  • hitchhiker
  • hitchhiker
02 Aug 2025 12:53
7i92 PDM and a Spindledriver board that need 5v
Category: Basic Configuration
hi i get a issue...
i have an very old servo driver that needs a 5+ pdm signal about 10khz.
my card i use is a 7i92.. the pdm output is sinking on the 7i92.. correct?
what is the best way to convert it?
thanks
  • TheTinkeringMechanic1
02 Aug 2025 12:49 - 02 Aug 2025 12:51
Replied by TheTinkeringMechanic1 on topic Spindle speed?
Spindle speed?
Digging into a bit deeper, whenever I run it in reverse the setting jumps to 8.25 and stays there. If I run it forward it stays around 2.69 with some variation in the next 5 digits. It moves up and down with speed adjustment.
02 Aug 2025 12:18
Spindle speed?
This should work.
02 Aug 2025 12:05
Spindle speed?
Thank you for letting me know about halshow. There is a wealth of data in here that will be VERY helpful. Unfortunately, the image size exceeds allowable data limit so I can't attach them just yet. Looking into reducing the file size.
  • Mars
  • Mars
02 Aug 2025 11:10
Thanx and I sorry about changing subject line...didn't realize it created problems.
  • warwickben
  • warwickben
02 Aug 2025 06:18
Replied by warwickben on topic Mini pc recommendations?
I’ll test this out.
I ran the latency test before but wa slightly confused how to read them .
I think part of the issue I’m having is the crappy bios and not being able to disable things .
  • PCW
  • PCW's Avatar
02 Aug 2025 05:22
Replied by PCW on topic Spindle speed?
Spindle speed?
OK so fairly complex...
As I said before, maybe the first step is to take a look at
hm2_5i24.0.7i83.0.2.analogout0 in halshow when running
the spindle in each direction.
  • unknown
  • unknown
02 Aug 2025 04:36
Dear new Member please don't change the Subject when posting it renames the thread in the Index and makes it hard to find
  • unknown
  • unknown
02 Aug 2025 04:34
Replied by unknown on topic Mini pc recommendations?
4GB RPI5 is fine, if you are going to jump that way. But I'd be more inclined to look at the x86 offerings from Odroid. I've been using one for 4 or 5 years without an issue.
  • PCW
  • PCW's Avatar
02 Aug 2025 03:00 - 02 Aug 2025 05:13
W5100S-EVB-PICO stepgenerator and encoder driver
Category: Driver Boards
Sorry , I guess you are right, G33.1 also looks at the spindle speed
But this works better with good velocity estimation, Though as I mentioned
you cannot use position interpolation except for constant speed applications
like threading on a lathe.
This is wrong because the TP does use the velocity value:
It is precisely true, LinuxCNCs TP only looks at the encoders position
in G33.1 moves. There is no other information path.
Looking a bit more into this, It does not look like the encoder velocity
( spindle.spindle_num].spindleSpeedIn ) is used for position mode synchronized
moves (G33 G76 etc) but only velocity mode synchronized moves (G95).
At least with a quick look at  tp.c
  • tuxcnc
  • tuxcnc
02 Aug 2025 01:40
Velocity estimation is unrelated to G33.1 as G33.1 only looks at position.
It is not true.
Tool moves while spindle stops, even if position is reached.
  • DauntlessA
  • DauntlessA
02 Aug 2025 00:39
Replied by DauntlessA on topic Surfacemap Z compensation with Probe Basic
Category: QtPyVCP
I'm not too familiar with the integration into probe basic, but I'm pretty sure the surfacemap tab did work when it was released.
It's possible that posting your config might help narrow down any issues.
And can you show your halshow for the relevant pins when you believe it should be enabled?
Also, It is possible to use the compensation component standalone, with no involvement from probe basic, even if the process is slightly more manual.
Use the version from Scott's Repo and follow the instructions there:
github.com/scottalford75/LinuxCNC-3D-Pri.../master/compensation
For PCB milling, I think that this compensation component should work really well. Since the component is taking the current XY point and outputting compensation in Z, it's always 'playing catch-up' as the machine moves, but unless you're demanding very quick changes in the compensated value (think feeding fast over a rough surface) any deviation in the compensated position isn't really much of an issue.
I haven't tried any other compensation approaches, but G-Code Ripper with the Auto-Probe operation can warp your G-Code to the probed surface.
The version bundled with LinuxCNC is located in the /usr/lib/python3/dist-packages/qtvcp/lib/ripper/ directory (and you can run it standalone if you want).
  • PCW
  • PCW's Avatar
02 Aug 2025 00:37
Replied by PCW on topic Mini pc recommendations?
It may be fixable
What servo thread period are you using?
what does:
sudo chart 99 ping -i .001 -q -c 60000 [7i96_ip_address]
report?
(it should run for 1 minute and report timing statistics, [7i96_ip_address] is the IP address of your 7I96S card)
Did you run a standard latency test?
02 Aug 2025 00:26
Spindle speed?
I believe I got them and then some.
  • PCW
  • PCW's Avatar
02 Aug 2025 00:24
If you do position interpolation, it's only for threading (Constant speed)
Also, as I mentioned, you need hardware timestamp support for velocity estimation.
Displaying 14071 - 14085 out of 14203 results.
Time to create page: 0.403 seconds
