AX58100
- COFHAL
- Thank you received: 61
- Hakan
- Thank you received: 453
Starting in eeprom_generator. Then for lcec in ethercat-conf.xml you can select the datatype of the created hal pin.
I don't think every combination is possible or makes sense, but to go from ethercat u32 to hal bit should work. For example.
Regarding the Analog voltage output - yes that was the reason to chose that pin - it is DAC capable.
The STM32 is really picky which pin one selects, they all have special functions and are not interchangeable at all.
- SOLD
- Thank you received: 13
This problem is fixed directly in ethercat-conf.xml using the original eeprom.I have been playing with the inputs and outputs of the card and I realized that these are of type u32 and in order to be used in LCN they must be converted to BITs with the conv_u32_bit component, this is because some pins that LCN automatically creates are of type bit, such as joint.N.amp-fault.in, iocontrol.o.emc.enable-in, or any other pin that has been declared as type bit.
<pdo idx="1a01">
<pdoEntry idx="6001" subIdx="01" bitLen="1" halPin="in1" halType="bit"/>
<pdoEntry idx="6001" subIdx="02" bitLen="1" halPin="in2" halType="bit"/>
<pdoEntry idx="6001" subIdx="03" bitLen="1" halPin="in3" halType="bit"/>
<pdoEntry idx="6001" subIdx="04" bitLen="1" halPin="in4" halType="bit"/>
<pdoEntry idx="6001" subIdx="05" bitLen="1" halPin="in5" halType="bit"/>
<pdoEntry idx="6001" subIdx="06" bitLen="1" halPin="in6" halType="bit"/>
<pdoEntry idx="6001" subIdx="07" bitLen="1" halPin="in7" halType="bit"/>
<pdoEntry idx="6001" subIdx="08" bitLen="1" halPin="in8" halType="bit"/>
</pdo>Please Log in or Create an account to join the conversation.
- SOLD
Thanks for the guide.ฮาคานโพสต์=316122 userid=22448ขอแสดงความยินดีด้วย โปรแกรมดีบักเกอร์ช่วยได้มากในการแก้ปัญหาบางอย่าง
ดังที่คุณทราบ ตัวแปรจะอัปเดตเมื่อโปรแกรมหยุดชั่วคราวหรือกำลังดำเนินการ
Next step, I might change the name of pin in u32 index-status; in metalmusings_encoder.comp to match the name of pdo, as I have confused it, and might need to change the data type of one of the parts to match.
Then reconnect the hal.
As I understand it,
when "Obj.IndexStatus" is sent to "pin in u32 index-status" in metalmusings_encoder,
it causes "pin io bit index-c-enable", which is equivalent to the original index-enable, to change the state to 1.
When index-c-enable is triggered, "pin out u32 index-latch-enable" will return to "Obj.IndexLatchEnable" to reset encCnt to 0, waiting to be 1 in the next round.
- SOLD
I tried to let Ai create a sample code according to my needs. It came out as follows. Of course, it still doesn't work. And the Obj variable that can't handle it. I don't have the knowledge to create a new program.
#include "OrientationHandler.h"
#include <Arduino.h>
#include "MyEncoder.h"
extern HardwareSerial Serial1;
extern MyEncoder Encoder1;
extern double spindleTargetPos; // ตัวแปรใหม่ที่ใช้เก็บตำแหน่งเป้าหมายสำหรับสปินเดิล
extern const byte DAC1_pin; // ขาสำหรับเชื่อมต่อสัญญาณอนาล็อก (0-10V)
extern _Objects Obj;
// ฟังก์ชันคำนวณทิศทางที่สั้นที่สุดในการหมุน
int calculateShortestAngle(int currentAngle, int targetAngle)
// ทำให้มุมทั้งหมดอยู่ในช่วง 0-360 องศา
currentAngle = currentAngle % 360;
targetAngle = targetAngle % 360;
// คำนวณความแตกต่างระหว่างมุม
int deltaAngle = targetAngle - currentAngle;
// ถ้าความแตกต่างมากกว่า 180 องศา ให้เลือกหมุนทางที่สั้นที่สุด
if (deltaAngle > 180)
deltaAngle -= 360;
else if (deltaAngle < -180)
deltaAngle += 360;
return deltaAngle; // ผลลัพธ์เป็นมุมที่ใกล้ที่สุดในการหมุน
// ฟังก์ชันสำหรับการหมุนสปินเดิลไปยังมุมที่กำหนด
void spindleOrientation(int targetAngle)
Serial1.println("คำสั่ง M19 ได้รับแล้ว กำลังหมุนสปินเดิลไปยังมุมเป้าหมาย...");
int currentAngle = Encoder1.currentPos(); // อ่านมุมปัจจุบันของสปินเดิล
int deltaAngle = calculateShortestAngle(currentAngle, targetAngle); // คำนวณมุมที่ใกล้ที่สุดที่ควรหมุน
Serial1.print("มุมที่ใกล้ที่สุด: ");
Serial1.println(deltaAngle);
// ถ้ามุมที่ต้องการคือ 0 หรือใกล้เคียง (ไม่ต้องหมุน)
if (fabs(deltaAngle) <= 0.01)
Serial1.println("ตำแหน่งปัจจุบันตรงกับตำแหน่งที่ต้องการ ไม่ต้องหมุน");
analogWrite(DAC1_pin, 0); // หยุดการหมุน
Obj.SpindleStatus = 1; // หมายเลข 1 สำหรับสำเร็จ
return; // ออกจากฟังก์ชัน
// คำนวณค่าอนาล็อกเพื่อควบคุมแรงดัน 0-10V (ใช้ map แปลงจากมุมที่ต้องหมุนเป็นค่าที่ใช้กับ analogWrite)
int analogValue = map(abs(deltaAngle), 0, 360, 0, 255);
if (analogValue > 255) analogValue = 255; // ตรวจสอบให้ค่าไม่เกิน 255
// กำหนดทิศทางการหมุนและควบคุมมอเตอร์
if (deltaAngle > 0) // หมุนไปทางขวา (clockwise)
analogWrite(DAC1_pin, analogValue);
Serial1.println("หมุนไปทางขวา (clockwise)");
else if (deltaAngle < 0) // หมุนไปทางซ้าย (counterclockwise)
Serial1.println("หมุนไปทางซ้าย (counterclockwise)");
// ตั้งเวลาหมุนสูงสุด (timeout) เช่น 5 วินาที
unsigned long startTime = millis();
unsigned long timeout = 5000; // เวลา 5 วินาที
// รอจนกว่าสปินเดิลจะถึงตำแหน่งเป้าหมาย หรือจนถึงเวลาหมด
while (fabs(Encoder1.currentPos() - targetAngle) > 0.01)
// ตรวจจับ rising edge ของสัญญาณ encoder index pulse เพื่อยืนยันการหมุนถึงตำแหน่งศูนย์
if (Encoder1.indexHappened())
Serial1.println("ตรวจจับ index pulse แล้ว.");
// ลดความเร็วเมื่อเข้าใกล้ตำแหน่งเป้าหมาย
if (fabs(Encoder1.currentPos() - targetAngle) < 5.0)
Serial1.println("ใกล้ถึงตำแหน่งเป้าหมาย ลดความเร็วลง...");
analogValue = map(abs(deltaAngle), 0, 360, 0, 100); // ลดค่าควบคุมแรงดันเพื่อหมุนช้าลง
// อัพเดตการทำงานของมอเตอร์
updateStepperGenerators();
// ตรวจสอบเวลา timeout
if (millis() - startTime > timeout)
Serial1.println("เวลาหมุนหมดแล้ว, ไม่สามารถหาตำแหน่งได้!");
// ส่งสถานะกลับไปยัง Master ว่าการหมุนไม่สำเร็จ
Obj.SpindleStatus = 2; // หมายเลข 2 สำหรับ Timeout
// เมื่อถึงตำแหน่งเป้าหมาย, หยุดจ่ายไฟ (หรือปรับค่าผลลัพธ์เป็น 0)
analogWrite(DAC1_pin, 0); // หยุดการหมุนโดยการส่งค่าแรงดัน 0
// ส่งสถานะกลับไปยัง Master ว่าการหมุนสำเร็จ
Serial1.println("สปินเดิลได้ถูกออเรียนเทชันไปยังมุมที่กำหนดแล้ว.");
Functions to be included
- Use DAC1 as analog +-10V to control servo spindle
- Receive M19 command and degree variables such as R0 R45 R90 from Hal " net spindle_orientation => ecat.0.command "
- Check if the current position is the same as the desired target
- Calculate the nearest rotation direction
- Add edge, near function
- Timer to turn off DAC if no target is found
- Confirm operation or error back to Master
Other if necessary
- COFHAL
- SOLD
???yes, work.
- COFHAL
- COFHAL
- Hakan
