  • Roger S
  • Roger S
27 Apr 2025 13:00
Using POSIX realtime was created by Roger S
Category: EtherCAT
Hello everyone,
i have completed the Ethercat installation according to rodw
forum.linuxcnc.org/ethercat/45336-etherc...-how-to-step-by-step
The installation went smoothly and the final test was positive:Component Pins:
Owner   Type  Dir         Value  Name
     4  u32   OUT    0x00000001  lcec.conf.master-count
     4  u32   OUT    0x00000004  lcec.conf.slave-count
The following version of Linuxcnc is installed:
6.1.0-30-rt-amd64 #1 SMP PREEMPT_RT Debian 6.1.124-1 (2025-01-12) x86_64 GNU/Linux
When I check if /sys/kernel/realtime exists, I get /sys/kernel/realtime
When I check the module cia 402 (halcmd loadrt cia402 count=1), I get Using POSIX realtime
Am I wrong as a layman if I assume that this is not real real time and that there may be problems with some modules?
  • FPM
  • FPM
27 Apr 2025 13:00 - 27 Apr 2025 13:01
Replied by FPM on topic converting a tos/intos fngj 40
Category: Milling Machines
I have connected everything and flashed the bitfile from PCW. But it looks i have not configured the second card in the hal properly.
Attached the output of mesaflash readhmi, the hal and the crash report from lcnc
any ideas?
thanks in advance.
File Name: readhmi.txt
File Size:7 KB
File Name: intos_2025-04-27.hal
File Size:10 KB
File Name: linuxcnc.txt
File Size:9 KB
  • Surmetall
  • Surmetall's Avatar
27 Apr 2025 12:25
WEMAS MT 32 CNC Lathe -> LinuxCNC - Mesa or EtherCAT?
Category: Turning
I have a lot of mechanical work on the machine. Cutting and welding on the housing to get it smaller. maybe i will post pictures later if you are interested.
The plan for the drives at the moment is to use the SIEMENS Drivers if i can manage them to run... i think at least the Step Dir Config via SMC30 should be possible. But i would love to use ethterCAT like in this example.
support.industry.siemens.com/cs/document...p-pn-?dti=0&lc=en-WW
I have some experience with Mesa. After learning LCNC and help of great people like Talla83 and many more, my Deckel FP3NC runs really nice with it.
But i am a complete NOOB with EtherCAT. And to be honest, i am a little bit afraid of it. :D
So i hesitate to buy a used few hundred euro PCB for something i have no glue of :D
  • pgf
  • pgf
27 Apr 2025 12:04
Replied by pgf on topic comparing to Grbl, or FluidNC
"Not a Linuxcnc issue, but a user issue."
A little respect, please. There were fundamental changes, and a small attempt at automating the upgrade. I did read the docs, and I did make the manual changes I thought were required, and it did work... most of the time, and then it would stop working. I think maybe I'm trying to jog the jog the joints instead of the axes. Or else maybe that's fine, and the problem lies elsewhere. But either way, I have a debugging problem on my hands, and after a couple of hours, I'm still not done.
  • pgf
  • pgf
27 Apr 2025 11:58
Another good perspective. You're clearly a LinuxCNC guru. How much time have you spent using Grbl or FluidNC?
You mention no need for coding skills: I'd say that any time you open up a HAL file, you're coding, designing arbitrarily complex digital "circuits" in a text file. An incredibly powerful feature, but where's the UI? It's a graphical concept, one that should be supported via a schematic capture tool. But there's no easy way to even display a HAL file, let alone construct it.
  • unknown
  • unknown
27 Apr 2025 11:37
Replied by unknown on topic comparing to Grbl, or FluidNC
Thank you! Your's was exactly the voice of experience I was hoping to hear from.
I love/hate LinuxCNC. On the one hand, I spent hours last night trying to figure out how to get my USB gamepad "wand", which worked fine under 2.7.4, to work reliably under 2.9. On the other hand, it's likely that Grbl/FluidNC wouldn't support the gamepad at all.
I've wondered, too, about whether the Grbl comm protocol could be implemented on the front of LinuxCNC. I know the folks driving industrial mills would be horrified, but it might be a good solution in some cases.
Again, thanks for the feedback.
There were major changes to jogging from 2.7.x to 2.8, so any pendant would need work, that's why one should read the docs to see what has changed before upgrading. Once a again, not a Linuxcnc issue as such but a user issue.
  • unknown
  • unknown
27 Apr 2025 11:26
Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
Category: Installing LinuxCNC
If you're going to use a CM5 & carrier board you'd be crazy not to use an NVMe drive. It's fast, like really fast. I use one with mine Rpi5.
  • Tom369
  • Tom369
27 Apr 2025 11:23
Allgemeine Frage und Problem:hm2/hm2_7i96s_0: error finishing read! iter=1256216
Hallo,
Kurz zu mir, habe mich heute hier bei euch regestriert weil ich nicht weiter komme und glaube noch öfter hilfe brauch.
Bin der Tom 35Jahre ich habe minimal Linux vorerfahrung, hab ein Prusa MK4 und eine Bernado 550 Dreh Fräs kombi mit nachgerüsteten DRO
Habe die Zahnräder zur Zug-leitspindel hin ausgebaut und will die jetzt mit nen nema24 - cl57t - mesa 7i96s - ace minicomputer - joystick oder controller/win11rdp steuern.
Hab alles fertig angeschlossen! Netzwerk zu Mesa eingerichtet jetzt kann ich die karte pingen mit ca. 170-200ms
Gehe jetzt in den pncconf wizard und mach nur das nötigste xz lathe der Motor test der X-achse funktioniert Motor dreht sich!
Speicher alles + desktop verknüpfung!
Wenn ich jetzt die Verknüpfung startet kann ich die Mesa karte nicht mehr pingen...
Karte leuchtet 4xGrün 1xGelb(der obere)
Jetzt kann ich den Motor 5min lang bewegen...
So dann nach ca. 5min leuchtet jetzt der unter dem gelben auf der karte Rot und ich bekomme im program unten rechts die fehlermeldung:
Jetzt kann ich auch den Motor net mehr bewegen.
Hab natürlich schonmal gegoogelt anderer Kernel macht mir schon zu viel probleme bei der Installation.
Gibt ja hier bei euch nen thread mit 34 seiten, wo ich echt nich mehr durch blicke...
Muss doch nen Fix geben weil es ja anscheinend erstmal geht^^
Möchte der effiezens wegen noch ne 2 Frage mit zu geben
Ich lass den originalen Schlosskasten mit zug/Leitspindel drin bedeutet das ich den schrittmotor einmal im dauerbetrieb
eine richtung fahren lasse(wenn ich nur den automatischen vorschub brauche) und einmal ganz normal mit eingelegter
schlossschraube zum gewinde schneiden...
Ist das möglich? Weil die position nach manueller arbeit ja sozusagen nicht mehr stimmt...
Kann ich LinuxCNC die Position vom DRO geben bzw. das DRO als endschalter benutzen?
Vielen Dank
Gruß Tom
  • unknown
  • unknown
27 Apr 2025 11:20 - 27 Apr 2025 11:35
I don't know where this idea comes from that you need any coding skills to setup Linuxcnc. This is one of the biggest lies attributed to Linuxcnc (Linux in general), it's bullshyte. You don't need to be a coder, even to type instructions at a terminal, no one ever said you need to be a coder to use MSDOS. That was the point of a OS to enable the system to be used by "non computer people" as well as a lot of abstraction & a million other things.
Setting up Linuxcnc for a basic 3 axis mill take no time at all using the Linuxcnc supplied config tools. Whether it's a parallel port or 7i92 based system. The biggest issue I see users have is not paying attention to the errors reported in the error report, things like pin xx doesn't exist, usually it's a typo. Or a user expecting a pin to exist that doesn't. Realtime errors are a PC issue, not really a Linuxcnc config issue.
Whether you axis, gmoccapy or your "grbl module" (whic I think will be a performnce hit in a bad way) you will still need to setup a linuxcnc config, the very thing you've been mentioning.
If you want to use grbl use it, but Linuxcnc is a completely different beast, but don't expect any grbl functionality from Linuxcnc.
Mesa, LlinuxcncRIO & Remora all work along a similar concept, step & direction signal generation is off loaded to the external motion control card.
I don't know why you would want to send a gcode file line by line to linuxcnc when it can open and read the file directly.
One thing that is very intriguing, you admit to poor coding skills, yet propose some major replacement of the Linuxcnc internal workings.
In reality all grbl is is a way to send data via a serial port.
  • pgf
  • pgf
27 Apr 2025 11:18
  • 3404gerber
  • 3404gerber
27 Apr 2025 11:04
I have a LinuxCNC image running on a CM4/eMMC, so it should also work on the Pi5.
  • ErwinCNC
  • ErwinCNC
27 Apr 2025 08:47
Hello
I put my pi 5 into operation yesterday.
Unfortunately I get the locale error with Pconf
I tried to use the same settings as you.
My keyboard is german
Do you have an idea?
  • AMLD
  • AMLD
27 Apr 2025 08:41 - 27 Apr 2025 08:43
QtDragon_hd + Basic Probe - probing results not displayed
Category: Qtvcp
I have added the missing part to the INI file and change basic_probe.py, probe_routines.py and probe_subprog.py to the original files from v2.9 from github.
After performing additional measurements, it appears that the issue of bad synchronization between the measurement process and data updating in the widget mainly occurs when the feedrate value changes during probing. If the value remains stable throughout the measurement, the probe measurement cycle completes correctly.
The video shows four consecutive measurements:
  • The first measurement was completed without issues.
  • In the second measurement –> at 37 seconds in the video, the feedrate oscillate from 52% to 51% and back during the probe measurement, after which the value in the table for the Z axis changed. However, the measurement had not yet been completed.
  • The third measurement –> similarly to the second, at 1:06 the feedrate oscillate from 40% to 41% (a very quick oscillation), after which the value on the axis Z changed.
  • The fourth measurement was completed without issues (no feedrate oscillation).
Do you have any idea how a change in feedrate could affect the value update in the widget?
  • 3404gerber
  • 3404gerber
27 Apr 2025 07:39
Replied by 3404gerber on topic Potential All-in-One Single Board Computers
The Radxa Zero 3E is a nice small SBC very similar to the Pi Zero but available with more RAM and an ethernet connector. You don't want to use it for step generation, but with the latest Armbian running a 6.12 RT kernel, the latency is ok, especially for a headless motion controller running a servo-thread. Could be interesting for example in a OpenPNP setup. One problem is that USB is not working with current kernel, but this will probably be fixed soon.
Yesterday I ran a G1F1X100 command with 6 TMC5160 connected over SPI @ 6MHz and spidev driver; the servo-thread (reading all 6 position, writing all 6 speed, only one PID) stayed under 0.75 ms for the entire 100 minutes.
  • 3404gerber
  • 3404gerber
27 Apr 2025 07:15
Replied by 3404gerber on topic comparing to Grbl, or FluidNC
I retrofitted my first engraver with GRBL; took an Arduino nano, read the manual for 3 hours, connected everything in 2 more hours and had a working system that I used till my spindle controller card burned while milling a pcb... I then retrofitted a small desktop mill and went this time for GrblESP32, which became FluidNC later. Again, the set up was quick, efficient and functional.
I started to read about LinuxCNC when I was trying to use TMC5160 stepper with their internal motion controller rather than with step/dir signal. For me this could be the first big difference; if you look for a G-Code interpreter to generate up to 6 axis step/dir signal at a fairly high frequency and need the standard Start/Stop/Pause inputs, then go for Grbl-like system. If you need more complex interaction with hardware, then LinuxCNC is the answer.
The second big difference is probably the difficulty; maybe not the best example, but after several months I still don't have a working system. But to be fair, it has a lot to do with my poor coding skills, and the fact that my mill is currently working well under FluidNC. Anyway, even for a standard project, you will have to find a reliable step generator (PC-based or external), find the correct configuration, adapt the INI and hal files, choose a GUI. There are many options and that's fantastic, but it takes time to figure everything out. FluidNC works on ESP32 and uses one config file. That's it.
Speaking of figuring things out, this forum is certainly the third big difference; yes, FluidNC has a nice wiki, yes 3D printing Grbl-like systems like Klipper, Marlin, etc have also a lot of users and forums. But this forum is a real gold mine and there are so many different information about so many different subject that you can spend hours here without thinking about your mill. :) Congratulations guys!
The fourth and for now last difference I'll mention is the GUI; as said before, Grbl-like systems are G-Code interpreters and they do not offer any user interface. So one option is to use none and just put your G-Code on a SD card and start it with a button or a small touch screen, or to connect an external PC that will host the GUI. There are different existing software and I don't know them all; I use bCNC and tried UGS. They are very fine for simple setups, to home machine, use camera for alignment, Z and tool probe, etc.
In my current project, I try to use LinuxCNC on a Radxa Zero 3E as a headless 6-axis motion controller. For this, it would be fantastic to have a module similar to linuxcncrsh but "speaking" Grbl standard; I could use any of those existing G-Code sender with my LinuxCNC board. On the other hand, the Remora component use external micro controller to generate steps/dir signals, but in theory, a Grbl component could completely replace the EMCMot+Stepgen components in LinuxCNC for stepper motors signal generation.
Displaying 16561 - 16575 out of 17167 results.
Time to create page: 0.466 seconds
