Amplifier Fault ECT60 Closed Loop
2 years 2 months ago #308679 by TheRoslyak
Well, and I wrote the XML manually.
2 years 2 months ago #308689 by rodw
Strange. I have this kind of drive, and I didn't have any problems with it, although I didn't run it for long. Actually, when you buy it, it's initially sold as either closed-loop or open-loop, and the seller asked me about it when I purchased it. Well, I immediately chose the closed-loop one.
Yes I have its big brother ECT86 running perfectly. I am sure I had this running  in testing with no load but lost the config. I think my manual XML has been used by most people on these drives. Pretty sure its found its way into ScottLairds linuxcnc-ethercat driver too.
@besriworld, I was hoping you had nailed it, but not to be. Being a plasma guy, I forget about inertia! I  tried disconnecting the drive and see if it runs with no load  but its no better.
The fault is "Joint 1 amplifier fault"
@tommy, this ethercat drive looks after the encoder connection. I can see the DRO moving when I twist the shaft so its OK. It has automatic tuning by default and the motor and drive are a matched pair. It can be set manually, but I don't think I need to go there.
Thanks everyone for their ideas. I am still none the wiser. From memory, there is an internal error register I might publish a pin for and review.
2 years 2 months ago #308704 by besriworld
Now I saw the device.
My idea was if there will be an error if the speed/acceleration is low.
2 years 2 months ago - 2 years 2 months ago #308716 by TheRoslyak
Again, please clarify which drive you ended up taking. Because a closed-loop drive is sold by the seller at a slightly higher price. This is probably due to the low-level firmware. They might have sent you a cheaper version.
www.rtelligentglobal.com/uploads/Rtellig...ies-User-Manual1.pdf
Last edit: 2 years 2 months ago by TheRoslyak.
2 years 2 months ago #308727 by rodw
As per the first post this is an ET60 so it has encoder inputs and associated firmware. The ECR60 is open loop only.
I wonder if you would be so kind as to share your working config?
2 years 2 months ago #308812 by AndyDM01
how did you get the ECR moving in the first place? did you add the lcec_rtec.c to the lcec_main.c ? I'm a bit stuck and out of ideas
Time to create page: 0.360 seconds
