What do you really get for a $350 desk top engraver ?
02 Apr 2025 21:41 #325554 by andypugh
I think we would need a better macro photo to tel if that was a fatigue failure or not, but it leads me to be rather suspicious of the motor-to-shaft alignment and mounting. Is there any type of flex-coupling there?
03 Apr 2025 11:32 #325608 by spumco
I couldn't make out any beach marks on the surface. A macro would be interesting, as would pulling the bearing shield/seal and checking for signs of heat or abnormal conditions.
Wouldn't misalignment between motor and driven component tend to break outboard of the bearing?  That's assuming the bearing didn't come with lots of negative preload from the factory, of course.
03 Apr 2025 11:51 #325609 by andypugh
This is one of those cases where, given the final result, I can think of a plausible explanation. But that would be true in either case...
The moment is greater further from the shaft end, and a ball bearing isn't particulary stiff against torsion. Also the step that the bearing butts against, if machined poorly, might be a stress raiser.
03 Apr 2025 12:10 #325612 by spumco
Why do I get the feeling this is not the first time you've looked at failed (or suspect) industrial components?  Spend any time involved with, or doing, NDT/NDE?
03 Apr 2025 12:56 #325613 by andypugh
I spent 12 years at Sheffield University doing postdoctoral research on cracks of various sorts.
The following user(s) said Thank You: tommylight, rodw, spumco
  • Todd Zuercher
  • Todd Zuercher's Avatar
  • Platinum Member
  • Platinum Member
03 Apr 2025 15:23 #325623 by Todd Zuercher
Replied by Todd Zuercher on topic What do you really get for a $350 desk top engraver ?
I think Andy is on the right path. I can't think of anything other than shaft misalignment that would cause a stepper motor shaft to snap like that.
  • machinedude
  • machinedude's Avatar Topic Author
  • Platinum Member
  • Platinum Member
08 Apr 2025 09:03 #325908 by machinedude
the only other clue i can offer up at this point would be the fact that the bearing was not pressed in the motor housing. it came right out so maybe a poor press fit added to this?
08 Apr 2025 11:39 #325917 by spumco
Bearings are quite often an interference fit on the shaft but close sliding (or transitional) fit in housing.  Makes assembly easier, especially in production environments.  Interference fits on both the shaft and housing make assembly a nightmare.
Frequently for smaller motors a spring/wave/Belleville washer is used inside one housing end to permit the bearing to move axially as the rotor shaft grows (from heat).  That spring preload also tends to keep the bearing outer races from spinning in the housing bore.
If the bearing was a fairly sloppy fit in the housing there was very little resistance to shaft bending and all the movement would have been concentrated at the shaft bearing seat shoulder.
Andy's suspicion about a fatigue crack from shaft misalignment is looking pretty darn persuasive to me.
  • machinedude
  • Platinum Member
  • Platinum Member
08 Apr 2025 12:19 #325920 by machinedude
i just measured the bearing OD and the housing bore diameter, and the housing is a good .002 larger than the bearing OD. the shaft is either pressed into the ID or it got that way when it broke? the bearing feels like it is spinning just fine so i don't think the bearing was the root cause. the break was right at the shoulder where the bearing would ride and seat on the shaft. no wave washer on the front side and it does not feel like it has one on the other end either.
08 Apr 2025 19:57 #325954 by spumco
What kind of shaft couplers are you using, and how is (was) the motor connected/aligned to the ballscrew?
Time to create page: 1.522 seconds
