  • rodw
  • rodw's Avatar
16 Aug 2025 01:42
Set program zero using XY positioning laser
Sometimes you need to know where to looks in the docs. how to set a pin value from the ini file
linuxcnc.org/docs/html/config/ini-config.html#sub:ini:custom
  • rodw
  • rodw's Avatar
16 Aug 2025 01:37
How to set qtdragon to re-face my spoilboard
Category: Qtvcp
qtdragon has a facing option built in. Why not use that?
16 Aug 2025 01:03
getting started , latency and breakout board questions
OK, yank an LED from anything you have no use for, stick one pin of that LED in hole number 2 or 4 and the other pin touch the metal shield on the parallel port, now jog LinuxCNC with the keyboard and watch the LED light up ... dimly, set a faster feed rate and it will glow a bit more.
Yeah, make a simple config before doing that and start LinuxCNC so you have something to jog..
Or use the config picker by starting LinuxCNC from the menu and chose sample configurations> by_interface>parport>stepper>mm or inches
  • unknown
  • unknown
16 Aug 2025 00:45
Thought I'd chime in, there's also the option of a CPU upgrade, did wonders for the ThinkCentre I found in the gutter.
  • Chock
  • Chock
16 Aug 2025 00:43
thanks,   it does seem to be ok.    it will be a bit before i actually have some hardware to connect.    but i have been able to move the tool head around and PLAY the original linuxCnc gcode that traces LinuxCnc on the screen and the jog buttons are working.
i will catch up when i get some hardware,   hopefully  within a couple of weeks.   I wanted to start with a technic clearpath all in one servo, for the quill
have a good night, and thanks
16 Aug 2025 00:32
Replied by tommylight on topic How to set qtdragon to re-face my spoilboard
Category: Qtvcp
I might not be the "best" to answer this, but since i see you're head first into self destruction, leme help :) :
-QtDragon does not care about your spoil board, nor does FreeCAD
-... i am out ... :)
Back on topic, i can not recall what i used some 15 or more years back for that exact purpose, but i am sure it was free and Open Source, but:
forum.linuxcnc.org/20-g-code/42707-g-code-generators
wiki.linuxcnc.org/cgi-bin/wiki.pl?Simple...NC_G-Code_Generators
And most probably this will do just fine
github.com/LinuxCNC/simple-gcode-generators/tree/master/face
and the bunch here
github.com/LinuxCNC/simple-gcode-generators?tab=readme-ov-file
  • Revinvoss
  • Revinvoss's Avatar
16 Aug 2025 00:16
Category: Qtvcp
For the life of me, I can not find ANY useful info on how to re-face my spoilboard. Sure, I would have to buy hundreds of dollars to get a program to do what Qtdragon should be able to do with out that. I have FreeCAD but, I also seems to not have the means to do this. Is there any one here that knows how to make a G-code operated machine simply go back and forth at a set high across a set dimension?
As you guys will have questions, I will be glade to answer to get this spoilboard faced. before I burn it to the ground.
16 Aug 2025 00:01
Looks fine so far, move on! :)
There should be no issues with the BOB as long as your servo drives can accept step/dir control signals, or even quadrature or UP/DOWN.
  • Chock
  • Chock
15 Aug 2025 22:59 - 15 Aug 2025 23:06
thanks again for the help     this is what i have set up NOW,   exercised latency is as pictured,
Are there any Known problems with a C11G multifunction CNC board?    for AC servos?
thanks
  • Chock
  • Chock
15 Aug 2025 22:26 - 15 Aug 2025 22:37
i have disabled all the options in the above picture . the latency test is still early, but it looks much much better
OOPs   i read a snippet from somewhere that said it would be good to start on a single core and the add the cores if i need them?
i disabled the C1E, but not the C1,   i did not see C1 as De-selectable,   I will try again
i can change it back correct?
OK C state support is set to C1.
and multi core is RE-enabled
thanks very much for your help PCW.
i am re running latency test again,   i did not take a pick from a few minutes ago,  but i think the servo thread was under 10000, and the base thread was about 26000
  • PCW
  • PCW's Avatar
15 Aug 2025 22:14
yes, you want multicore processing enabled
You should also disable Cstates > C1
  • Chock
  • Chock
15 Aug 2025 22:01 - 15 Aug 2025 22:08
After a bit of luck i have managed to access a menu that has the hyper threading setting.   In the pic  i have disabled the top 2 options.    How about the rest of the settings in this menu?
  DO i need multi core processing??
Are these changes permanent or do I have to resett them every time i power cycle?
also i am double spacing these posts when i type, but when i submit the post ;   they get all squashed together.Is there a way to keep my double spacing so the post is easier to read?
  • scsmith1451
  • scsmith1451's Avatar
15 Aug 2025 20:47
Replied by scsmith1451 on topic Set program zero using XY positioning laser
Thanks rodw,
I've added the following to my .ini file:
[LASER]
laser-offset-x = -3.2017
laser-offset-y = -0.2124
I've tried several ways that I could think of to reference these values in the gvcp-panel.ui, as CALL parameters to the EMC_Action_MDI widget without success.  I've also tried to just reference them in the auto-xy-zero.ngc file called by the EMC_Action_MDI widget without success.
A review of the online documentation has not been helpful either.
What is the correct method to pass them to the ngc file for execution?
Kind regards,
  • Martin.L
  • Martin.L
15 Aug 2025 19:08 - 18 Aug 2025 06:10
Carousel ATC setup on Probe Basic was created by Martin.L
Category: QtPyVCP
Hi, after a couple of months I'm back on my Brother TC201 retrofit, Will post pictures soon. As a newbie with probe basic (and LCNC) I did my best to configure it but without luck, I guess I'm missing a big chunk of knowledge somewhere but cant figure out. here is my config, actually the ATC tab look like in the screenshot. Please point me somewhere
  • COFHAL
  • COFHAL
15 Aug 2025 19:06
Replied by COFHAL on topic AX58100
AX58100
Category: EtherCAT
Another thing I noticed is that when looking at the circuit diagram the +24 volt input is not connected to anything, the same on the PCB this pin is not connected either, only -24 volts is connected to the current limiting resistors at the inputs of the optocouplers of the inputs.
Displaying 13636 - 13650 out of 14177 results.
Time to create page: 0.360 seconds
