  • Grotius
  • Grotius's Avatar
24 Apr 2025 18:01
Replied by Grotius on topic LinuxCNC S-Curve Accelerations
Can we test the cia-402 and shortcut linuxcnc pos-cmd to pos-feedback so
there is no ferror in linuxcnc that can trigger a motion stop?
Or test it by hooking the cia-402 to a stepgen or pid without closed loop feedback.
  • PCW
  • PCW's Avatar
24 Apr 2025 17:25
Replied by PCW on topic Stepper motors for a EtherCat system
The motor type doesn't matter, it just needs to be supported by the drive.
The drive needs to be EtherCat compatible or you will need an EtherCat
-> step/dir interface.
  • cmorley
  • cmorley
24 Apr 2025 16:41 - 25 Apr 2025 00:29
Replied by cmorley on topic qtdragon mod
qtdragon mod
Category: Qtvcp
The problem is that the 'on_counts_value_changed' function uses the 'value' (encoder counts) as an absolute value (as you said), but you could use it as a relative value.
if new value is higher then the last value, then move up 10% higher then the current rate.
if new value is less then the last value then move down 10% from the current rate
The current rate you can get from STATUS or from the appropriate widget.
I'm sure there will be some minor details to adjust to.
  • billru
  • billru
24 Apr 2025 16:27
Stepper motors for a EtherCat system was created by billru
Hello everyone,
This my first post, I am a DIY hobbyist I am trying to learn what hardware is being used for a diy CNC mills. I ran across different system and setups but I have been unable to get a clear understanding on stepper motors being used in a diy home type CNC mill for a EtherCat setup.I have poked around and searched youtube but still have not got a clear knowledge, my question is can a Nema 23 closed loop stepper motors with encoder be used in a EtherCat setup or dose the stepper have to be EtherCat designated style motor.
I have some 23HS30-5004D-E1000 motors I was going to try and play with and see if I can learn a Ethercat system
  • Hakan
  • Hakan
24 Apr 2025 16:14
Replied by Hakan on topic LinuxCNC S-Curve Accelerations
It's pretty rudimentary. There are these basic PDOs
      <syncManager idx="2" dir="out">
        <pdo idx="1600">
          <pdoEntry idx="6040" subIdx="00" bitLen="16" halPin="cia-controlword" halType="u32"/>
          <pdoEntry idx="6060" subIdx="00" bitLen="8" halPin="opmode" halType="s32"/>
          <pdoEntry idx="607A" subIdx="00" bitLen="32" halPin="target-position" halType="s32"/>
        </pdo>
      </syncManager>
      <syncManager idx="3" dir="in">
        <pdo idx="1a00">
          <pdoEntry idx="6041" subIdx="00" bitLen="16" halPin="cia-statusword" halType="u32"/>
          <pdoEntry idx="6061" subIdx="00" bitLen="8" halPin="opmode-display" halType="s32"/>
          <pdoEntry idx="6064" subIdx="00" bitLen="32" halPin="actual-position" halType="s32"/>
        </pdo>
so basically one send a wanted position to the drive and read the current position back. That's all.
Following error is calculated in linuxcnc.
The cia402 module basically just passes position after scaling to the drive. And reads back actual position.
It also does the state machine walking, but that's in the beginning, then that idles.
  • jjdege
  • jjdege's Avatar
24 Apr 2025 15:18
I do the ST Linkv2 procedure and it does everything right,
hi
by correct procedure you mean the one described by @Scotta to convert a STlink V2 into a CMSIS-DAP probe.
Pyocd will not see it as STlink, but as CMSIS-DAP
pyocd list
  • vre
  • vre
24 Apr 2025 15:08
XHC-HB04 wireless MPG pendant HAL module
Category: HAL
Some easier way to do this ?
This code github.com/LinuxCNC/linuxcnc/blob/master.../hallib/xhc-hb04.tcl
creates hal pins pendant_util.X can do something with these pins?
  • meister
  • meister
24 Apr 2025 13:18
Replied by meister on topic Umstieg auf LinuxCNC mit RaspberryPi4
Category: Deutsch
Moin,
willkommen im forum.
für den Raspberry gibt es auch einen Parport adapter, so könnte man ein altes alte Mach3 BOB vielleicht weiter nutzen:
byte2bot.com/products/parallel-port-raspberry-pi-hat
aber es kommt auch immer darauf an was man vor hat, es gibt da einiges an hardware die man nutzen kann: Mesa, Remora, Rio, GPIO.
Gruß Olli
  • rodw
  • rodw's Avatar
24 Apr 2025 13:15
Replied by rodw on topic LinuxCNC S-Curve Accelerations
hmm, I am not seeing 6065 in my drives manual.
0x603F reports any errors including following errors which are described as Closed-loop mode tracking error over limit
In practice, a drive error is thrown and this pin can be referred to to determine the error . I have seen a few following errors here.
  • kitkat
  • kitkat
24 Apr 2025 11:21
How do I catch the loadusr process termination signal in LinuxCNC 2.9.2?
Category: HAL
English is not my native language, so sorry for possible mistakes.
I write a c++ program that I run by adding loadusr myprogram to custom.hal(I'm using AXIS gui). This program do some stuff and closes with exiting from AXIS. I catch unix signals like SIGTERM and SIGQUIT to gracefully terminate this program(closing file descriptors, sockets and so on). Everything worked fine on LinuxCNC 2.8.4 but stopped working when I switch to LinuxCNC 2.9.2.
I can catch and handle signals when I directly run my program from terminal, but I can't catch signals when I run it via loadusr. I try with SIGTERM, SIGINT and SIGQUIT signals, nothing gets caught. Looks like in LinuxCNC 2.9.2 AXIS does't sending any of this signals to close it's loadsur subprocesses. Does it use any other signals to close its subprocesses? Or do I need to use another way to catch the termination of the program?
  • COFHAL
  • COFHAL
24 Apr 2025 10:47
Replied by COFHAL on topic XHC-HB04 wireless MPG pendant HAL module
Category: HAL
You have to use an OR comparator, to connect two inputs to a single output.
  • Grotius
  • Grotius's Avatar
24 Apr 2025 09:27
@Rod,
In the mean time, have done some reading about the cia-402.
  • The
    0x6065
    : following error window is not used or set by linuxcnc.
  • Velocity mode in combination with a tuned linuxcnc pid could be a try out.
@Tia,
if you want to access my machine remotely i can give you access
We could verify iff all is installed ok. Like the libclothoid is in place etc.
But i think you already used the ./installer. It can be the installer failed at some step.
For the rest i don't know much about the cia-402.
  • Aciera
  • Aciera's Avatar
24 Apr 2025 09:27
Replied by Aciera on topic Has Anyone used DeskProto
Category: CAD CAM
No double posting. Thank you.
  • vre
  • vre
24 Apr 2025 09:23
Category: HAL
I have already configured in hal cycle start pause stop external buttons
and spindle start stop external buttons and when i start linuxcnc it reports that
these signals already used and can't used by XHC-HB04.
How can i use both the external buttons and XHC-HB04 together without conflict ?
  • Marc
  • Marc
24 Apr 2025 08:42
Replied by Marc on topic Has Anyone used DeskProto
Category: CAD CAM
Hallo und guten Tag, bin neu hier und habe eine Frage zu deskproto.
Auf welchem System benutzt du es ? habe es über Wine auf Zorin installiert, Startbildschirm von Deskproto öffnet sich auch, habe es lizensiert - jedoch kommt dann recht schnell die Meldung "deskproto antwortet nicht" mit den Optionen "Beenden erzwingen" oder "warten". Unter warten geht es leider gar nicht weiter sodaß mir nur bleibt das Program zu beenden- irgendeine Idee warum das so ist ? besten Dank und Gruß Marc
Displaying 16681 - 16695 out of 17175 results.
Time to create page: 0.700 seconds
