Ver 2.9.4 iso clean install Trouble when disabling EOE
8 months 6 days ago - 8 months 6 days ago #343524 by Hakan
That's right. Linuxcnc doesn't use an ESI file.
The ethercat master reads out the info it needs from the slave directly.
The safest way to update the SII eeprom contents of the drive is to use TwinCAT.
There are a number of steps needed, but in principle not difficult.
Download and install TwinCAT from Beckhoff it you don't already have it,
Place the ESI file you got from support in C:\TwinCAT\3.1\Config\Io\EtherCAT
or where your twincat installation is.
In this video I update the firmware on a device, the principle is the same for your drive.
Go to 5:20 for the relevant part.
Last edit: 8 months 6 days ago by Hakan.
The following user(s) said Thank You: tar_san
8 months 6 days ago #343533 by Marcos DC
I think that for Yaskawa, the safest approach is to use Yaskawa’s own tool (SigmaWin+), since it knows the hardware and the drive’s constraints, and it’s also the approach their support can reproduce and help with if something goes wrong.
8 months 5 days ago - 8 months 5 days ago #343570 by tar_san
Thank you so much,  This video is helpful.
And I counld not find ESI upload function in SigmaWin+.
I agree that using SigmaWin would be better if I could use it to do that.
And I think .. sometimes updating new ESI to older software version device is a little bit risky..
I'm considering a little bit about it.
Anyways, thank you so much you guys.
Last edit: 8 months 5 days ago by tar_san.
8 months 5 days ago #343583 by Hakan
Yes, the ESI file must agree with the firmware in the drive.
I thought about warning for that, but since you were in contact
with Yaskawa support I thought they must know, they should know.
8 months 4 days ago #343629 by tar_san
Thanks a lot !
They also mentioned, "if you put this newest ESI , some of this problem will fixed."
( But LinuxCNC (IgH master) desn't have this function. And Yaskawa tools doesn't have upload ESI function to drive as default.)
They said also, this ESI file contains fixture for all versions of firmware.
In this case, do you think It is possible for TwinCAT to fix default ESI in ServoDrive , to make LinuxCNC work ?
I know I have to do it with my own risk and I may not need to do it if I found another solutions.
But I'm happy if I could get some hints for it...
8 months 4 days ago #343640 by Hakan
You can always test the new version. It is actually very easy to make a backup
of the eeprom contents and later put it back if needed.
ethercat -p 0 sii_read > eeprom_backup.bin ethercat -p 0 sii_write eeprom_to_restore.bin
We need TwinCAT to do the translation from ESI file to eeprom binary contents.
While there are some open-source tools for that too, the safest way is to use TwinCAT.
Time to create page: 0.072 seconds
