  • ArthurG
  • ArthurG
01 Dec 2025 21:27
Looking for freelancer to finish retrofit of K2 router
Category: User Exchange
I hired someone last year to retrofit our K2 (KG5050) router after the K2 control board was fried. The primary goal (besides replacing the control electronics) was for it to be able to run LinuxCNC. After many false starts and wrong decisions made in the components to be used, and many, many hours spent wiring and re-wiring and testing things, it turned out that this project was too much for the young man I hired. He ultimately gave up after he failed to figure out the tuning of the servos/axes.
I have a computer programming background but I know very little about the world of electrical engineering and am hoping to find someone who can finish off the project - which according to the young man I hired, is just the tuning of the motors/axes, but which I suspect might require a bit more.
Ideally, I'd like to find someone local (we're based in Ventura, CA) but the control PC *is* setup with remote desktop access and a webcam on the table, so if you're confident you could do it remotely, with me on hand to E-stop/reset the machine as needed, I'd be okay with that option.
  • Muzzer
  • Muzzer
01 Dec 2025 21:22
Updating from LINUXCNC - 2.8.4-23, Mint 20.3 - gmoccapy lathe structure
Category: Gmoccapy
I have to admit that Linuxcnc is the only application I have that requires Linux. Like Andy, my engineering job requires almost exclusively Windows based programs, as do my family, for whom I appear to be IT manager.
@andypugh - could you suggest why your macros aren't showing up in my gmoccapy GUI? I've got no errors showing but clicking on the "cycles" tab doesn't change from the XZ preview.
File Name: combined_2...2-01.ini
File Size:7 KB
File Name: combined_2...2-01.hal
File Size:10 KB
  • Masiwood123
  • Masiwood123's Avatar
01 Dec 2025 20:21
Replied by Masiwood123 on topic Physical buttons to 7i96s+7i77
Category: HAL
thank you very much, I'll try it tomorrow, maybe the scale won't match because the input to the potentiometer is about 26vdc, but it's important that it works... maybe you can insert another potentiometer for jog override, i.e. jogging speed regulation, since this bosch wheel is not mpg, but the same potentiometer that they used, I assume, in the version with increments on the old controller, it's the same around 26vdc and could be attached  to analogin2?
  • unknown
  • unknown
01 Dec 2025 20:13
looking to tweak a working system for more accuracy
Category: Basic Configuration
Regarding Imperial vs Metric for accuracy.
Since Mr Johansson decide to use 25.4mm as the standard for 1 inch when producing his blocks, around the 1930's 16 countries started to use this as standard conversion, including the USA and UK. This was officially adopted world wide in the 1960s.
So basically an inch is defined as 25.4mm. Therefore it matters not whether one chooses metric or imperial to work with. As long as the machine is up to the task, ie in a state mechanically and to be pendantic tested and calibrated via a NIST certified testing facility you will get the required accuracy.
Another thing to consider whilst microstepping is great for smoothing movement it does not guarantee any linearality over a complete revolution. Another thing is the linearality of the lead screw it self, the stew itself may require mapping to help with commanded position and actual position reported by your scales.
Rolled ballscrews may not give the accuracy you are seeking.
So much to consider when aiming for um accuracy, without even thinking of thermal expansion of the cast iron vs lead screw material and all the boffin subjects.
But first port of call would be to assess the machine mechanically, check linearality and this should give you a baseline of what is realistic, then attempt progressive changes with much testing.
Your ideas do seem like a good starting point and only testing will confirm.
  • unknown
  • unknown
01 Dec 2025 19:45
Replied by unknown on topic User name rpi-first-boot-wizard
Category: Installing LinuxCNC
Thanks Tommy for picking up the slack in my less than ideal state of alertness.
One thing I would like the OP to confirm, is when using halcmd do you get proper comms with the board ? Just to confirm we aren't dealing with a hardware issue.
Once again I apologise for my lack of alertness.
  • unknown
  • unknown
01 Dec 2025 19:41
Remora (SKR 1.4 RPi) – massive SPI noise, “bad payload” communication fails
I know that with the mesa 7c81 boards it is recommended to have a length of less than ~2.5" for the SPI cable length. So it just maybe the cable length is too long.
Dupont cables aren't ideal for SPI transmission at speed.
So ideas to try.
Ribbon cable with every second conductor a ground terminated at one end only, of course you will need a dedicated return ground. This may involved a custom bit of PCB at each end.
Shorter cable length for sure.
There's some other fixes I was going to suggest, but since the remora bards are "all in one" they would not apply.
But I guess a quality PSU, think Meanwell, might be worth considering.
My first port of call would be to reduce the SPI cable to the absolute minimum, preferably to under 2.5" max.
One thing of note is that I have the RPi5 can tolerate a longer SPI cable that the RPi4, the caveat being this is based on experience with a home made 7c81 clone.
I'm apologise if the references to the 7c81 is annoying, but it is entirely based on my experience with SPI as a communication medium. I honestly hope that some of the above suggestions will give you good for thought.
  • COFHAL
  • COFHAL
01 Dec 2025 19:23
Replied by COFHAL on topic Physical buttons to 7i96s+7i77
Category: HAL
File Name: custom_2025-12-01.hal
File Size:2 KB
I am sending you the corrected custom.hal file; I believe I had sent you one with some errors.
  • Chad
  • Chad
01 Dec 2025 19:21
Hi all,I have a working Remora configuration running with Raspberry Pi (LinuxCNC 2.9), SKR 1.4 board (LPC1768), and SPI connection – but only using an old Remora component, because the recent ones do not support LPC1768 anymore (as Scott confirmed). The system works perfectly “on the bench” with just the boards and motors, but as soon as I connect it to my real machine, the SPI link becomes super unstable (“bad SPI payload / estop won’t reset” errors).Symptoms:
  • Dupont wires or short IDC ribbon cable used for SPI (RPi CM4 → SKR1.4, <30cm).
  • Works fine with just the controller and stepper drivers.
  • The moment I connect “real loads” (motors, hotwire, power MOSFETs, or even touch the machine frame), SPI constantly fails.
  • E-stop triggers, payload errors jump in LinuxCNC log.
  • Even switching on the heater causes instant SPI dropouts.
  • With ribbon cable it’s even worse (won’t leave estop).
What I tried:
  • Multiple cables, power supplies, SD cards, re-flashing, common ground.
  • SPI config is what works for old component – I can’t change SPI freq etc, I get “unknown command” if I try.
  • System is totally stable on the bench, not with machine.
Limitations:
  • New Remora components don't work – the SKR1.4/LPC1768 is legacy, so I must use the oldest one.
  • This old Remora doesn’t let me change SPI speed, delay, etc.
  • Hardware fix suggestions welcome, but software/firmware is stuck “as is” for now.
Has anyone solved this?
  • Is it possible to get reliable SPI with legacy SKR1.4 + RPi, in a noisy CNC environment?
  • Any proven hardware methods? (twisted pairs, shielded cable, ground, ferrites, extra pullups, RC on SPI lines…?)
  • Is it possible to patch the Remora legacy component to allow lower SPI clock?
  • Any old firmware/component version which allows SPI configuration and works with LPC1768?
Any advice would help – right now the setup works great “bare”, but physical machine (motors/heaters/vibrations) kills SPI instantly…Thanks!
  • unknown
  • unknown
01 Dec 2025 19:16
Replied by unknown on topic Red Init & Done Lights on 7i92M
Category: Driver Boards
Why would you be attempting to offer a LPT card in this instance ?
  • RobotMatic
  • RobotMatic's Avatar
01 Dec 2025 19:04
parport observation in outport out-inverter-1 seems not to work
Category: HAL
I tried what you suggested, it doesn’t work, it has erratic behavior. It performs poorly in 2.8, 2.94, and 2.97, it behaves erratically in all of them, I don’t understand what’s going on
  • unknown
  • unknown
01 Dec 2025 18:44
Now it's morning time I'll have a look into this in a couple of hours.
Note to self, you're too old for late nights.
  • Hakan
  • Hakan
01 Dec 2025 18:43
Replied by Hakan on topic EtherCAT servo as main spindle
Category: EtherCAT
I don't have such a setup so it is very difficult to say.
But it sounds like the current position is lost, and when you go back to csp mode the current position is set to zero no matter how the spindle actually is rotated.
aDm1N had something about tracking position didn't he? Did you try that?
  • Hexagon
  • Hexagon
01 Dec 2025 18:15
Replied by Hexagon on topic EtherCAT servo as main spindle
Category: EtherCAT
Thank you Hakan.
This was very helpful. With your cia402pv and the files from aDm1N, I managed to get the servo running with GCode Commands both for rotation and positioning.
Here are the things I had to change in the hal-file:
- net c-mode-request and2.3.in0 -> spindle-ok-for-c
- net spindle-speed-normal spindle.0.speed-out mux2.0.in0 -> spindle.0.speed-out-rps
- and of corse some names and scale values
Now to my problem:
As long as I only use G0 and G1, the servo positions correct (example: C0 is at 12 o'clock). Then I let it run with M3 S1000 and after a while I stop it using M5. Now the servo stops at its position. In my optinion it should move to 12 o'clock, if I use G0 C0. But nothing happens. If I type G0 C90, it moves 1/4 revolution. So it looks like if the stopping of the servo sets somehow the zero position?
  • RobotMatic
01 Dec 2025 16:41 - 01 Dec 2025 16:51
Category: HAL
video     That's what I did when I ran into the problem
Displaying 10396 - 10410 out of 11519 results.
Time to create page: 0.317 seconds
