  • PCW
  • PCW's Avatar
19 Sep 2025 19:18
Replied by PCW on topic RPi5 Scale settings
RPi5 Scale settings
Category: Basic Configuration
Are you sure it is not stalling because your accel/velocity values are too high?
if the distance moved with a 100 mm command is not inversely proportional
to the scale, the hardware is not following the  command.
500 mm/s is way faster than is possible.
Even at 300 steps per mm, 500 mm/s  needs a 150 KHz step rate, but your base thread
period limits you to only about 5KHz (5 KHz = about 16.6 mm/sec at 300 steps/mm)
  • scsmith1451
  • scsmith1451's Avatar
19 Sep 2025 18:50
Linear Move Exceeds Lower Limit was created by scsmith1451
I am trying to create a simple subroutine to surface a block before engraving. It originally complained about an EOF in the file so I decided to execute each move command individually using MDI to make sure the code was correct.
Here the snippet that is giving an error:
    G0 X2.144 Y-0.125   (Move to start)
    G0 Z-0.02           (Lower spindle)
    G91             (Relative Moves)
    G0 X-11.163     (Make cut)
    G90             (Absolute Moves)
    G0 Y1.6921      (Move Y for next cut)
   -- -> G0 X11.163      (Make cut) <---
    G0 Y3.5092      (Move Y for next cut)
    G0 Z0.1         (Move to safe height)
At the line indicated --->  <--- LCNC reports an error to the effect that Linear Move will exceed limits of the machine.  The program zero is located at the right-front corner of the block. Since I could move to the starting location in line 1 and do the first cut to "G0 X-11.163" which is negative, I naively expected moving opposite direction the same distance would be acceptable.
The block, 3.25 x 7.00 in., is located in the center of the 19 x 11 in. table with ample space on all sides for the 2 in. surfacing mill to clear the block. Fortunately, this was my first attempt to use LCNC on this machine so I was cutting air for the test, so no material was damaged.
Can someone help explain the error and how to resolve it?
Kind Regards,
  • scsmith1451
19 Sep 2025 18:32
Arrow keys for jogging was created by scsmith1451
Category: Gmoccapy
The GMOCCAPY documentation indicates that the arrow-keys, pg-up, pg-down are enabled by default, however, they are not responding on my installation from the main screen. I've looked for a configuration parameter to enable them, but the only key I found disables all hot keys, not just the jog keys. Am I doing something wrong or did I miss something in the documentation?
  • krille
  • krille
19 Sep 2025 17:29
RPi5 Scale settings was created by krille
RPi5 Scale settings
Hi I has problem with my setup  ini file  I do not understand the behavior of this if I use 200 step for the scale in my z axle and then G0Z-100 and the movment stop at 40 mm
step 300 = 60 mm
step 400 =  81mm
step 500 = 78 mm
step 600 = 59 mm
Why can´'t I hit 100 mm in my set up I tryed many diferent value of steps with 50 increasment
computer = Raspberry Pi 5 ,breakoutboard db25 cinese make , stepperdriver DM542  , 1/4 800 steps , motors 200 steps
are there any kind to help me in the right direction
yours sinserly Krister
File Name: my-lathe.hal
File Size:5 KB
File Name: my-lathe.ini
File Size:2 KB
  • BorisMatris
  • BorisMatris
19 Sep 2025 15:37
Looking for a freelancer to help me with my project?
Category: User Exchange
I am looking for someone who would help me with my LinuxCnc project. We use laser welding to weld electric motor shaft before grinding. I am at the end but some small issues I can't resolve. If there is someone who can spare some time and help( I am willing to pay) would be much appriciated.
Boris
19 Sep 2025 13:57
Replied by tommylight on topic Firmware Request for 7i92 – Plasma CNC Build
Category: Driver Boards
1 Yes
2 Yes
3 Yes
4 Yes, if you do not use any encoders
5 Yes
  • souh-hil
  • souh-hil's Avatar
19 Sep 2025 13:50
Replied by souh-hil on topic Firmware Request for 7i92 – Plasma CNC Build
Hi all,Thanks in advance to everyone who responds!I’m using the following HostMot2 bitfile for my Mesa 7i92:
BoardName : MESA7I92
FPGA Size: 9 KGates
FPGA Pins: 144
Number of IO Ports: 2
Width of one I/O port: 17
Clock Low frequency: 100.0000 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: DPLL
There are 1 of DPLL in configuration
Version: 0
Registers: 7
BaseAddress: 7000
ClockFrequency: 100.000 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
There are 2 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: QCount
There are 6 of QCount in configuration
Version: 2
Registers: 5
BaseAddress: 3000
Module: StepGen
There are 5 of StepGen in configuration
Version: 2
Registers: 10
BaseAddress: 2000
Module: PWM
There are 1 of PWM in configuration
Version: 0
Registers: 5
BaseAddress: 4100
ClockFrequency: 200.000 MHz
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for P2
Pin#  I/O   Pri. func    Sec. func       Chan      Pin func        Pin Dir
 1      0   IOPort       PWM              0        PWM             (Out)
14      1   IOPort       None
 2      2   IOPort       StepGen          0        Step/Table1     (Out)
15      3   IOPort       None
 3      4   IOPort       StepGen          0        Dir/Table2      (Out)
16      5   IOPort       StepGen          4        Step/Table1     (Out)
 4      6   IOPort       StepGen          1        Step/Table1     (Out)
17      7   IOPort       StepGen          4        Dir/Table2      (Out)
 5      8   IOPort       StepGen          1        Dir/Table2      (Out)
 6      9   IOPort       StepGen          2        Step/Table1     (Out)
 7     10   IOPort       StepGen          2        Dir/Table2      (Out)
 8     11   IOPort       StepGen          3        Step/Table1     (Out)
 9     12   IOPort       StepGen          3        Dir/Table2      (Out)
10     13   IOPort       None
11     14   IOPort       QCount           0        Quad-A          (In)
12     15   IOPort       QCount           0        Quad-B          (In)
13     16   IOPort       QCount           0        Quad-IDX        (In)
IO Connections for P1
 1     17   IOPort       QCount           1        Quad-A          (In)
14     18   IOPort       QCount           1        Quad-B          (In)
 2     19   IOPort       QCount           1        Quad-IDX        (In)
15     20   IOPort       QCount           2        Quad-A          (In)
 3     21   IOPort       QCount           2        Quad-B          (In)
16     22   IOPort       QCount           2        Quad-IDX        (In)
 4     23   IOPort       QCount           3        Quad-A          (In)
17     24   IOPort       QCount           3        Quad-B          (In)
 5     25   IOPort       QCount           3        Quad-IDX        (In)
 6     26   IOPort       QCount           4        Quad-A          (In)
 7     27   IOPort       QCount           4        Quad-B          (In)
 8     28   IOPort       QCount           4        Quad-IDX        (In)
 9     29   IOPort       QCount           5        Quad-A          (In)
10     30   IOPort       QCount           5        Quad-B          (In)
11     31   IOPort       QCount           5        Quad-IDX        (In)
12     32   IOPort       None
13     33   IOPort       None
  1. I only need 4 axes (X, Y1, Y2, Z). Can I use the last StepGen for torch on and laser pointer outputs?
  2. I do not need encoders. Can I use the QCount pins as general-purpose inputs?
  3. Can I use the pins labeled “None” or “unassigned” in the bitfile as inputs or outputs, depending on their pin direction?For example, pins 10 and 15 as inputs, and pin 14 as output?
  4. Are pins 13 and 15 on P2 free to use as I/O?
  5. My breakout board has 5 inputs labeled P10, P11, P12, P13, and P15. Can I use all of them as inputs
thanks again to everyone who helps!Best regards,
  • alexandrap
  • alexandrap
19 Sep 2025 13:30 - 20 Sep 2025 13:55
Replied by alexandrap on topic My MESA 7i95T wiring
yes, I just needed to make sure
Info : By measuring I found that between the encoder inputs A-A/,B-B/,Z-Z/ there is a resistance of 120 Ohm, they are already integrated in the MESA card. So additional resistors are not needed. I did not find information about this in the manual
  • RobotMatic
  • RobotMatic's Avatar
19 Sep 2025 12:30
Replied by RobotMatic on topic 7i76E Spindle configuration
Category: PnCConf Wizard
I need to work more organized!!
Thank you for all the help you gave me!!! I am going out to configure the VFD so I can finish the machine, I am under a lot of pressure!! Thank you!!!!!
  • alexandrap
  • alexandrap
19 Sep 2025 11:52 - 10 Oct 2025 17:21
My MESA 7i95T wiring was created by alexandrap
 EDIT:
tested functionality: step-dir servo X,Y,Z
step-dir spindle
MPG
untested:
probe
limit switch
linear ruler and encoder spindle
it is possible to configure all these functions on the 7i95T board using PNCCONFG  in LinuxCNC 2.10 (with the need for simple manual editing of the HAL file for MPG -axes switch)
not yet tested - I'm worried that I connected it wrong - it's my first experience with MESA
I'd be happy for any comments
I'm not sure if I should ground the shielding of the servo motor data cables to the MESA board - the drivers are already grounded via the ground wire from the ~ 230 V power supply and a ground loop is created, which could cause EMC interference
more details on my channel :
www.youtube.com/channel/UC_zOVvs96VKX6R_DIO5KyJg
This browser does not support PDFs. Please download the PDF to view it: Download PDF
  • csreades
  • csreades
19 Sep 2025 10:29
Recommendations for a dual NIC SBC or mini-pc
Category: EtherCAT
Initially I was considering using a RPi5, but my intention is for LCNC to be networked and not host the UI, instead I would use the second nic to recieve individual commands or whole files if/when needed.
There are hats, but it seems it is likely easier to get a PC, there have been some topics but it has been some time since then, does anyone have recommendations for the smallest formfactor solution with dual NIC? Ideally we would be priced similar to RPi, but I would be happy <€300.
(I know it was a few years ago but in the Marco reps video it seemed that he had a ncie solution, but I couldn't find details on his).
Displaying 13396 - 13406 out of 13406 results.
Time to create page: 0.759 seconds
