  • PCW
  • PCW's Avatar
09 May 2025 15:53
Replied by PCW on topic Real Time and Latency
LinuxCNC works identically to most CNC systems in that it outputs
a stream of joint/axis position coordinates (waypoints) at a fixed rate.
In LinuxCNC this rate is called the servo thread rate. This is typically
1 KHz in LinuxCNC but can be higher. In addition, either LinuxCNC or
downstream hardware interpolates between the position waypoints
so smooth motion is generated.
Simple LinuxCNC systems using a parallel port or GPIO do the interpolation
and step/dir generation with a second, faster real time thread, called the base thread.
More complex systems do the interpolation in external hardware or processors
(Mesa cards, Remora, RIO etc) or in the motor drive itself (EtherCAT) and typically
do not use a base thread.
  • ogogon
  • ogogon's Avatar
09 May 2025 15:49
Replied by ogogon on topic Real Time and Latency
The values for step & direction are part of the ini file and can be adjusted to suit many stepper driver products.
With a 25000 ns base thread motion will be based on this.
External motion control is usually based on a 1ms update period.
Hence the reason a known & steady latency is important, regularity is an important factor, like a band if the drummer isn't regular, uhmmm like Lars from Metallica, things don't work as well as they should.
Regarding the step value and the ini file. Correct me if I'm wrong, but its linear value is specified there, not the execution time. (When I set up my CNC, there was no talk about time.)
When we start discussing milliseconds, it means that we have accepted as a given the position about the need for parallel execution of commands on different axes.
Maybe this is true, but I do not yet fully understand the wisdom of this idea.
Where can I see materials about this?
  • vre
  • vre
09 May 2025 15:43
Replied by vre on topic NativeCam on LinuxCNC 2.9.3
Category: NativeCAM
How can use it with qtdragon_hd ?
Also the icons are missing from menus.
  • PCW
  • PCW's Avatar
09 May 2025 15:38
analog Servo spins on its own when connected to 7i77
Does the servo spin when LinuxCNC is not running?
  • ogogon
  • ogogon's Avatar
09 May 2025 15:32
What are you trying to do, exactly?
Einstein said that the basis of science is the flight from amaze. I am amazed and I trying to understand the meaning of what amazed me. This is important.
I have dealt with several professional control stations - Fanuc, Siemens. All of them issued control commands sequentially.
From you I learned that LinuxCNC uses a more progressive algorithm. Now I want to know about it.
  • Hakan
  • Hakan
09 May 2025 15:18
Replied by Hakan on topic Using POSIX realtime
Category: EtherCAT
I think it looks ok, maybe there is something with the exact kernel version and the module version but it should still work even with the "tainted" message.
We are just trying to find out why it doesn't work and make it work.
Actually, maybe the interface settings.
You showed some screenshots early in the thread with IPv4 settings and more.
Actually, ethercat and IPv4 are not compatible and one should not configure any IPv4 things on the interface.
On my system, the ethercat interface doesn't even show up on the first screen of that application that lists the interfaces.
This is how my interface is started, in /etc/network/interfaces
auto enp2s0
iface enp2s0 inet manual
        hardware-irq-coalesce-rx-usecs 0
        pre-up /sbin/ifconfig $IFACE up
        post-down /sbin/ifconfig $IFACE down
That hardware-irq-coelesce setting is a Intel card setting.
The output of my ethercat interface fromthe commadn "ip a"
4: enp2s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
    link/ether c4:62:37:06:66:54 brd ff:ff:ff:ff:ff:ff
    inet6 fe80::c662:37ff:fe06:6654/64 scope link
       valid_lft forever preferred_lft forever
no ipv4 address
  • Todd Zuercher
  • Todd Zuercher's Avatar
09 May 2025 15:04
Replied by Todd Zuercher on topic analog Servo spins on its own when connected to 7i77
Look at the command output signals from hal. Are they zero before you "plug in" the servo? If they are zero, is the voltage at the analog out pins zero? Double check your wiring?
  • PCW
  • PCW's Avatar
09 May 2025 14:53
Can I have 2 seperate interfaces on the same computer?
To retain your old system, it might be simplest to install the 2.9.4 ISO
on a different PC (or SSD)
  • Murphy
  • Murphy
09 May 2025 14:42 - 09 May 2025 15:39
@caskeslob. When I'm in CSS mode and moving the X axis . In halscope the Remora.sp signal looks like it's tapering , is it supposed to this? You can hear the spindle in the background slowing down with every adjustment . I'm moving in 10mm jogs .
youtube.com/shorts/wCQEtX8jdlg?si=56bFTHS2TniANqbB
Not in CSS mode
youtube.com/shorts/3FCbzGDeuUc?si=U3O0NyMvfS-R4K8-
  • CallumRD1
  • CallumRD1
09 May 2025 14:40
Replied by CallumRD1 on topic G-code file loading at G53 instead of G54
Category: Qtvcp
Sure. I'll try that this afternoon.
  • cmorley
  • cmorley
09 May 2025 14:34
Replied by cmorley on topic G-code file loading at G53 instead of G54
Category: Qtvcp
could you run in debug mode (DISPLAY = qtvcp -d qtdragon), run linuxcnc from a terminal and post the output?
  • Onkelmat
  • Onkelmat's Avatar
09 May 2025 14:29 - 09 May 2025 14:30
You are correct but in my case the servo isn't connected to the axis, and only spins when the +-10V are connected to the 7i77, if unplugged the servo is perfectly still.
The exact same setup for the Z axis works.
I'll check the axis configuration today, maybe I made a mistake.
  • Catch22
  • Catch22's Avatar
09 May 2025 14:12
I need 2.9 because I want Probe Basic, and it won't run on 2.8 for me..
  • heaven
  • heaven
09 May 2025 14:12
Control linuxcnc by FT sensor (external force)?
My FT sensor is a multiple-axis sensor that mounts at the robot end-effector. Tool gravity compensation, external force, and new joint position command calculation are already done, so right now I need to send these commands to LinuxCNC.
Sending via the jog command does not give me a smooth move, I will try the jogwheel function by converting the position command to jog count, not sure if it works
  • aeth
  • aeth
09 May 2025 13:51
Ethercat LinuxCNC board for a 4 axis router
Lately I started looking with great curiosity into LinuxCNC, because it seems to be one of the nicest and most affordable options to get EtherCAT and recently even s-curve acceleration control! In other words, as far as I know, it's the only solution on the market that offers such badass features as well as full configurability at a fraction of the price of other devices.
My current experience is with Mach 3 and UCCNC, but in both cases I was dissatisfied with motion planning where the machine would stutter a lot with complex toolpaths or with larger error allowance, it would run smoothly but it would mess with the surface finish.
My biggest hurdle right now is finding the right hardware. I saw countless solutions and configurations to get this done and I'm looking for something well proven that's not too hard to set up and doesn't look like spaghetti.
I was looking into Mesa boards, but even that got me a bit confused and I don't know what I should get. What's important for me is that the board offers screw terminals for interfacing with endstops and VFD and ideally it has its own computer - i.e. Raspberry Pi.
Could I ask someone for some recommendations?
Displaying 15811 - 15825 out of 17107 results.
Time to create page: 0.358 seconds
