AX58100
- Hakan
- Thank you received: 255
It's a possibility what you say. Anyone wishing to give it a go have all the schematics and pcb layouts
as a starter, and all software needed to deliver values over EtherCAT on github.
You know the path isn't always that straight when I develop things. I started with the LAN9252 and it is more or less coincidental that I went with the Ax58100. And you are right, they are used as gateways. In the setup with a MCU I don't really see a difference, can go with any of the two. They are both available on aliexpress and cost about the same. I have gone back to the LAN9252.
For the plasma build, my initial thoughts with EaserCAT-3000 card and the Ax58100 was to use existing stepper motor drivers and have the card do pulse/dir. While that now works, I have skipped that path and are now going to use ECT60 Ethercat stepper motor drives. My own cards will be used for Digital IO (limit switches, float switch, break-away switch, torch on), and for reading the THCAD-300.
Here is the reader for THCAD. A stripped version of the EaserCAT-3000, with LAN9252. The MCU reads PWM frequency on one pin. Could definitely use a smaller MCU, but it is also easy to reuse what I know works.
Digital IO. This card does use the DIO of the LAN9252 directly, no MCU.
I find that the documentation for the Ax58100 is lacking for the special functions, like stepper motor driver. There is a reference application supplied that uses TwinCAT to drive a stepper motor. I guess one could try to understand how all that works, but I haven't. And that is all info I know of.
- RDA
- Thank you received: 43
The asix chips look nice on paper but then again if you pair it with a MCU, how much benefits are there, I don't know? I was just wondering if there are benefits from the programming side so that it would make sense to use that instead of the LAN9252. I have 0 experience with the asix chips so I would love to hear from people that have used both.
Although both maybe available on aliexpress, I would say the LAN9252 is far more obtainable than the asix chips. I typically try to scan something like octoparts for any "special" components I might use, at least if there is even a small chance I make something more than one. A quick look and just digikey and mouser stock these in the thousands. I lost my mind on the chip shortage so now days I try to find multiple sources for parts and if I'm lucky multiple alternatives.
Good luck with your plasma build!
- Hakan
There is a tiny difference in how to reset the ESC chip, LAN9252 can be reset by writing over SPI, AX58100 need a pin to go low.
Ax58100 also has a pin for a led that indicates successful read of the eeprom. Pretty useless but has been nice diagnostics when starting up the board.
Other than that one can consider them identical.
I have seen someone state that the AX58100 is faster than the LAN9252. I can not see that, I haven't been in a situation where I can identify the ESC speed as a factor, on individual usec level.
- pippin88
- Thank you received: 48
- SOLD
- Thank you received: 12
- SOLD
I haven't made it into 1PCB yet due to the price constraints of PCB size exceeding 100X100mm.
I'm adding the DAC Op-amp circuit and waiting for the test. Encoder connection.
- SOLD
- SOLD
I followed hackaday.io/project/181058-ethercat-serv...e/log/196311-ax58100 for years before the project switched to AX58100. There was a description between the two chips that I didn't quite understand until I found Kahan's project that switched to AX58100 and I followed suit.The asix chips look nice on paper but then again if you pair it with a MCU, how much benefits are there, I don't know? I was just wondering if there are benefits from the programming side so that it would make sense to use that instead of the LAN9252. I have 0 experience with the asix chips so I would love to hear from people that have used both.
- SOLD
If so, I will try LAN9252 on the next board.With the use of SOES github.com/OpenEtherCATsociety/SOES there is no difference for me as a programmer.
- SOLD
According to the AXIS manual, it uses an STM32H745, which has 2 cores, both H7 and H4, and is expensive. I saw that all the configuration examples only use the H4 core, so I designed another STM32H723 as an alternative. It has a single core, the H7. It costs almost the same as the F407, which is much cheaper than the H745.
When I finish building the PCB, I hope to compile the files successfully with the knowledge I have gained from Hakan.
