  • DerKlotz
  • DerKlotz
09 Oct 2025 16:10 - 09 Oct 2025 16:14
Strange behavior Mesa 7i76e - FU YL-620A Speedvoltage
Category: Configuration Tools
I found it at pncconf and unchecked "Require homing before MDI/Running". Now it works.
Thanks a lot!
  • PCW
  • PCW's Avatar
09 Oct 2025 16:05
Try setting the HOME_SEARCH_VEL and HOME_LATCH_VEL to 0
  • DerKlotz
  • DerKlotz
09 Oct 2025 16:00
I did it at all Joints like this
[JOINT_0]
NO_FORCE_HOMING = 1
and restarted Linuxcnc but i still get the error not "homed"
  • PCW
  • PCW's Avatar
09 Oct 2025 15:49
You can temporarily disable homing by setting
NO_FORCE_HOMING = 1
 in all joint sections of the.ini file
  • DerKlotz
  • DerKlotz
09 Oct 2025 15:32
At the moment i´m not able to do a homing in Linuxcnc. If i try a MDI command it says home all axes...
  • PCW
  • PCW's Avatar
09 Oct 2025 15:29
That looks OK
Does the spindle speed control work at all. that is,
does MDI command M3 S12000 give you about 12000 RPM
and ~5V output?
  • DerKlotz
  • DerKlotz
09 Oct 2025 14:51
Hope these are the right files. Iḿ a newbie
  • PCW
  • PCW's Avatar
09 Oct 2025 14:47
  • Aciera
  • Aciera's Avatar
09 Oct 2025 14:30
Replied by Aciera on topic REMAP=M6 modalgroup=6 python=atc_toolchange
Your last test file works fine for me.
Sounds like you might not have things set up right in your ini file.
Do you have TOPLEVEL defined correctly in the [PYTHON] section (your path might be different):
[PYTHON]
PATH_PREPEND= python
# import the following Python module
TOPLEVEL= python/toplevel.py
  • DerKlotz
  • DerKlotz
09 Oct 2025 14:12 - 09 Oct 2025 14:14
Hello,I can't get my spindle with frequency converter YL-620A and Mesa7i76e to rotate. Homing is not working at the moment because the mechanical and electrical components have not yet been connected.
Pin 1 Spindle- to GND
Pin 2 Spindle out to VI1
Pin 3 Spindle+ to 10V
Pin 5 Spindle Ena- to XGND
Pin 6 Spindle Ena+ to FWD
Pin 7 Spindle Dir- to XGND
Pin 8 Spindle Dir+ to REV
In Linuxcnc, I can press the forward, reverse, and stop buttons, and this is also displayed correctly on the frequency converter. When I press the forward button, I measure a fluctuating voltage between approximately 0.65V and 0.9V between pin 2 and pin 1. There is 10V between pin 3 and pin 1. Without starting Linuxcnc, I measure 0V between pin 2 and pin 1. I have already increased the parameter P03.06 and decreased P03.07. Unfortunately, there has been no change.
Help
  • DerKlotz
  • DerKlotz
09 Oct 2025 11:20
Spindel über Mesa 7i76e ohne Homing ansteuern
Category: Deutsch
Hallo,
ist es möglich unter Linuxcnc die Spindel (mit FU YL-620A) über eine Mesa 7i76e anzusteuern, ohne die Achsen zu homen? Elektronik und Mechanik sind noch nicht verheiratet. Geht das über Halshow? Wenn ja, wie? Die Spindel läuft über das Poti vom FU problemlos. Habe dann die Parameter für externe Steuerung angepasst... hier hänge ich jetzt fest.
Dank euch
  • Hakan
  • Hakan
09 Oct 2025 10:17
Replied by Hakan on topic Config-Problem Ethercat
Category: Deutsch
Yes, I see the difference in refclocksynccycles and assignActivate, that's most likely it.
I seem to recall the erc60 only works with DC sync mode, that is set assignActivate=300.
  • DerKlotz
  • DerKlotz
09 Oct 2025 08:42
Homing Cycle deaktivieren und Achsen von Hand Nullen
Category: Deutsch
Hallo,
beschäftige mich gerade als Neuling mit der Thematik und würde auch gerne das Homing abschalten, da der Elektronik und Mechanikteil noch nicht verheiratet sind. In welcher ini muss ich das wo einsetzen?
Danke euch
  • DerKlotz
  • DerKlotz
09 Oct 2025 08:05 - 09 Oct 2025 08:58
Replied by DerKlotz on topic Set GPIOś via Halshow
Category: HAL
I just set pin 17 to flood and pin 18 to mist. Then the relays work...
So how can i set the pins to Digital out and control then via Linuxcnc. Can i create new buttons in Linuxcnc?
  • TripleM
  • TripleM
09 Oct 2025 07:25
Replied by TripleM on topic Gmoccapy 3.5.1
Gmoccapy 3.5.1
Category: Gmoccapy
Firstly, I have already implemented a solution for checking the tool table . If this seems useful for others, we could consider integrating this function directly into Gmoccapy.
I would also find it useful if there were an additional option available for each tool in the tool table—for example, a checkbox or drop-down menu for the direction of rotation (CW or CCW).  This would make it easy to determine the required direction of rotation for each tool and eliminate errors caused by incorrect rotation.
Displaying 12586 - 12600 out of 13403 results.
Time to create page: 1.357 seconds
