For Yaskawa Sigma7 the issue with lcec (linuxcnc-ethercat) software component is not only EOE being enabled in the drive.
It also has something to do with modes LRD/LWR and LRW. In the sigma7, the PDOs in the syncMasters are not read-write, i.e., LRW mode is not supported by sigma7. To work with sigma7, you need to enable 2 domains in the lcec program. I am not sure how to do that yet.
This issue is documented in these forum threads:
forum.linuxcnc.org/ethercat/50245-yasikawa-sigma7-lcec-driver
forum.linuxcnc.org/ethercat/48110-etherc...-responding?start=40
I have tried using this program from github.com/nylon7 and fdarling (on the yaskawa thread in the linuxcnc forum) and have seen some success in enabling the sigma7 motor and moving it and reading the absolute position register over ethercat.
github.com/nylon7/Igh-Ethercat-master/bl...ples/user/main_yas.c
For doing this, I am using the IGH Ethercat master 1.6-stable with EOE disabled as documented by Hakan.
I think we need to make some changes in lcec to enable the use of two domains.
-automata
