Using POSIX realtime
1 year 5 months ago #327684 by Roger S
Replied by Roger S on topic Using POSIX realtime
I performed the installation according to the instructions from rodw
forum.linuxcnc.org/ethercat/45336-etherc...-how-to-step-by-step
1 year 5 months ago #327691 by Hakan
Replied by Hakan on topic Using POSIX realtime
Search for the ec_generic.so files like  I did.
1 year 5 months ago #327949 by Roger S
this is the result:
35375     20 -rw-r--r--   1 root     root        20333 Mai  5 16:57 /usr/lib/modules/6.1.0-34-rt-amd64/updates/dkms/ec_generic.ko
  7093046     20 -rw-r--r--   1 root     root        20333 Mai  5 16:55 /usr/lib/modules/6.1.0-30-rt-amd64/updates/dkms/ec_generic.ko
   526822     20 -rw-r--r--   1 root     root        20333 Mai  5 16:57 /var/lib/dkms/ethercat-dkms/1.6.4/6.1.0-34-rt-amd64/x86_64/module/ec_generic.ko
   526812     20 -rw-r--r--   1 root     root        20333 Mai  5 16:55 /var/lib/dkms/ethercat-dkms/1.6.4/6.1.0-30-rt-amd64/x86_64/module/ec_generic.ko
1 year 5 months ago - 1 year 5 months ago #327980 by Hakan
I guess you installed ethercat-dkms, the modules seem to be generated a couple of days ago.
It works now?
If it doesn't I would say to reinstall ethercat master and the drivers
sudo apt remove ethercat-master ethercat-dkms sudo apt install ethercat-master ethercat-dkms # edit /etc/ethercat.conf again
and make sure that the rather lengthy part where the modules are being built for the kernel succeeds.
Last edit: 1 year 5 months ago by Hakan.
1 year 5 months ago #328022 by Roger S
Unfortunately, it still doesn't work. I've since reinstalled the system, but there's no improvement. I don't understand it. The system worked before the reinstallation. I performed the installation according to the instructions. Anything else isn't possible for me anyway, as I'm just a user and don't know enough to try anything myself.
[  100.533257] EtherCAT: Master module cleaned up.
[  101.670667] EtherCAT: Master driver 1.6.4 1.6.4.g703b611-1+17.1
[  101.670804] EtherCAT: 1 master waiting for devices.
Master0
  Phase: Waiting for device(s)...
  Active: no
  Slaves: 0
  Ethernet devices:
    Main: 80:ee:73:fd:0f:8b (waiting...)
      Link: DOWN
the only thing I noticed:
8.198677] ec_master: module verification failed: signature and/or required key missing - tainting kernel
1 year 5 months ago - 1 year 5 months ago #328025 by Hakan
There is something odd with your installation.
I just tried myself to "apt remove ethercat-master ethercat-dkms" followed by "apt install ethercat-master ethercat-dkms" and it worked just fine.
I do not get the "tainted kernel" message.
Can it be that you have compiled the ethercat master yourself at one point? And that the runnning ethercat master is looking for ec_generic in a place where it isn't?
It's a bit of guesswork and searching now.
Can you the command "sudo service ethercat status" and compare the ouput with mine?
debian@plasma:~$ sudo service ethercat status ● ethercat.service - EtherCAT Master Kernel Modules      Loaded: loaded (/lib/systemd/system/ethercat.service; enabled; preset: enabled)      Active: active (exited) since Thu 2025-05-08 20:32:57 CEST; 7min ago     Process: 78578 ExecStart=/usr/sbin/ethercatctl start (code=exited, status=0/SUCCESS)    Main PID: 78578 (code=exited, status=0/SUCCESS)         CPU: 25ms maj 08 20:32:57 plasma systemd[1]: Starting ethercat.service - EtherCAT Master Kernel Modules... maj 08 20:32:57 plasma systemd[1]: Finished ethercat.service - EtherCAT Master Kernel Modules.
Edit. Can you also repeat the search for ec_generic, but this time search for ec_master, in the same way?
Edit 2. No need to search. Instead show the output of the command "sudo modinfo ec_master", especially the first filename line.
Last edit: 1 year 5 months ago by Hakan. Reason: Ask to search for ec_master
Time to create page: 0.201 seconds
