  • PCW
  • PCW's Avatar
19 Jun 2025 23:45
Laser Head Height Sensor – Looking for a Beta Tester
Category: Plasma & Laser
It does make the resolution of the encoder frequency  a bit better than at 1 ms
but the periodm does not care as you specify the number of period averages.
19 Jun 2025 23:07
  • tuxcnc
  • tuxcnc
19 Jun 2025 22:48
Hi, which module have you been trying to use? The software Encoder module or the QDC module? Both support the index pulse detection and encoder count latching so LinuxCNC can acquire the index position count.
Hi.
QDC.
The encoder_raw code is good and there are only hardware problems (optocouplers and RC filters cut the bandwith).
But this is very bad idea to send encoder's index pulse by ethernet.
Let's make calculations.
3000 rpm and 1 ms base_thread is 18 degrees accuracy - not acceptable.
The solution is send not index, but raw_count lathed at encoder's index edge interrupt routine.
There is in your code, line 321 in qdc.cpp file:
this->indexCount = ENC_GetPositionValue(this->encBase);
But there is no indexCount hal pin...
In the fact, we don't need receive index pulse at component side, because change of indexCount means index was betwen last and present data transmision.
So we can update indexCount at every encoder's index edge, but use them only if hal index_enable pin is true. (look at my code).
I tried use raw_count and index pins connected to PRUencoder module. Sometimes it works, mostly not.
But even if it works, PRUencoder resets position to zero at received index, not at real index.
In my code, position is reset not to zero, but to
pos = (fb.raw_encoder - latched_enc) / pos_scale;
(raw_encoder may be not equal latched_enc)
So there is no delay.
In this case I not need PRUencoder, because I move pos and vel calculations to my component.
  • bcorley
  • bcorley
19 Jun 2025 22:44
Thanks for the info. From what I gather, reading previous posts, the periodm function requires linuxcnc 2.10. I'll have to make up another test unit for that. Also, I'm running a 2msec servo thread. Is that going to be an issue?
  • PCW
  • PCW's Avatar
19 Jun 2025 22:36
homing with Phase Z encoder on MESA 7i96s
None of these are needed and the first will likely mean
that you never get an index.
setp [HMOT](CARD0).encoder.00.index-mask 1
setp [HMOT](CARD0).encoder.00.index-invert 0
setp [HMOT](CARD0).encoder.00.index-mask-invert 0
The index mask logic is intended for configurations
that have a index mask input pin which is typically used
for spindles where the encoder is on the motor and the
spindle is geared down from the motor.
  • kworm
  • kworm
19 Jun 2025 22:33
Replied by kworm on topic QTPlasmac pierce delay handling
Category: Plasmac
The reed switch works great. Thanks for everyones help.
  • PCW
  • PCW's Avatar
19 Jun 2025 20:54
  • MaHa
  • MaHa
19 Jun 2025 20:49
ERROR: Linear movement in line xx would exceed the positive stop of the Z axis
When  HOME = 0,  MAX_LIMIT  should be greater than 0, to avoid get stoped by softlimit error
  • scotta
  • scotta's Avatar
19 Jun 2025 20:35
  • kubes
  • kubes
19 Jun 2025 20:28
Replied by kubes on topic How to jog when beyond soft limits
Category: EtherCAT
There are a few issues. Should we break them into new threads?
1. The discussed issue about being on or over a limit. The resolution/variance comments.
2. Axis UI will allow an AXIS to be moved back within limits, but Probe Basic does not
3. The docs state: "The [JOINT_N]MIN_LIMIT/MAX_LIMIT settings are enforced while jogging in joint mode prior to homing. After homing, [AXIS_L]MIN_LIMIT/MAX_LIMIT coordinate limits are used as constraints for axis (coordinate letter) jogging" but that is not the case. This is different for Probe Basic and Axis.
3a. Using the Axis UI, the JOINT MAX_LIMIT and MIN_LIMIT are ignored before homed, meaning no limits are enforced.
3b. Probe Basic seems to enforce the AXIS_L limit, whether homed or not
  • PCW
  • PCW's Avatar
19 Jun 2025 20:02
  The velocity range only seems to be around 6500 hz from 0-10mm (3/8")
That does seem quite small, maybe too much stray capacitance on the sensor?
The BCL-AMPs ~2.5 MHz /2 frequency of ~1.25 MHz only gives you about 1250
counts per 1 ms servo period which will end up adding quite a bit of noise.
 This may be improved if you set the hires-timestamp of the encoder true but
a better solution may to use the periodm's frequency output as it does frequency
estimation by 1/period_average:
forum.linuxcnc.org/plasma-laser/51568-in...e-sensor-to-linuxcnc
  • PCW
  • PCW's Avatar
19 Jun 2025 18:40
Replied by PCW on topic Lo ejes dejaron de moverse
7I97 or 7I96?
  • Johnnysacalu
  • Johnnysacalu
19 Jun 2025 18:32
Lo ejes dejaron de moverse was created by Johnnysacalu
Hola a todos soy muy novato en esto pero lo intento.
Monte un  plasma cnc con mesa 7i97s que consequi hacer que funcione bien hasta que le puse el thcad2, le hice solo 3 pruebas de antorcha y los motores ya no se mueven, save alguien si puede ser que se haya quemado la tarjeta 7i96. Se conecta a linux puedo encender antorcha pero no se como verificar cual puede ser el problema, gracias.
  • ttt
  • ttt
19 Jun 2025 17:58
How to link existing glass scale DRO readout to LinuxCNC for cheap
Category: Driver Boards
The ELS project I listed above is my design, yes. I've talked about it before here on this forum but interest seems low. Most people go for Clough42's much simpler+cheaper approach: github.com/clough42/electronic-leadscrew
My ELS system is LinuxCNC based with a web interface frontend. I use a 7i96 board which has only one encoder, hence this rp2040 based project.
My system also has X-axis steppers, not just a Z-axis stepper. One my goals is to be able to do NPT taper threads easily since I do this often and using dies is a PITA on stainless.
  • meister
  • meister
19 Jun 2025 17:42
no checksum for SPI, it's only for short distance. only the UDP and RS485/RS422 connections have checksum
Displaying 14791 - 14805 out of 15360 results.
Time to create page: 2.871 seconds
