  • emresensoy
  • emresensoy
20 Aug 2026 08:41
CNC Manual Panel | EtherCAT | LinuxCNC | 9 Axis
Category: Show Your Stuff
I'm sharing my new 9-axis CNC control panel, designed to industrial standards and based on LinuxCNC.
With its fully customizable structure and ergonomic design, you have complete control at your fingertips.
Key features:
Simultaneous control support for up to 9 axes.
Ergonomic axis selection and jog control.
All functions integrated, including spindle, coolant, tool release, and emergency stop.
Hardware fully compatible with LinuxCNC flexibility.
  • cgrobi
  • cgrobi
20 Aug 2026 08:12
DEFAULT_LINEAR_VELOCITY does not change the jog speed in Probe Basic
Category: Basic Configuration
Hi to all of you,
I am new to LinuxCNC and I set up a system using Ethercat and Probe Basic. I am getting more and more familiar with the configuration system and so far, everything works really well. The motors are moving and IOs do what I want them to do. So far so good.
The only problem I have is the use of DEFAULT_LINEAR_VELOCITY in the TRAJ section of the ini file. No matter what I put in here (trying to set it to 50mm/s), the speed ends up always beeing 600 mm/min ( which is 10mm/s). I checked the ini file if the line occurs twice. I also checked linked files but I can't find another occurence. It just drives me nuts. I searched several internet advices but no explained solutions work for me.
It would be very nice if someone could have a look at my files and maybe find a solution I didn't see myself. Thanks a lot for this.
Please be aware, that I did prepare the hal file for more axis than three. But I only have 3 servos at the moment so there might be some future changes.
  • Oxbown
  • Oxbown
20 Aug 2026 06:54
Just updated to the dev branch and tested the new feature with the Tang Nano 9K: it works perfectly!
The board now starts communicating and reading inputs immediately as soon as LinuxCNC launches, completely solving the startup issue.
Huge thanks for implementing this so quickly and for being so attentive and responsive. Really appreciate your support!
  • meister
  • meister
20 Aug 2026 06:16
@Oxbown
I’ve added an option for AutoConnect,
but I haven’t been able to test it properly yet; at least it’s already working in the simulator (dev branch)
  • meister
  • meister
20 Aug 2026 05:40
Hi, ok, i understand what you mean, this is 'work as designed', little bit different to mesa :)
but i will check how to connect directly on startup.
  • Oxbown
  • Oxbown
20 Aug 2026 05:15
Hi!I ran into a weird issue with my Tang Nano 9K setup (using Axis).On startup, LinuxCNC doesn't seem to read any inputs from the FPGA until I manually toggle E-Stop off in the UI (F1) at least once. After that initial click on screen, all physical buttons and inputs work perfectly.It's a bit of a chicken-and-egg problem, as I can't use a physical reset button to clear the initial E-Stop on launch.Is the communication loop paused while in initial E-Stop, or is there a way in HAL to make RioCore poll and update inputs right from the start?Thanks!
  • Tim Bee
  • Tim Bee
20 Aug 2026 04:15 - 20 Aug 2026 04:56
Dear meister:
It's looks so cool!
In attachments is user manual in English version that I translated help with AI.and pcb top/bottom views
Yes, On the bottom of PCB have some testpoint to download firmware
Tim
  • NWE
  • NWE's Avatar
20 Aug 2026 01:29
Chinise mesa clone vs Original vs Ethercat
Category: Driver Boards
I mean:  1 pc port, 1 Ethernet switch, 1 Ethercat drive (Z axis), 1 c-mesa card 7i92 with X, Y axis connected. runnig in a loop
Nice. Which model Wago ethernet switch did you use? I was under the impression most ethernet switches don't run ethercat.
  • Halbear
  • Halbear
19 Aug 2026 21:58
Replied by Halbear on topic QTDragon 5-axis trt
QTDragon 5-axis trt
Category: Qtvcp
I think I'm still on 2.09. I have one of those network cards that was a pain to troubleshoot when I originally set LCNC up (it kept randomly freezing up the Mesa board) and therefore I've resisted upgrading the LCNC version
  • leexi
  • leexi
19 Aug 2026 20:04 - 19 Aug 2026 20:41
Replied by leexi on topic Chinise mesa clone vs Original vs Ethercat
Dear,
Yes, I tested with X and Y axis controlled by c-mesa 7i92 ver 2.0 and Z axis on Ethercat port, and works fine, I run a program and looks fine but i do no cut any piece of metal yet because this is a test setup and the Z ethercat servo was a external rtelligent ethercat closed loop step motor and my original z servo is way bigger and it is step and direction controled
And after as a test I disconnect the 2 Ethernet ports, and then I use only one Ethernet port and I made the proper setup for ethercat mac address for the same port as the mesa port , and I use a Ethernet switch from wago (industrial Ethernet switch) and I connect only one PC Ethernet port (the original one onboard port from ralteck), and the ethercat drive and c-mesa card to the same switch and was working fine, I did not spend to much time testing, because I need the machine back to work again,
o001;
g4 p2;
G0 x0 y0 x0;
g4 p2;
g0 x5 y5 z5;
m99
speed (90 ipm)
And I am really surprised that I test some mixed configuration and the CNC machine with probe basic GUI, and was working fine without prompt me a issue,
  • tomscnc
  • tomscnc
19 Aug 2026 17:24
  • GFC
  • GFC
19 Aug 2026 16:04
Replied by GFC on topic THC doesent work when G code is running
Category: Plasmac
I just checked, the Gui button changes the pin, but isnt affecting the thc activation
  • PCW
  • PCW's Avatar
19 Aug 2026 14:54
Replied by PCW on topic Mesa 7i92TM+7i77+7i76U configuration
Yes, the 7I77U is identical to the 7I77 and 7I77D  FPGA interface wise.
  • meister
  • meister
19 Aug 2026 14:34
Thank you Tim,
Thanks very much for the details; I’ve entered the board’s details as best I could,
I hope it’s all correct so far – please do have a look over it.
What’s not quite clear to me yet is, how do you flash it? Are there any connectors on the back?
You’re also welcome to send me some text and a link for the description, and I’ll update it.
  • Firehunter
  • Firehunter
19 Aug 2026 14:23
Replied by Firehunter on topic Mesa 7i92TM+7i77+7i76U configuration
Okay, thanks! Is the .bin file for 7i77 the same as for 7i77U?
Displaying 1726 - 1740 out of 11356 results.
Time to create page: 0.635 seconds
