  • unknown
  • unknown
22 Apr 2025 20:44
Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
Category: Installing LinuxCNC
The kernel is a custom one based on the RPi sources, as such the kernel headers are preinstalled.
If you read the very first post in this thread you will realise that the image is based on Debian 12 with a RT kernel based on the RPi sources.
I have my Pi in a metal enclosure and haven't noticed any issues with wifi. Your mileage may vary.
Have you tried plugging in your dongle and checked if the kernel loads drivers ?
  • PCW
  • PCW's Avatar
22 Apr 2025 20:29
Replied by PCW on topic amplifier fault troubleshooting
Category: Driver Boards
This:
net plasmac:breakaway joint.0.amp-fault-in <= hm2_7i97.0.inmux.00.input-04-not
Looks like the only thing that can generate a amplifier fault
  • bentiggin
  • bentiggin
22 Apr 2025 20:20
Replied by bentiggin on topic amplifier fault troubleshooting
I haven't edited files between things functioning and when amplifier fault problem started.
  • bentiggin
  • bentiggin
22 Apr 2025 20:17
Attached
  • PCW
  • PCW's Avatar
22 Apr 2025 20:11
Can you post your hal/ini files?
  • Turners
  • Turners
22 Apr 2025 20:09
Replied by Turners on topic boxford 160tcl
boxford 160tcl
Hi guys sorry to spam I've been told I need two of these opb866t55 but as cannot solder in need the wired equivalent could
anyone recommend from rs components link please?
www.google.com/url?sa=t&source=web&rct=j...ZB86ElWxq3tzU_1B6xk7
  • bentiggin
  • bentiggin
22 Apr 2025 20:04
It is not a following error.
The pop up says "operator error: joint 0 amplifier fault".
The terminal says
emc/task/taskintf.cc 976: Error on joint 0, command number 110
I never hooked up a way for the 7i97t to sense amplifier faults. The only input from the amplifier is the encoder.
  • PCW
  • PCW's Avatar
22 Apr 2025 19:42
Is the error an amplifier fault (something that would require a 7I97T input connection to sense)
or a joint following error? (cause by incorrect or lack of motion/feedback)
  • DarkPhoinix
  • DarkPhoinix
22 Apr 2025 19:36
Replied by DarkPhoinix on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
I try again and C turning in all direction.
  • DarkPhoinix
  • DarkPhoinix
22 Apr 2025 19:29 - 22 Apr 2025 19:31
Hi
the board is a 3-axis, but I don't think it depends on that, I think.
Ultimately, on six axes XYB working, Z and C turning in one direction, dir doesn't work, A doesn't work.
I haven't had any luck....
this is the second board, the first one in understanding how to flash it I must have made it unusable, I can't get it back.
I don't want to buy another one, never mind.
Thanks for the feedback
try this:
mkdir ~/linuxcnc/configs/remora-rt1052-test
pair the contents in this dir:
github.com/scottalford75/Remora-RT1052-c.../remora-rt1052-basic
download this: github.com/scottalford75/Remora-RT1052-c...xCNC/nvem-rt1052.txt
python3 upload_config.py nvem-rt1052.txt
pair your files:nvem-rt1052.hal,nvem-rt1052.ini
then:
and try again please
  • jjdege
  • jjdege's Avatar
22 Apr 2025 18:50
Hi
  • bentiggin
  • bentiggin
22 Apr 2025 18:41
amplifier fault troubleshooting was created by bentiggin
I recently started working on finishing a plasma table retrofit that was put on hold for about 6 months.
It has servos, a hypertherm hsd 130 (I believe HF start), and a mesa 7i97t.
I thought I had it ready for a trial cut, but when the torch fired, I got an error.
error finishing read! iter=172124.
I tried again with the same result. I eventually realized that I had removed the torch start relay and diode, and instead hooked the torch start wires directly to the 7i97t. (Not for any good reason, I just kinda forgot what little I had figured out from 6 months ago and was hastily making wiring changes.)
Despite not making any changes after my 2 failed test cut attempts, I am having a new problem.
Now, after I start linuxcnc, when I hit the power button at the top of the plasmac screen, I immediately get joint 0 amplifier fault.
The DRO stays at 0 for all axis's when physically moved, but the amplifiers appear to be on and displaying encoder counts correctly on their little read outs.
I'm worried I damaged the 7i97t, but don't know where to go from here. Any advice is appreciated.
  • Turners
  • Turners
  • Turners
  • Turners
22 Apr 2025 18:24
boxford 160tcl
Hi guys just an update it should have 2 separate ones one counts the large slot and one counts a single slot. so two go one plug. still unsure what to buy something like this? but pre wired ones as my soldering ability
  • DarkPhoinix
  • DarkPhoinix
22 Apr 2025 17:47 - 22 Apr 2025 18:48
hi
thanks for the feedback,
for testing I downloaded again from the link you posted, I loaded the configuration file that is in the folder, the I/O seem not to be suitable for the NVEM, however dir/step are suitable,
my result does not change XY works, Z pressing forward and backward only turns in one direction, the dir channel does not work, and I think that by also setting the A axis it does not work.
I think it is a hardware problem.
thanks
Hi, I used your configuration by copying your files to mine and all the axes work. Did you get a board with only 3 axes? Or do you have a 6 axes? Because the manufacturer could have not soldered the bga. Or simply there is some faulty circuit, I don't know if there are opto-isolators in the output but there should be.
but I didn't compile any hal file like this  "nvem-rt1052.hal"
Displaying 16756 - 16770 out of 17181 results.
Time to create page: 0.535 seconds
