  • darrylb123
  • darrylb123
15 Mar 2025 05:49
Replied by darrylb123 on topic SCATECH EV1616DN - Example config
Category: EtherCAT
Assuming the Mesa 7i92 is my answer, I'm in Australia, I looked for a local distributor and a 10 year old post on CNCZone from rodw said that he too was Australian and had them for sale?? Is this still the case and how do I go about buying one?
  • unknown
  • unknown
15 Mar 2025 05:37
Replied by unknown on topic SCATECH EV1616DN - Example config
Category: EtherCAT
Ethercat will work with Ethercat servo\stepper drives and other Ethercat devices, unfortunately my endeavors and experiments have been in other areas.
Linuxcnc comes with a plethora and sample & simulation configs, but what you want to do may not be even possible or may require more work than you've assumed. Have you explored the Linuxcnc menus, tried a simulation config, read the Linuxcnc docs ?
Did you even bother to have a look at the 2 links I gave you ? One of them explains the reset function.
When you try to run a config that you think will work what errors if any are you gettting ?
Are you getting any output at all ?
Have you got access to a logic analyser or 'scope ?
Does Ethercat hardware support updates every 25000ns, as this would have to match the base thread timing. Otherwise the steppers are going to be very very slow with updates every 1ms.
The best bet would be just to get a single axis moving, as a proof of concept and evaluate the performance.
There is a lot that you may have assumed & expected that may not be the case or possible.
Tho it does sound like a reasonable & unique idea, but I think you may be delving into unknown territory. So you make have to come up with a lot of solutions on your own.
No one would try and shut you down, but there maybe more hurdles than you realise.
In honesty I don't see how it would be an improvement over an external board that generates step & direction timings. Or an ethercat driver servo/stepper driver.
  • Hakan
  • Hakan
15 Mar 2025 05:26
Replied by Hakan on topic SCATECH EV1616DN - Example config
Category: EtherCAT
Sounds like you want to use this IO board to drive Step/dir signals for a stepper motor driver.
It will work kind of but you will be severly restricted by the slow speed of the servo thread.
Say 1 ms servo thread, which is normal, and you will get max 500 steps per second. You will need 10 times more than that, easily.
  • PCW
  • PCW's Avatar
15 Mar 2025 05:10
Replied by PCW on topic OLD Lathe conversion to a CNC
Category: Turning
Have you tried a 2 ms servo thread?
  • darrylb123
  • darrylb123
15 Mar 2025 04:45
Category: EtherCAT
Pardon my confusion.
There seem to be a lot of supported modules, I haven't looked at the capabilities of each one. What is the ethercat support for in Linuxcnc if not for IO?
Why would I need to write my own real time driver when the existing one is loaded real time? It seems to work.
I'm fine with creating my own HAL file . Where are the example configs? If I google linuxcnc 3 axis hal example, there are only people on this forum asking similar questions. The documentation only contains snippets. This is why I expected to start with my existing hal file created by stepconf
  • besriworld
  • besriworld
15 Mar 2025 04:18 - 15 Mar 2025 04:47
Replied by besriworld on topic OLD Lathe conversion to a CNC
Category: Turning
Sometimes I get this warning:
hm2/m2_7198.0: Smart Serial port 0:Dolt not cleared from previous servo thread. Servo thread rate probably too fast. This message will not be
repeated, but the hm2_7198.0.sserial.O.fault-count pin will indicate if this is happening frequently
PS I'm wondering if I should try using an external LAN card in a PCI slot. What kind of PCIe x16 LAN card should I get?
  • unknown
  • unknown
15 Mar 2025 04:18
Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
Category: Installing LinuxCNC
One thing you can try is logging in via ssh, before things lockup, and when they do see if anything untoward shows up in dmesg or any of the other log files.
Does it occur when just running one of the sims from the Linuxcnc menus.
Are you able to use a config that uses Axis, if so does this give the same problems.
Just to confirm your are using one of the images from the downloads page, without an extra packages installed, cos I'm not sure if ctrl-esc gets the task manager. On the RPi5.which is the same apart from the kernel support, it doesn't bring up a task manager.
Before the title was changed, it was mainly to do with the Linuxcnc images, not Linuxcnc on Raspberry Pi OS.
Tommy if you see this can you change the topic heading so it reflects this is support for the Official Linuxcnc Rpi Images, I didn't intend for it to support Linuxcnc on the Raspberry Pi OS. That should be dealt with elsewhere.
I'm pretty sure the original tile reflected that.
  • U2fletch
  • U2fletch
15 Mar 2025 04:01
I have a second Pi 400 on my Ham Radio station, so I switched the two keyboards and fired up LinuxCNC on the "new" board.  I let it sit for awhile trying to duplicate what happens.  Basically the display becomes unresponsive to anything.  The cursor moves around, but I cannot select between pages on GMOCCAPY. However I can still jog the machine around using my pendant, so It is still communicating with the Mesa 7i96 board. Also I cannot ctrl-Esc the Pi to access the task switcher, so something is locking up.
  • U2fletch
  • U2fletch
15 Mar 2025 03:54
Sorry, did not think it would affect the whole thread.
  • PCW
  • PCW's Avatar
15 Mar 2025 03:49
Category: Turning
What error do you get? Delayed sserial communications have no effect on Ethernet timing.
  • besriworld
  • besriworld
15 Mar 2025 03:03
Category: Turning
@tommylight
Of course, there is thermal paste, and it's high-end. I'll check how the fan is spinning, but the issue could be due to the small case and the compact CPU cooler.
@PCW
The maximum clock frequency is 3.3GHz. Maybe this is a stupid question, but could the issue be caused by delayed communication between the 7i98 and 7i73, possibly due to dropped packets smart serial?
  • unknown
  • unknown
15 Mar 2025 02:48
Replied by unknown on topic Funny message when reply to a topic
Category: Forum Questions
It was related to the number of recipients per message, not total emails per day.
ie: no more than 5 recipients per message.
I was more concerned with why I was seeing it, since I'm just a pleb ;)
  • unknown
  • unknown
15 Mar 2025 02:46
  • unknown
  • unknown
15 Mar 2025 02:41
Need help with sourcing something in Aus to run Remora
Fellow Aussie, there's a few of us around.
Shame you're low on space, I've got a running 7c81 clone here.
github.com/ozzyrob/Linuxcnc-FPGA
Anyways shoot us an email, that's on my github.
  • smc.collins
  • smc.collins
15 Mar 2025 01:54
Implementing Spindle Homing for DELTA C2000 Plus (In)correctly?
Category: EtherCAT
are you using this for C axis work or just threading ? if just threading, then, it's already handled in spindle mappings in the base config, you just need to make sure to connect it in the HAL file to the Z/index pin. If it's for C axis live tool type work, that's a bit outside of my experience as I haven't had time to finish my own work towards that myself.
Displaying 17566 - 17580 out of 18592 results.
Time to create page: 0.339 seconds
