The following results:
- ip a returns the result that the adapter is running without errors:
enp1s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP
- the permissions are also correct:
crwxrwxrwx 1 root root 238, 0 3. Mai 16:22 /dev/EtherCAT0
nevertheless the link is DOWN and I cannot start a test configuration
Debug file information:
Note: Using POSIX realtime
Failed to reserve master: No such device
LCEC: requesting master 0 (index 0) failed
LCEC: failure, clearing config
LCEC: exiting
LCEC: returning -EINVAL
lcec: rtapi_app_main: Invalid argument (-22)
./axis_mm.hal:3: waitpid failed /usr/bin/rtapi_app lcec
./axis_mm.hal:3: /usr/bin/rtapi_app exited without becoming ready
./axis_mm.hal:3: insmod for lcec failed, returned -1
2306
Stopping realtime threads
Unloading hal components
