identical to the one linked above. It says that there's an EtherCAT version, but provides no information whatsoever about EtherCAT beyond that. No SDO info, etc.
I *think* this is a new product for them; they posted about it on Youtube and Facebook in late April, so maybe the English-language manual is still waiting for translation? I'll poke at their FB page and see how helpful they are.
- Sandro
04 May 2024 19:24 - 04 May 2024 21:40 #299748
by Sandro
I have created a folder which contains the user manual which I have received from Lichuan as well as the XML-File provided (LC10E V1.04_slave_description_source_lichuan.xml). I have also generated a slave description XML after power-cycling with the "ethercat xml" command (LC10E_slave_description). From the XML provided by Lichuan I took a screenshot from the DC section.
drive.google.com/drive/folders/1tk1QHigm...g8cWkT_b?usp=sharing
Last edit: 04 May 2024 21:40 by Sandro.
- pippin88
- Thank you received: 51
04 May 2024 22:40 #299757
by pippin88
Replied by pippin88 on topic Problems with Lichuan Ethercat servo drive
The LC10E / A5 Ethercat manual is not on their website as far as I could find.
They emailed me a copy. I have put it, and the XML file they sent me on OneDrive:
1drv.ms/f/s!Ag2mbb7kEO9giLxzBJsl1sAU7TO8FA?e=Ch5iFU
- drboeller
04 May 2024 23:34 - 05 May 2024 19:49 #299768
by drboeller
Replied by drboeller on topic Problems with Lichuan Ethercat servo drive
After powerup i got the same "ethercat pdos" as Sandro.
After starting linuxcnc i got:seems that the pdo mapping failes. I used exactly the files from trisa25.
M2: PhysAddr 0x1200, DefaultSize 0, ControlRegister 0x64, Enable 1
RxPDO 0x1600 ""
PDO entry 0x6040:00, 16 bit, ""
PDO entry 0x6060:00, 8 bit, ""
PDO entry 0x607a:00, 32 bit, ""
SM3: PhysAddr 0x1300, DefaultSize 0, ControlRegister 0x20, Enable 1
TxPDO 0x1a00 "1st transmit PDO Mapping"
PDO entry 0x6041:00, 16 bit, ""
PDO entry 0x6061:00, 8 bit, ""
PDO entry 0x6064:00, 32 bit, ""
Last edit: 05 May 2024 19:49 by drboeller.
- vre
- Thank you received: 17
07 May 2024 02:25 - 07 May 2024 06:24 #299995
by vre
Replied by vre on topic Problems with Lichuan Ethercat servo drive
I plan to get this www.aliexpress.com/item/1005006702584930.html
Has anyone success with this driver ?
The motor seems too small to be 1kw has anyone measured the power because seems from size overrated...
Last edit: 07 May 2024 06:24 by vre.
- kiwiscanfly
07 May 2024 10:54 #300028
by kiwiscanfly
Replied by kiwiscanfly on topic Problems with Lichuan Ethercat servo drive
I'm rather keen to hear how these units worked out and if they are worth it over a more regular closed system stepper... I was looking at the dual 750w motor for a full sheet CNC Rack and Pinion .
- drboeller
07 May 2024 13:49 #300037
by drboeller
I have the 200w version. For about 150$, its awesome. Of course its not comparable to a yaskawa or other 1000$+ servos, it doesnt come with a pc software for tuning etc. No autotuning.
Struggling with ethercat+linuxcnc atm. Under Windows with TwinCAT the servo worked well.
- burnie
- Thank you received: 13
09 May 2024 02:01 #300177
by burnie
Replied by burnie on topic Problems with Lichuan Ethercat servo drive
My contact at Lichuan sent me the Windows program for configuring the driver, My servos just arrived yesterday, so I haven't tried it.
- drboeller
10 May 2024 10:00 #300300
by drboeller
I configured the pdo´s in twincat, started linuxcnc and got the same error messages as in the last post.Then unplugged the ethernet cable and put it back in while linuxcnc was loading and it worked! Servopack had OP status and i was able to control the servo and see the position via linuxcnc with the files from trisa25. So there is no problem with the files he provided.
ts a problem with the synchronisation maybe? But cant reproduce it atm.
The following user(s) said Thank You: Sandro, burnie
Time to create page: 0.655 seconds
