26 Oct 2025 23:36
Replied by tommylight on topic Mesa7i96s and Postep60-250?
Take some pictures of the wiring and upload them here on the forum so we can have a look.
Do you have a DVM or even better an oscilloscope? Or a simple small LED?
You can use those to check if the drives get any signal on the inputs, easy to check by changing direction of the axis being checked as that should swing from 0 to ~3.3 or 5V.
  • AkkiSan
  • AkkiSan
26 Oct 2025 22:15 - 26 Oct 2025 22:18
Which LinuxCNC HW for 2026+? was created by AkkiSan
I have been using LinuxCNC/EMC1-2 for more than 20 years by now; currently, on five machines (one with Machinekit) - and every single of them now has issues with newer versions:
- probe tripped during movement
- queue full
- joint following errors
It's a wild mix of interfaces and computers, two parallel ports, two Mesa cards, a RPi 5 (Mesa) and a Beaglebone Black (PocketNC).
I have never ever experienced joint following errors before. I also made millions (guessing here, hehe :-)) of probe movements without any issues.
Now, I'm not even able to finish a single milling job longer than 15 minutes without error.
I already went back to Wheezy (this also halved the latency again) and duplicated the setups without containing any probe pins,
just to keep things going. Of course, I always forgot to switch back and rammed mills into the length probes and elsewhere.
While browsing the forum, I noticed that many others seem to have the same issues, but there have to be working setups.
One machine was already converted to grbl. I always thought about this as a joke, and I now have to use my phone instead
of my handwheel - but it's actually not that bad. I also checked Acorn CNC and Masso, probably the way to go unless I find
time to develop sth on my own - the 87th standard. Lol.
I would like to stick with LinuxCNC, so which >>working<< setups could you propose?
Thx,
AS
  • melayate
  • melayate
26 Oct 2025 21:39
Replied by melayate on topic Mesa7i96s and Postep60-250?
Thank you guys so much for the heated debate about power supply. I have 2 power supplies each powering 3 of the drives. it worked like a charm with Pokeys57 board. I am not getting any juice out of the drives to the stepper motors, I tried the 1K pullup resistor, no luck. I to use a 10kΩ pull-up resistor from each PoStep Pin 1 to Pin 9 (+5V) to ensure drivers default to disabled state. and still nothing. I really don't want to go back to Mach4 & Pokeys board. I am just hitting a wall!
Thank you!
  • Grandberg
  • Grandberg
26 Oct 2025 21:28
7i97T stepgen outputs dead, encoders & I/O OK - suspect damaged P2 interface
Category: Driver Boards
While my new controller is on its way, could you tell me where I can find examples of electrical diagrams for connecting the board to peripheral devices (servo motors, encoders, sensors), especially in terms of their common ground? I don't want to make any mistakes again. Thanks!
26 Oct 2025 20:57
Replied by tommylight on topic Workshop update
Workshop update
Category: Show Your Stuff
A perfectly managed mess one would tend to think.
YES! I use the expression "organized chaos" when explaining my shop to others, but the meaning is pretty much the same.
Thank you.
  • unknown
  • unknown
26 Oct 2025 20:31
Replied by unknown on topic Workshop update
Workshop update
  • PCW
  • PCW's Avatar
26 Oct 2025 20:24 - 26 Oct 2025 20:31
Mesa smart serial or PktUART or serial over RS232 or udp for robot joints
Actually I took a look at this in the past and had some example firmware source, I will take a look on Monday.
And yes, it requires grafting on a simple UART connected to the "A" encoder pin (the UART can be quite basic as its
parameters are fixed)
  • unknown
  • unknown
26 Oct 2025 20:22
Proposal RPi Linuxcnc Image Based on Raspi OS All welcome/encoraged to comment
Category: Installing LinuxCNC
A lot has changed in time.
What was the reason for changing, if known ?
Is it a path worth checking out again ?
In other news.
It would look like the Trixie packages have been built on Bookworm for Arm, is that correct ?
Now that I have a working Trixie image, one image will work for the 4 & 5 would it be useful for package building for Trixie ?
  • PCW
  • PCW's Avatar
26 Oct 2025 20:21
Replied by PCW on topic LinuxCNC installation + 7I96S
Please attach your hal and ini files rather than including the text in the message as the forum
software mangles it so badly that it's basically unreadable.
Note that it is suggested to use pncconf or MesaCT to create hal/ini files for a current mesa card
This is likely the source of your following error issues.
  • jmp97
  • jmp97
26 Oct 2025 19:57 - 26 Oct 2025 19:59
Replied by jmp97 on topic LinuxCNC installation + 7I96S
No, it does not show an error at the beginning when the machine stops. The movement error occurs when you try to move the motors afterwards.
My INI
[EMC] # The version string for this INI file. VERSION = 1.1 # Name of machine, for use with display, etc. MACHINE = HM2-Stepper # Debug level, 0 means no messages. See src/emc/nml_int/emcglb.h for others #DEBUG = 0x00000003 #DEBUG = 0x00000007 DEBUG = 0 [DISPLAY] # Name of display program, e.g., tklinuxcnc #DISPLAY = tklinuxcnc DISPLAY = axis update_period = 0.05 show_trail = True # Cycle time, in seconds, that display will sleep between polls CYCLE_TIME = 0.0500 # Path to help file HELP_FILE = tklinuxcnc.txt # Initial display setting for position, RELATIVE or MACHINE POSITION_OFFSET = RELATIVE # Initial display setting for position, COMMANDED or ACTUAL POSITION_FEEDBACK = ACTUAL # Highest value that will be allowed for feed override, 1.0 = 100% MAX_FEED_OVERRIDE = 1.5 # Prefix to be used PROGRAM_PREFIX = ../../nc_files/ # Introductory graphic INTRO_GRAPHIC = linuxcnc.gif INTRO_TIME = 5 [FILTER] PROGRAM_EXTENSION = .png,.gif,.jpg Grayscale Depth Image PROGRAM_EXTENSION = .py Python Script png = image-to-gcode gif = image-to-gcode jpg = image-to-gcode py = python3 [RS274NGC] # File containing interpreter variables PARAMETER_FILE = hm2-stepper.var [EMCMOT] EMCMOT = motmod # Timeout for comm to emcmot, in seconds COMM_TIMEOUT = 1.0 # Servo task period, in nanoseconds SERVO_PERIOD = 4000000 [TASK] # Name of task controller program, e.g., milltask TASK = milltask # Cycle time, in seconds, that task controller will sleep between polls CYCLE_TIME = 0.010 [HAL] # The run script first uses halcmd to execute any HALFILE # files, and then to execute any individual HALCMD commands. # list of hal config files to run through halcmd # files are executed in the order in which they appear HALFILE = hm2-stepper-eth.hal # list of halcmd commands to execute # commands are executed in the order in which they appear #HALCMD = save neta [HALUI] #No Content [TRAJ] COORDINATES = X Y Z LINEAR_UNITS = mm ANGULAR_UNITS = degree # Ajuste seguro de velocidad inicial MAX_LINEAR_VELOCITY = 20 [EMCIO] # Name of IO controller program, e.g., io EMCIO = io # cycle time, in seconds CYCLE_TIME = 0.100 # tool table file TOOL_TABLE = tool.tbl [KINS] KINEMATICS = trivkins JOINTS = 3 [AXIS_X] MIN_LIMIT = -10000.0 MAX_LIMIT = 10000.0 MAX_VELOCITY = 20 MAX_ACCELERATION = 100 [JOINT_0] # # Step timing is 40 us steplen + 40 us stepspace # That gives 80 us step period = 12.5 KHz step freq # # Bah, even software stepping can handle that, hm2 doesn't buy you much with # such slow steppers. # # Scale is 200 steps/rev * 5 revs/inch = 1000 steps/inch # # This gives a maxvel of 12.5/1 = 12.5 ips # TYPE = LINEAR MAX_VELOCITY = 20 MAX_ACCELERATION = 100 # Set Stepgen max 20% higher than the axis STEPGEN_MAX_VEL = 24 STEPGEN_MAX_ACC = 120 BACKLASH = 0.01 # scale is 200 steps/rev * 5 revs/inch SCALE = -400 MIN_LIMIT = -10000.0 MAX_LIMIT = 10000.0 FERROR = 0.050 MIN_FERROR = 0.005 #HOME = 0.000 #HOME_OFFSET = 0.10 #HOME_SEARCH_VEL = 0.10 #HOME_LATCH_VEL = -0.01 #HOME_USE_INDEX = YES #HOME_IGNORE_LIMITS = YES HOME_SEQUENCE = 0 # these are in nanoseconds DIRSETUP = 200 DIRHOLD = 200 STEPLEN = 8000 STEPSPACE = 8000 [AXIS_Y] MIN_LIMIT = -10000.0 MAX_LIMIT = 10000.0 MAX_VELOCITY = 20 MAX_ACCELERATION = 100 [JOINT_1] TYPE = LINEAR MAX_VELOCITY = 20 MAX_ACCELERATION = 100 # Set Stepgen max 20% higher than the axis STEPGEN_MAX_VEL = 24 STEPGEN_MAX_ACC = 120 BACKLASH = 0.005 SCALE = -400 MIN_LIMIT = -10000.0 MAX_LIMIT = 10000.0 FERROR = 0.050 MIN_FERROR = 0.005 #HOME = 0.000 #HOME_OFFSET = 0.10 #HOME_SEARCH_VEL = 0.10 #HOME_LATCH_VEL = -0.01 #HOME_USE_INDEX = YES #HOME_IGNORE_LIMITS = YES HOME_SEQUENCE = 0 # these are in nanoseconds DIRSETUP = 200 DIRHOLD = 200 STEPLEN = 8000 STEPSPACE = 8000 [AXIS_Z] MIN_LIMIT = -10000.0 MAX_LIMIT = 10000.0 MAX_VELOCITY = 20 MAX_ACCELERATION = 100 [JOINT_2] TYPE = LINEAR MAX_VELOCITY = 20 MAX_ACCELERATION = 100 # Set Stepgen max 20% higher than the axis STEPGEN_MAX_VEL = 24 STEPGEN_MAX_ACC = 120 BACKLASH = 0.004 SCALE = 400 MIN_LIMIT = -10000.0 MAX_LIMIT = 10000.0 FERROR = 0.050 MIN_FERROR = 0.005 #HOME = 0.000 #HOME_OFFSET = 0.10 #HOME_SEARCH_VEL = 0.10 #HOME_LATCH_VEL = -0.01 #HOME_USE_INDEX = YES #HOME_IGNORE_LIMITS = YES HOME_SEQUENCE = 0 # these are in nanoseconds DIRSETUP = 200 DIRHOLD = 200 STEPLEN = 8000 STEPSPACE = 8000 [HOSTMOT2] DRIVER=hm2_eth BOARD_IP=192.168.1.121 BOARD=7i96s CONFIG="num_encoders=1 num_pwmgens=0 num_stepgens=5 sserial_port_0=0000"
My HAL:
# HAL file for HostMot2 with 3 steppers # # Derived from Ted Hyde's original hm2-servo config # # Based up work and discussion with Seb & Peter & Jeff # GNU license references - insert here. www.linuxcnc.org # # # ######################################## # Firmware files are in /lib/firmware/hm2/7i43/ # Must symlink the hostmot2 firmware directory of sanbox to # /lib/firmware before running EMC2... # sudo ln -s $HOME/emc2-sandbox/src/hal/drivers/mesa-hostmot2/firmware /lib/firmware/hm2 # # See also: # <www.linuxcnc.org/docs/devel/html/man/man...ml#config%20modparam> # and wiki.linuxcnc.org/cgi-bin/emcinfo.pl?HostMot2 # # ##################################################################### # ################################### # Core EMC/HAL Loads # ################################### # kinematics loadrt [KINS]KINEMATICS # motion controller, get name and thread periods from ini file loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS # hostmot2 driver loadrt hostmot2 # load low-level driver loadrt [HOSTMOT2](DRIVER) board_ip=[HOSTMOT2](BOARD_IP) config=[HOSTMOT2](CONFIG) # load estop latch component loadrt estop_latch # ################################################ # THREADS # ################################################ addf hm2_[HOSTMOT2](BOARD).0.read servo-thread addf motion-command-handler servo-thread addf motion-controller servo-thread # revel in the free time here from not having que run PID addf hm2_[HOSTMOT2](BOARD).0.write servo-thread addf estop-latch.0 servo-thread # ###################################################### # Axis-of-motion Specific Configs (not the GUI) # ###################################################### # ################ # X [0] Axis # ################ # axis enable chain newsig emcmot.00.enable bit sets emcmot.00.enable FALSE net emcmot.00.enable <= joint.0.amp-enable-out net emcmot.00.enable => hm2_[HOSTMOT2](BOARD).0.stepgen.00.enable # position command and feedback net emcmot.00.pos-cmd <= joint.0.motor-pos-cmd net emcmot.00.pos-cmd => hm2_[HOSTMOT2](BOARD).0.stepgen.00.position-cmd net motor.00.pos-fb <= hm2_[HOSTMOT2](BOARD).0.stepgen.00.position-fb net motor.00.pos-fb => joint.0.motor-pos-fb # timing parameters setp hm2_[HOSTMOT2](BOARD).0.stepgen.00.dirsetup [JOINT_0]DIRSETUP setp hm2_[HOSTMOT2](BOARD).0.stepgen.00.dirhold [JOINT_0]DIRHOLD setp hm2_[HOSTMOT2](BOARD).0.stepgen.00.steplen [JOINT_0]STEPLEN setp hm2_[HOSTMOT2](BOARD).0.stepgen.00.stepspace [JOINT_0]STEPSPACE setp hm2_[HOSTMOT2](BOARD).0.stepgen.00.position-scale [JOINT_0]SCALE setp hm2_[HOSTMOT2](BOARD).0.stepgen.00.maxvel [JOINT_0]STEPGEN_MAX_VEL setp hm2_[HOSTMOT2](BOARD).0.stepgen.00.maxaccel [JOINT_0]STEPGEN_MAX_ACC setp hm2_[HOSTMOT2](BOARD).0.stepgen.00.step_type 0 # ################ # Y [1] Axis # ################ # axis enable chain newsig emcmot.01.enable bit sets emcmot.01.enable FALSE net emcmot.01.enable <= joint.1.amp-enable-out net emcmot.01.enable => hm2_[HOSTMOT2](BOARD).0.stepgen.01.enable # position command and feedback net emcmot.01.pos-cmd <= joint.1.motor-pos-cmd net emcmot.01.pos-cmd => hm2_[HOSTMOT2](BOARD).0.stepgen.01.position-cmd net motor.01.pos-fb <= hm2_[HOSTMOT2](BOARD).0.stepgen.01.position-fb net motor.01.pos-fb => joint.1.motor-pos-fb # timing parameters setp hm2_[HOSTMOT2](BOARD).0.stepgen.01.dirsetup [JOINT_1]DIRSETUP setp hm2_[HOSTMOT2](BOARD).0.stepgen.01.dirhold [JOINT_1]DIRHOLD setp hm2_[HOSTMOT2](BOARD).0.stepgen.01.steplen [JOINT_1]STEPLEN setp hm2_[HOSTMOT2](BOARD).0.stepgen.01.stepspace [JOINT_1]STEPSPACE setp hm2_[HOSTMOT2](BOARD).0.stepgen.01.position-scale [JOINT_1]SCALE setp hm2_[HOSTMOT2](BOARD).0.stepgen.01.maxvel [JOINT_1]STEPGEN_MAX_VEL setp hm2_[HOSTMOT2](BOARD).0.stepgen.01.maxaccel [JOINT_1]STEPGEN_MAX_ACC setp hm2_[HOSTMOT2](BOARD).0.stepgen.01.step_type 0 # ################ # Z [2] Axis # ################ # axis enable chain newsig emcmot.02.enable bit sets emcmot.02.enable FALSE net emcmot.02.enable <= joint.2.amp-enable-out net emcmot.02.enable => hm2_[HOSTMOT2](BOARD).0.stepgen.02.enable # position command and feedback net emcmot.02.pos-cmd <= joint.2.motor-pos-cmd net emcmot.02.pos-cmd => hm2_[HOSTMOT2](BOARD).0.stepgen.02.position-cmd net motor.02.pos-fb <= hm2_[HOSTMOT2](BOARD).0.stepgen.02.position-fb net motor.02.pos-fb => joint.2.motor-pos-fb # timing parameters setp hm2_[HOSTMOT2](BOARD).0.stepgen.02.dirsetup [JOINT_2]DIRSETUP setp hm2_[HOSTMOT2](BOARD).0.stepgen.02.dirhold [JOINT_2]DIRHOLD setp hm2_[HOSTMOT2](BOARD).0.stepgen.02.steplen [JOINT_2]STEPLEN setp hm2_[HOSTMOT2](BOARD).0.stepgen.02.stepspace [JOINT_2]STEPSPACE setp hm2_[HOSTMOT2](BOARD).0.stepgen.02.position-scale [JOINT_2]SCALE setp hm2_[HOSTMOT2](BOARD).0.stepgen.02.maxvel [JOINT_2]STEPGEN_MAX_VEL setp hm2_[HOSTMOT2](BOARD).0.stepgen.02.maxaccel [JOINT_2]STEPGEN_MAX_ACC setp hm2_[HOSTMOT2](BOARD).0.stepgen.02.step_type 0 # # The Mesa AnyIO output pins can be in open-drain mode (drive low, float # high) or push/pull mode (drive low, drive high). # # When a logical output is 1 in open-drain mode, the FPGA lets the pin # float and it gets pulled high to +5V via a 10K resistor. # # When a logical output is 1 in push/pull mode, the FPGA pushes the pin # high but only to +3.3V. This is problematic on some kinds of inputs. # #setp hm2_[HOSTMOT2](BOARD).0.gpio.048.is_opendrain 1 #setp hm2_[HOSTMOT2](BOARD).0.gpio.049.is_opendrain 1 #setp hm2_[HOSTMOT2](BOARD).0.gpio.054.is_opendrain 1 #setp hm2_[HOSTMOT2](BOARD).0.gpio.055.is_opendrain 1 #setp hm2_[HOSTMOT2](BOARD).0.gpio.060.is_opendrain 1 #setp hm2_[HOSTMOT2](BOARD).0.gpio.061.is_opendrain 1 # ################################################## # Standard I/O Block - EStop, Etc # ################################################## # A basic estop loop that only includes the hostmot watchdog. net user-enable iocontrol.0.user-request-enable => estop-latch.0.reset net enable-latch estop-latch.0.ok-out => iocontrol.0.emc-enable-in net watchdog hm2_[HOSTMOT2](BOARD).0.watchdog.has_bit => estop-latch.0.fault-in # create signals for tool loading loopback net tool-prep-loop iocontrol.0.tool-prepare => iocontrol.0.tool-prepared net tool-change-loop iocontrol.0.tool-change => iocontrol.0.tool-changed
(Use CL57T stepper drivers)
  • thanks for the help
26 Oct 2025 19:56
Replied by thanks for the help on topic Manual tool change + tool lengh touch off
So no need for the tool table to populate?  I think I have it running correct now....I was able to have a long reference tool to establish a G54 offset, I called a TXM6 for a short tool, and with that short tool I called it back to G54 and it hit the z target correct.  As long as I know not to look for a tool in the tool table I think I good for this part unless you think I am missing anything?
On a side note, I have another switch wired up to set my z offset "my G54" that is mobile, meaning I can set it anywhere on the table to establish my initial z offset, but I don't know where to find the code or how to initiate the probing cycle to make that happen, can someone point me in a direction to make that happen?
Thanks again for all the help!!!!!  I'm excited to get this thing working!!!!!!!
  • scotta
  • scotta's Avatar
26 Oct 2025 19:53
Replied by scotta on topic Remora with STM32H753ZI
Here you go
github.com/remora-cnc/Remora-STM32H7xx-PIO
It even has TMC5160 support. Work has slowed a bit as we're porting over the F4, but the H7 is running.
  • scotta
  • scotta's Avatar
26 Oct 2025 19:50
The A and B channels should be connected to PE9 and PE11, index to PE13. So that looks correct. It should work, but I have not played with the QEI for ages.
  • boksi
  • boksi
26 Oct 2025 19:47 - 26 Oct 2025 19:49
Thanks both on suggestions, I see, checked both links quickly.
Have a question on principal level.
I need to have in fpga both uart component and quadrature enc component.
In order to work enc reading, first enc input pins should be connected to fpga input uart pins and then via some logic/demux this pins needs to be routed to quadrature logic in order to get inc pulses and also there is need to issue select signals on this demux after uart transfer sequence is finished.
Or other way, enc pins are connected to both uart and quadrature module components inside fpga but enable signals of both components are separately controlled via some conditions/logic.
Is this working this way or?
  • scotta
  • scotta's Avatar
26 Oct 2025 19:39
Remora SPI: Bad SPI payload, estop won’t reset, SKR 1.4 + RPi4 – config below
The SKR1.4 and LPC1768 are legacy and not supported in the latest version of the Remora component. You could try to use an older version of the component that supports the LPC1768.
Displaying 12241 - 12255 out of 12369 results.
Time to create page: 2.885 seconds
