  • PCW
  • PCW's Avatar
08 Jun 2025 02:59 - 08 Jun 2025 03:01
Mesa 7i95t connection to Thermal Dynamics 60i
Category: Plasma & Laser
100 mA is a typical value for 5V, at say 24V the current is much less for most contacts (closer to 10 mA)
A small capacitor across the contacts can provide the wetting current without a large constant load.
If the relay does not show closed at 24V, its likely faulty...
  • TheTinkeringMechanic1
08 Jun 2025 02:26
Replied by TheTinkeringMechanic1 on topic CNC lathe to grinder.
Category: Basic Configuration
This should be it.
File Name: Knuth.ini
File Size:4 KB
  • rodw
  • rodw's Avatar
08 Jun 2025 02:17
IO Questions around mixing IO between Ethercat and Pi 5?
Category: EtherCAT
Yeh, my post must have broke. If you look a bit harder on eBay you will find better priced moduled for around $130. Some want stupid money. Don;t be frightened of buying from other countries...
  • MaHa
  • MaHa
08 Jun 2025 02:07
Replied by MaHa on topic Position: relative expected
Failed again to leave my workshop early.
Sorry i am blessed with writing jam at the moment, but good luck for recovery from the injury
  • cmorley
  • cmorley
08 Jun 2025 02:02
Replied by cmorley on topic cam_align
cam_align
Category: Qtvcp
version 2.9.4 did not get the change, only master branch.
You will need to save over the camview_widget with the supplied version again.
  • jhandel
  • jhandel
08 Jun 2025 01:13
Category: EtherCAT
hey @rodw, was there something you wanted to add? looks like you just quoted my original post.... I know you have a lot of experience in this area, i have read more than a few of your posts so would love your input.
  • rodw
  • rodw's Avatar
08 Jun 2025 01:07
The pierce delay starts from the beginning of arcOK so the delay turning the torch on makes no difference.
The internal relay will need a minimum current of 100 mA and the Mesa board generally can't deliver this. You need to add a pull down resistor as discussed in the qtplasmac docs.
  • rodw
  • rodw's Avatar
08 Jun 2025 00:56
Replied by rodw on topic reference during rotorhoming
At the moment, rotorhoming starts when i power on the machine.
The problem is that i want to home the z-axis first.
HOME_SEQUENCE in ini
  • rodw
  • rodw's Avatar
08 Jun 2025 00:36
Replied by rodw on topic QTPlasmac pierce delay handling
Category: Plasmac
Unfortunately the relay in the unit is damaged and does not close. I ran through the diagnostics in the service manual to come to that conclusion and of course the service manual recommendation is to replace the inverter board which is half the cost of a new unit lol. It's also very difficult to access but some point down the road I will pull it apart and replace the relay on the board if possible. I'm going to try Tommy's suggestions and hopefully that will buy some time until I fix it or sell it and get another unit.
the most likely cause of a "damaged" relay is oxidisation because the current through the relay has  been below the minimum operating spec. Installing a HS10 1 K pulldown resistor is likely to fix the issue after a few operations once the oxide is burnt off. This is covered in the qtplasmac docs.
  • rodw
  • rodw's Avatar
08 Jun 2025 00:28
Feature Request: ramp piercing (aka moving piercing)
Category: Plasmac
new features go into master branch (2.10) so this will never be in 2.9.4
08 Jun 2025 00:14
Replied by tommylight on topic QTPlasmac pierce delay handling
Category: Plasmac
Get a "reed contact" or "reed relay", make some 3 turns of the clamp wire around it.
That is it, cheap simple and never fails.
I am sure it was in the PlasmaC documentation, no idea if it is in QtPlasmaC.
See attached.
  • kworm
  • kworm
08 Jun 2025 00:07
Replied by kworm on topic QTPlasmac pierce delay handling
Category: Plasmac
  • kworm
  • kworm
07 Jun 2025 23:59
Category: Plasmac
Sorry, I did see the previous post but it's from a year and a half ago. I guess I should have asked if it had been merged into 2.9.4 and/or master.
  • PCW
  • PCW's Avatar
07 Jun 2025 23:50
Replied by PCW on topic Mesa 7i97T & LinuxCNC setup struggles
Category: Installing LinuxCNC
Changing the PWM scale changes the scaling of all PID parameters.
That is, a P term of 10 with a PWM scale of 10 is the same as a P term
of 1 with a PWM scale of 1, In both cases an error of 1 mm generates a
full scale (+ or - 10V)
There is no reason on a torque mode drive to change the default
PWM scale of 10 (a scale of 10 means the PID output is scale in volts)
Displaying 15316 - 15330 out of 15472 results.
Time to create page: 0.629 seconds
