  • Cooped-Up
  • Cooped-Up
07 Oct 2025 10:38
Replied by Cooped-Up on topic 5i25t firmware screwup
Category: Driver Boards
Okay I remember there was a section in the CNC panel for tools and hal stuff so I poked around there and found the specific call-out I need to address the 7i84. I'm starting to get excited as I was able to make something actually happen finally. I controlled an output on the 84 for "coolant" now I just need to add all of the lines for my machine and wire everything. I will likely return with more issues but I will probably make a new topic mostly for tracking my progress.
  • Cooped-Up
  • Cooped-Up
07 Oct 2025 10:27
I have a new section in the error codes where it does say it can see the 7i84. So it must be my call-out for the pins are incorrect. I am referencing a project where the guy had his 84 wired to his 7i77 but I am using the 7i74 to communicate with the 7i84 and 7i73. Is the pin call-out different currently it is "HM2_5i25.0.7i84.0.2.output-10"
  • Cooped-Up
  • Cooped-Up
07 Oct 2025 10:14
I decided I didn't like the looks of the Ethernet cable I was using so I went and grabbed 2 different ones to try. When I plugged it in a new yellow light turned on and when I launched the CNC page it blinked green a few times before giving me the same error pins on 7i84 don't exist.
  • partec
  • partec
07 Oct 2025 10:06
Very small 4 axis mill for cutting plastic materials
Category: Show Your Stuff
I saw the question and you have now attached exactly the relevant files. Thanks, I'll be happy to think about it!
  • my1987toyota
  • my1987toyota's Avatar
07 Oct 2025 09:57
Replied by my1987toyota on topic ARE YOU KIDDING ME YOUTUBE !!!
OK. Best of luck Rod.
  • Cooped-Up
  • Cooped-Up
07 Oct 2025 09:54
No I didn't get a blinking green light, the 7i77 flickered a few times and went back to red.
  • DerKlotz
  • DerKlotz
07 Oct 2025 09:37
Mesa 7i76e -> problem to activate TB5 and TB6
Category: PnCConf Wizard
Hello,
iḿ a newbie (from Germany) and i just build a new mill. Now I want to configure my Mesa 7i76e. However, I can't get TB5 and TB6 to activate. Just TB2/TB3, P1 and P2 are visible.
Please help
  • Gartenzwerg
  • Gartenzwerg
07 Oct 2025 09:06
Replied by Gartenzwerg on topic Tipps für aktuelle LinuxCNC Hardware gesucht
Category: Deutsch
Danke, das ist schon mal ein Ansatz!
Im Moment sehe ich da zwei Möglichkeiten:
- Raspberry Pi 5 + ein Parallel Hat von byte2bot
byte2bot.com/products/parallel-port-rasp...gak8F2DJq1o7WoFK2x-g
Verstehe ich das richtig, dass damit die Erzeugung der Signale die an meine Fräse gesendet werden im Raspberry stattfindet, und somit von der Systemauslastung, Latenz, etc.. abhängt?
- Raspberry Pi 5 + MESA 7C81
Während hier die Signale in/von der Mesa Karte erzeugt werden?
In beiden Fällen muss ich die .hal Dateien so anpassen dass die korrekten Pins angesprochen werden, das ist mir klar.
Aber funktioniert das grundsätzlich so, oder liege ich daneben?
  • Hakan
  • Hakan
07 Oct 2025 09:05
Replied by Hakan on topic Config-Problem Ethercat
Category: Deutsch
I assume the ERC60 just reports back the commanded position as actual position, without knowing if it lost steps.
Have you verified with halshow that  joint.2.motor-pos-fb =cia402.2.pos-cmd and cia402.2.drv-actual-position = lcec.0.5.actual-position?
  • Hakan
  • Hakan
07 Oct 2025 08:51 - 07 Oct 2025 12:55
Issue with OP Entry Delay and Failures in LinuxCNC + EtherCAT System
Category: EtherCAT
That looks like the situation I had yesterday. Traced it to a bad kernel (I think I traced it there).
I upgraded the kernel to latest 6.12-48 and all problems went away.
  • Hakan
  • Hakan
07 Oct 2025 08:48 - 07 Oct 2025 12:55
Ethercat drives not responding, mesa error finishing read
Category: EtherCAT
I got lot's of errors yesterday and going in and out of PREOP.
It might have been a bad kernel. I upgrade to latest 6.12-48 and the problems went away.
Think the bad one was 6.12-38.
  • Hakan
  • Hakan
07 Oct 2025 08:45
Replied by Hakan on topic Important EtherCAT configuration option
Category: EtherCAT
Got that too yesterday. Traced it to a bad kernel think it was 6.14-38 or so. Upgrade the kernel is my advice.
  • laurentl38
  • laurentl38
07 Oct 2025 07:24
Replied by laurentl38 on topic orient spindle with ethercat EL5101
Category: EtherCAT
Well, I just found another mistake.
My spindle driver only has two pins: forward and reverse; it doesn't have an enable pin.
And I had wired spindle.0.on to the driver's forward pin instead of spindle.0.forward.
The good news is that the PID speed still works fine.
The bad news is that the orientation doesn't move at all anymore, nothing...
File Name: EL7-schaublin-282.hal
File Size:11 KB
  • heaven
  • heaven
07 Oct 2025 06:22 - 07 Oct 2025 06:22
Replied by heaven on topic Important EtherCAT configuration option
Category: EtherCAT
Today i tried active DC mode on and linuxcnc keep spamming this error:
Failed to get reference clock time: Input/output error
What causes this error? I'm using Linuxcnc 2.9.4 install from iso file.Here is my xml file and driver document:
drive.google.com/file/d/1ZTNpSNYDF0IL-IE...Bn4/view?usp=sharing
File Name: da180_2025-10-07.xml
File Size:1 KB
  • Red_D85
  • Red_D85
07 Oct 2025 05:04
Replied by Red_D85 on topic Config-Problem Ethercat
Category: Deutsch
Das Problem hab ich gefunden nur keine idee wie ich es umgehen kann. Es wird ein Feedback vom Motor/Encoder erwartet aber der ECR60 hat keinen. Hat jemand einen Lösungsvorschlag um das zu umgehen?
Displaying 13066 - 13080 out of 13202 results.
Time to create page: 0.403 seconds
