Problems with Lichuan Ethercat servo drive
- NickH
- Thank you received: 4
01 Jul 2024 15:05 #304165
by NickH
Replied by NickH on topic Problems with Lichuan Ethercat servo drive
Another subscribing...
Sorry ihavenofish, no progress to report. I will the moment I get something running.
I have however just ordered 4* 400w and a 1Kw for a hobby mill conversion, presently in transit.
Latest manual, sent by Annie at Lichuan.
EtherCAT LC10E driver manual: i.trade-cloud.com.cn/upload/7257/20240509164719885295.pdf
- ihavenofish
- Thank you received: 286
01 Jul 2024 17:06 - 01 Jul 2024 19:08 #304171
by ihavenofish
Replied by ihavenofish on topic Problems with Lichuan Ethercat servo drive
cool thanks
Where did you buy form? i see 2 aliexpress stores with slightly different prices claiming to be them. I contacted through the website.
(edit, it seems they have 2 legit reps, each operating somewhat independently,)
Last edit: 01 Jul 2024 19:08 by ihavenofish.
- NickH
01 Jul 2024 20:20 #304174
by NickH
@Nofish, from here: www.aliexpress.com/store/1907567?spm=a2g...in.93.50f31802aywbrJ
Annie will help, and if you ask she will also adjust the somewhat high shipping fees. This resulted in a very worthwhile discount.
- ihavenofish
01 Jul 2024 21:18 #304177
by ihavenofish
i contacted the website directly and the price was much less. Thats why i'm a bit cautious here. But it looks like annie and sharon are both listed on the website.
Bleh haha.
Bleh haha.
- Robbbbbb
- Thank you received: 6
01 Jul 2024 23:09 #304179
by Robbbbbb
Replied by Robbbbbb on topic Problems with Lichuan Ethercat servo drive
I've got a 750w with absolute encoder and brake for my Z axis (RF45 clone). Anyone tried setting the sync mode manually in the HAL file? Or can we set it using ethercat directly in a bash script before starting linuxcnc? I plan to give this a go at some point to see if it gets around our startup issue. (Page 64 of the pdf manual linked by NickH details the setting).
Has anyone also looked at page 56 of the manual PDF? It has "Self-adjusting mode selection" am I too optimistic to think this is an autotune feature? There also seems to be "inertia identification" settings on the next page.
- ihavenofish
01 Jul 2024 23:36 #304182
by ihavenofish
It is a basic dynamic autotune by the look. Looks similar to what my JMC's and older sanyos have. Set a desired stiffness / response, and it deals with the rest.
JMC's autotune is "ok". It did not make the motor perform better than my manual tune. What it did to is take 2 minutes instead of 10 hours to adjust, which is nice
- Robbbbbb
01 Jul 2024 23:55 #304184
by Robbbbbb
Awesome, that sounds promising, I'll have to give it a go once the servo is mounted on the mill, I already spent my 10h trying unsuccessfully to tune the X and Y steppers with linear encoder feedback - not fun...
- ihavenofish
02 Jul 2024 00:00 #304185
by ihavenofish
steppers? ha. ouch.
my experience with steppers and encoders is that the encoder is good for a safety system to make sure its not lost position, but it is best not to actually try to "drive" the stepper with the encoder feedback. The just don't have the ability to respond.
- Darium
10 Jul 2024 15:38 #304824
by Darium
Replied by Darium on topic Problems with Lichuan Ethercat servo drive
Has anyone solve "the start lcnc before plug in ethernet cable" issue yet?
i have the same thing but my driver are lichuan closed loop stepper CL3-E86H
I got it to run but still have to do the ritual every times I turn on the machine
- Thank you received: 7488
10 Jul 2024 16:17 #304826
Edit the IP and the location as needed, save to a text file with whatever name .sh, make the file executable in properties.
Replied by tommylight on topic Problems with Lichuan Ethercat servo drive
From PCW:Has anyone solve "the start lcnc before plug in ethernet cable" issue yet?
#!/bin/bash
echo Waiting for control power
(exit 1)
while (($?))
do
ping -c 1 10.10.10.10 >/dev/null 2>&1
done
echo Starting LinuxCNC
linuxcnc /home/cnc/linuxcnc/configs/by_machine.plasmac.axis-2/metric_plasmac.ini
The following user(s) said Thank You: Darium
Time to create page: 0.182 seconds
