What do you really get for a $350 desk top engraver ?
  • machinedude
  • machinedude's Avatar Topic Author
  • Platinum Member
  • Platinum Member
09 Apr 2025 07:23 #325966 by machinedude
it was on a belt drive with an omega style configuration.
09 Apr 2025 11:30 #325978 by spumco
I should have looked back in this thread - you did post some pics of the arrangement.
Sounds like excessive belt tension is the culprit - maybe in conjunction with a defect in the motor shaft.
Any room to mount a bearing on the motor shaft outboard of the timing pulley?  Or drive an intermediate shaft which is supported at both ends using a typical flex coupling (oldham, lovejoy, etc.)?
  • machinedude
  • Platinum Member
  • Platinum Member
09 Apr 2025 14:03 #325988 by machinedude
not easily so if it happens again i might have to rethink things. this was on the X axis so not too much mass being moved. the whole machine is pretty light less than 100lbs the X might hit 20lbs if that. most of the weight is the t-slot table and gantry beam.
