  • Fastfred
  • Fastfred
12 Dec 2025 19:22
Replied by Fastfred on topic Clearpath HLFB amp.joint.delay
Category: HAL
Just got back to it, have screen shots showing HLFB input pins inactive and active with machine enable ( think I did this correct) Two things only have the x axis active everything else commented out. Wasn't sure how to configure the output portion at the moment i have one output to enable the drives and the second thing was should the x axis fault with this config when i disconnect it at the moment it does not.
File Name: custom_2025-12-12.hal
File Size:1 KB
  • T_D
  • T_D
12 Dec 2025 19:13
Replied by T_D on topic Mesa konfiguration Maho 500 W4
Category: Driver Boards
Thank you for this answer , that means i can use the 7i97t and connect as much cards that i need together or does something like limit exist for this combination ? Or is it better to wait for the 7i77 to get available ?
  • Masiwood123
  • Masiwood123's Avatar
12 Dec 2025 18:36
freelancer needed to create a routine for ATC tool change (rackchange)
File Name: beta1_2025-12-12.ini
File Size:5 KB
File Name: beta1_2025-12-12.hal
File Size:13 KB
File Name: rack_chang...2-12.ngc
File Size:2 KB
if someone know to edit ini and rack_change.ngc files according to my y positions for tool 4,5,6 here are my files.thank you
  • gravedigger
  • gravedigger
12 Dec 2025 18:31
Replied by gravedigger on topic stepgen maxvel too big and SRO problem
Category: Gmoccapy
I tested with gmoccapy and dragon.
The MOV doesn't work. The spindle and the normal feed work with enc3.
# ---Überschreibung von Signalen zum Mesa-Geber - mpg (feed override signals to mesa encoder - mpg)---
net fo-count <= [HMOT](CARD0).7i73.0.0.enc1.count
# Vorschub-Override-Schritte verbinden - MPG (connect feed override increments - MPG)
setp halui.feed-override.direct-value false
setp halui.feed-override.scale .01
setp halui.feed-override.count-enable true
net fo-count => halui.feed-override.counts
# ---max Geschwindigkeit Neufestsetzungs-Signale an Mesa Encoder - mpg (max velocity override signals to mesa encoder - mpg)---
net mvo-count <= [HMOT](CARD0).7i73.0.0.enc3.count
# verbinde max Geschwindigkeit Neufestetzung Inkrement - MPG (connect max velocity override increments - MPG)
setp halui.max-velocity.direct-value false
setp halui.max-velocity.scale 0.666667
setp halui.max-velocity.count-enable true
net mvo-count => halui.max-velocity.counts
  • Ismacr63
  • Ismacr63
12 Dec 2025 18:25
Replied by Ismacr63 on topic VFD configuration help
Category: Turning
That's true, but I'd like to have the buttons because that's the configuration I've had until now.
What kind of relay do I need?
  • Masiwood123
12 Dec 2025 17:14 - 12 Dec 2025 17:29
The space between 3 and 4 do not agree to say that it is possible to divide by 111I would like all 6 tools to work, the delta between 1,2,3 is 111mm, so there is a gap, so the same delta raster between 4,5,6 is also 111mm, so the distance between 3 and 4 is 317mm...I will post the script for the first 3 tools later...if I copy and put an additional [change position delta 2]' in the ini file with ``if<current_tool GT 3>`` it doesn't work
12 Dec 2025 16:08
Replied by tommylight on topic VFD configuration help
Category: Turning
You already have that with the 3 position switch.
If you want to use momentary switches for it, might need to add relays.
12 Dec 2025 16:05
Replied by tommylight on topic Mesa konfiguration Maho 500 W4
7i92TM + 7i77 is functionally the same as 7i97T, but with more IO so no need for 7i84.
The IDC26 connector can be used for other Mesa boards, like 7i85 or 7i85S or 7i74 etc, or a simple BOB can also be used and this will limit what pin can be used as input and output and limit the stepgen and/or encoder count rate, but still can be used for plenty things like switches, sensors, relays, etc.
  • Ismacr63
  • Ismacr63
12 Dec 2025 16:03
VFD configuration help was created by Ismacr63
Category: Turning
Hello, I've bought my first VFD, a Vevor A2 8015 1.5kW model, for a 0.75kW, 1000rpm motor for my mini lathe. I've configured the most basic options and added an external potentiometer and a 3-position switch for forward and reverse.
I'd like to add two momentary switches, one for start and one for stop. Is that possible with my VFD? Can anyone help me with this?
I've attached the manual.
12 Dec 2025 15:59
Is the gap a multiple of existing tool distances?
If yes, set it as tool (4 i think in your case) and just do not use tool 4 in post, and even if someone asks for tool 4 no damage should be done as the spindle does not go that low.
  • Hakan
  • Hakan
12 Dec 2025 15:49
Ethercat compatible Encoder board tentative STM32F4 + LAN9252
Category: EtherCAT
Here is how you assign the encoder value to the PDO variable
  • Hakan
  • Hakan
12 Dec 2025 15:26 - 12 Dec 2025 15:32
Category: EtherCAT
You decide yourself which SDOs and PDOs you need and want to have.
I propose to have zero SDOs to start with and only one PDO which is the hardware counter number.
You see at ther bottom in the figure, the save/restore button. Download all files, it will create a zip file with al you need.
Unpack those seven? files in lib/soes-esi and rebuild the code. Take the xml file to TwinCat and program the eeprom there.
You decide yourself which Vendor Id. Product code, etc etc you want to have.
Some sizes you should not change, it tells you in the mouse-over comment.
The config struct can look like this
And the loop()
A lot of clean-up  yes.
  • automata
  • automata
12 Dec 2025 15:11
Long initialization of Ethercat on servo drive SV660N
Category: EtherCAT
I can confirm that Innovance SV660N works by recompiling the IGH etherlab master stable-1.6 branch and installing on a fresh debian bookworm installation.
The configuration options I have used for the etherlab master are:
./configure --sysconfdir=/etc/ --disable-8139too --enable-userlib --enable-generic --disable-eoe
Thank you nanowhat.
-automata
  • vibram
  • vibram
12 Dec 2025 14:20 - 12 Dec 2025 15:01
Category: EtherCAT
Hello and thank you for your reply.
My encoder seems good and with the help of AI I modified the SPI to match my setup. I started from your E7000 version and made some cleaning of the main.cpp.
I went too fast and test in Twincat, I can see the device but its stuck in INIT mode yet. not surprising. I think the old eeprom is still there because in twincat, in the device I can see 8 inputs and 8 outputs, what I had on the original board.
I think I need to build the eeprom stuff correctly but I have absolutely no clue how to do it.
My github is up to date.
Do you have more information regading SDos and PDOs ? How to know what to write?
Thank you
Displaying 10036 - 10050 out of 11520 results.
Time to create page: 0.800 seconds
